Everything posted by SUBARU3
Ok...I played with the AC today. (105 degrees!!!! Car at idle, shop fan in front of radiator, windows closed). It seems the high pressure cutoff is cutting the AC and then it has to wait for the pressure to come down to cycle back on. The cutoff seems to be 400. After removing some charge, the high side climbs to about 300ish when revved to 2000 rpms......and the low side stay about 30ish. The air is cold in the car at 43 out the vent. It seems to cycle appropriately now, but I will drive it tomorrow in the heat of the day and see. Oh, If I add any charge at all, the high end goes too high. Do I have a marginally failing expansion valve? Shouldn't the low end be a bit higher and the high end be a bit lower.....or is this hell we call "TX...it's a dry heat" causing it? Thanks!! Todd
WOW...so much AC knowledge!! Thanks! I will again check pressures. Does any one know the correct #s? I do know it's not the compressor clutch, as I can jump it to operate with the battery. It's worse when it's "not so hot", such as trying to defog in cooler wet weather. Also seems to cut out for l o n g e r periods when it's really hot. Works best on "medium" days. (high 80s -low 90s) Thermoswitch....is that at the evaporator? Lot's to look at now! Thank you guys so much. I will report back. Todd
OK..... some weirdness going on here. 1995 Legacy 2.2 98K. AC compressor cycles on and off and air gets nicely cold. However, randomly and frequently now, it decides to cycle off and then won't cycle back on again for some time. Car get's hot, windows go down and then it just starts to work OK again.:-\ All fans work fine. The charge seems to be fine. Any ideas? Thanks in advance! Todd
Thanks guys, I appreciate the feedback. Paul....you are a mess!
Anybody have ideas, suggestions, or options to manage a light surface rust covering the bottom of a Gen 1 ? Car is a southern car, so no salt rust, but the car was never undercoated, so after 30 years, there is surface rust present all over the bottom. Again, the car is sold as a rock though. Can this be pressure washed and then sealed? Whats a good product to convert surface rust and seal? Your thoughts? Thanks
Need help with 81 brat struts
SUBARU3 replied to 81 brat's topic in Historic Subaru Forum: 50's thru 70's
The Gen 1 cars 77-79 are often lumped in with the BRATs in databases. The BRATs have "adjustable" struts. The cars do not. However, the complete car strut will fit the BRATs just fine, if you want to go that way. The difference is a VERY small height difference. So: All "complete" struts interchange on all gen one BRATs AND cars. The original Gen one car strut insert is different from the original Gen one BRAT insert. (The whole strut is different). Often times I have found Gen one car struts on BRATs. So in that case, the specified strut insert for the BRAT will not fit. If you see adjustment bolts on the outside side of the strut....it's a BRAT strut. Hope this helps. -
Keep it stock until you are really more familar with it. Engine transplanting is no easy feat and you have a solid engine in there. After all you want to enjoy the car, not have it apart for a year. Check www.car-part.com Have fun!! Todd
Well, the Astro has only 70K on it and is in perfect condition. It gets used all the time for hauling things around and it can also tow if needed. I almost did sell it, but now thankful I didn't. It was my Moms before and just was too big for her. She got the Forester. Believe it or not, it gets nearly the same mpg as the Forester!
Thanks for the good info. Yea, the car never overheated, I just saw the green coolant start dripping from the gasket. It increased in cold weather. If you looked at the headgasket from the bottom on a cold morning, it would be dripping. It stopped after warm up obviously. Yes, the dealership was great and the mechanic there is a Japanese guy ; trained in Japan with Subaru. A great mechanic! If I sell, I will post here. Big decision. Do I need to add this to the stable? LOL I like the space in the Forester! 1995 Impreza FWD 1.8 70K 1995 Impreza AWD 2.2 59K 1995 Legacy AWD 2.2 93K 1978 Subaru wagon Automatic 64K 1979 Subaru wagon 5 speed 88K 1979 Dodge Colt twin stick 64K 1994 Chevrolet Astro 4.3 72K Too many cars! LOL
I ran across some old info. I believe that these shocks may fit the rear of GEN 1 wagons, sedans, coupes and BRATs. Monroe Matics # 33097 ALSO fits: 81-87 Ford Granada 78-83 Ford Fairmont 79-86 Mercury Capri 81 Mercury Cougar 82-86 Mercury Marquis Todd
Need new shocks for gen. 1 wagon
SUBARU3 replied to Whitehog's topic in Historic Subaru Forum: 50's thru 70's
I ran across some old info. I believe that these shocks may fit the rear of GEN 1 wagons, sedans, coupes and BRATs. Monroe Matics # 33097 ALSO fits: 81-87 Ford Granada 78-83 Ford Fairmont 79-86 Mercury Capri 81-81 Mercury Cougar 82-86 Mercury Marquis Todd -
Are you in Muncy PA? I'm interested in the dash and could have my father pick it up. (He's in Jersey Shore). I'm in TX, but I can ship it back when I visit. Thanks! Todd
I was VERY fortunate to have Subaru replace the orginal headgaskets on my mother's 99 Forester last month under warranty. The vehicle had 85K on it. (She drives very little). I noticed the increasing external leak on the drivers side and because I alerted Subaru in the past to the situation.... they covered it. I also had a new rear seal, and separator plate replaced at the same time. Subaru has always been good to me. My question: What is the reliability of this SOHC 2.5 when it has the NEW Subaru headgaskets in it now?? Is it as solid as my 95 2.2s? I know it's noisier! How many miles will these go when compared to the early 2.2s? Mom now has decided to not drive anymore and I'm not sure what to do with this vehicle. It's in GREAT shape and fresh out of the Subaru garage. Thanks, Todd
Big trouble in little wagon MASS LEAKAGE!!!
Got a ton-o-stuff for your car too. Todd -
Hey guys....is there a single, common culprit that causes the gear shifter to rattle when cruising? I know on the Gen 1s it's usually the bushing at the base if the shifter. There are alot of bushings and insulators in the shifter , I just know it's not all of them. Car has 73K 1995 Impreza 2WD 5 speed Thanks, Todd
