Everything posted by J A Blazer
Leaks Gas Inside-outside FIXED
J A Blazer replied to Rhubey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is serious. You should not drive this car. Have it taken by flat-bed tow-truck to a competent mechanic immediately.
timing belt replacement
J A Blazer replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSmpol19 - do you mind sharing the name of your mechanic? I'm in Fairfax and in need of the 105K very soon. Thanks.
Head gasket replaced and now problems --pls help
J A Blazer replied to yameyer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds to me like you had a leaking valve cover gasket, not head gasket.
Question on pw switch operation - 2000obw
J A Blazer replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2000 OBW has one.
Rear door panel help - 2000 obw
J A Blazer replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did this recently on my 2000 OBW and it was not difficult, but I do not remember whether you might also have to pry up the window switch assembly - it is possible that another screws lurks back there, but I doubt it. Are you sure that you are lifting the panel up first, then away from the door? There is a top lip that rests next to the glass.
best way to flush an auto tranny
J A Blazer replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure about that; my 2000 OBW has an external filter on the automatic transmission.
ATF level check - help!
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI repeat myself - new fluid is not sufficiently opaque and is therefore difficult to see on the dipstick. Hot, idle, in park - I understand, but what about the difficulty in seeing the fluid? Any suggestions, or is there nothing else that I can do?
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPart of the problem is that the fluid is relatively clear and its hard to distinguish the level on the dipstick; suggestions?
What is the secret to determining the level of ATF with any degree of confidence? Cold or hot, at idle or off? I changed the fluid, but the dipstick simply doesn't consistently register the level of fluid.
90k Service Advice for `01 OBW
J A Blazer replied to bawalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre these items recommended at 90K, or at 105K?
1997 OBW - good deal?
One-owner 1997 Outback wagon, 122,000 miles, well-maintained, no issues apparent. Worth $5,000?
Lock system problem
J A Blazer replied to Sweden's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuestion: In my 2000 OBW, opening the driver's door with the key unlocks only the driver's door (even with multiple rotations of the key) yet with the remote all doors will unlock. Is this normal? If not, what is the explanation?
ac is blowing hot air
J A Blazer replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXe-mail me directly at JABlazer@aol.com
J A Blazer replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm in Fairfax and happy to look at it if you want. I'm near George Mason.
need help finding oil leak
J A Blazer replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou personally rebuilt the motor, but don't know where the steering rack is? How is this possible?
Looking to buy late ninties - early 2000s Outback
J A Blazer replied to heep70's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRegarding price range, I did considerable shopping before I bought mine 3 months ago. It is a 2000 Outback wagon, base model. I bought it from a local dealer. It was a one-owner, with most of the service records. Well-maintained, no issues. 'Sub-frame recall' and 'coolant additive' had been timely done and documented by the dealer. 85,000 miles. I paid $9,600 which I considered a good deal. I've fixed a few minor things, nothing major. Very happy.
J A Blazer replied to heep70's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe body style changed for year 2000, so my recommendation would be to get that year, at the earliest.
CD Changer Repair
Although the 6-disc changer in my 2000 OBW would accept discs, it would not play them; I replaced it with a single disc player and the setup now works fine, so that tells me that its not the head unit that's to blame. But any suggestions on where to send the changer for diagnosis and repair? Its too valuable a device (over $400 retail) to throw out. TIA. I'm in Fairfax Virginia if that matters.
ATF change
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI too find it hard to read. I measured what I removed and I then replaced it with the same amount. This assumes that an appropriate amount was in to begin with, but its a start.
Lightly sticking caliper...
J A Blazer replied to eseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBe sure that you are trying to remove the bolt in the proper direction. If you are facing the rotor, and attempting to remove the caliper bolt from behind (i.e. the threaded portion is pointed towards you), keep in mind that you want to be applying force in the clockwise direction when viewed from your perspective.
Brake job
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI forgot to mention - each set also had 4 guide clips.
Brake job
I purchased from the dealer front and rear pad sets with which to do a brake job on my 2000 Outback Wagon. Front set had two sets of shims (4 black and 4 silver), two tubes of anti-squeal paste, and instructions. Rear set had only one set of shims (black), no paste, and no instructions. Am I missing something?
ATF change
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm getting conflicting advice on the necessity of replacing the screw-on filter. Dealer wants $42.00 for the filter, which is one reason why I hesitate. One web-site regarding diagnosis and maintenance of the 4EAT says that under ordinary circumstances (whatever that means) it is not necessary to change this filter. What is the collective wisdom of this group? TIA.
ATF change
I'm going to drain and refill my 2000 OBW transmission tomorrow with Dexron III. How many quarts should I expect to put in, assuming I don't touch the filter? Any reason to change the filter?
Now my Outback is overheating
J A Blazer replied to Boddi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you use an OEM thermostat? Many stories of non-OEM thermostats not working properly.
