Everything posted by SUBARU3
tbreaden (Todd) From ,my research you cannot put the 95 EJ22 in a 99 Forester. At least easily. You run into the complications in engine management and bolting to the trans. I guess it could be done with some tweaking. I still want to do this swap on my 99 Forester of my moms. The 2.5 SOHC still scares me....not as much as the DOHC though. I'm wondering if the bellhousing for the 2.5 will fit on the 1995 EJ22? That would take care of the bolt issue at least!! Todd (yes another Todd) http://www.ultimatesubaru.org/forum/showthread.php?t=61096 http://www.ultimatesubaru.org/forum/showthread.php?t=83537
Rust
SUBARU3 replied to suban00b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Rust bullet is a better product IMHO, I have use both. http://www.rustbullet.com/ Todd -
OK changed the PCV valve and it only has a very short tube going to the crankcase....all the tubing was OK. Still get that puff of smoke. Now I noticed that after a drive, if I sit in the driveway and rev to 2000 rpms or so, it smokes too! Hmm??? Not a ton, but enough to see. I'm doing a compression check next. Car went to Subaru today for headgasket check and it's OK on that front. FYI The car runs 15W50 Mobil 1 I'm not likeing these 2.5s already!! GIMMEE my 2.2s!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Todd
The 81 BRAT is the same body as the 77-80 BRAT. You need a shock that has the threaded rod at the top and the rubber grommet hole at the bottom. You must have been looking at the wrong picture. For that matter the 77-79 2WD car rear shock are the same too. This is weird. Todd
Belt Driven Fan?
SUBARU3 replied to the sucker king's topic in Historic Subaru Forum: 50's thru 70's
The AC system was not installed at the factory. All the cars were "AC ready", with holes in the firewall and the air handler box capable. Of course there was the blue markings on the dash with "AC". The kits were made by Subaru of America "specifically" for the gen 1s. There were also some other kits made by Lone Star. The compressors were Sanden, or Mini Yorks. As for the cooling fan, all AC installs had one. You had to have one for efficient condenser cooling. As for "no AC/belt driven fans", the 4WDs were suppose to have them. But it might be possible that they stopped this with the stage 2s. I do believe every stage 1/ 4WD had that belt driven fan. My stage 2 4WDs had them without AC. Todd -
Belt Driven Fan?
Gen 1 4WDs and Gen 1 automatics ALL came from the factory with the aux cooling/belt driven fan. (or were suppose to). Most have disapeared by now with engine repairs and transplants. After market AC kits installed also had a belt driven fan. No Gen 1 came from the factory with AC. I'm unsure about gen 2 Todd -
77-79(?) orange wagon in Hurst Texas
SUBARU3 replied to gbrand's topic in Historic Subaru Forum: 50's thru 70's
No, it's on the north side of TX. (Near Ft.Worth) Todd -
Sounds like you have the wrong wiper arm, or you have a broken pivot joint. Can you get a pic? Todd
Well, it has a VERY weak suction when the car is running. The hoses are somewhat blocked too. I'm looking through my piles of subaru stuff, I know I have one! Ya know, it's so frustrating to have tons of Subaru crap, but I can NEVER lay my hands on something I know I have, when I want it! Anyone else have that problem?? I can SEE that PVC valve in my head...I think it walked off! Todd
Took a look tonight. It's not a 4WD, because it has shocks on the bumpers. I bet it's not an automatic either. (I could not see inside at the shifter). It looks like a southern car...no rust. But the bottom of the right, rear quarter has the typical " full of dirt and leafs rust". Seems pretty straight. It was inside, so I assume it's someone that works there. I'll call tomorrow and be inquisitive!! (and plant some seeds). Todd -
OK, a 1999 SOHC EJ25 81K .......This motor has a puff of blue smoke after a warm start. (Vehicle previously run and then shut off for a short duration). No smoke while running/driving and no smoke from a COLD start. (Just that damn piston slap)!! New mobil one 15W50/correct level. Runs/drives fine. No oil usage to speak of. Have noticed a blackened tailpipe inside surface though. Valve seals already! Can these be replaced with heads on car/engine in car? Thanks you New gen gods! Todd
I'll have to check it out! (Man you are close to me....Euless. We should exchange #s and meet sometime). subaru3@aol.com Todd -
You guys are GREAT! I really appreciate this dialog.......alot! I don't know what I would do without this board!!! So, although it may appear that the 95 2.2 is doable, it would not be perfect because of the bolts and the wiring/management differences. So it sounds like the 1999/ 2.2, (phase 2 SOHC), would be the best overall 2.2 to use?? That engine IS plug and play? Todd
1977 1600 wagon found
SUBARU3 replied to coylethebarbarian's topic in Historic Subaru Forum: 50's thru 70's
Stage 1 or Stgae 2 ? Some 77s were Stage 2. Todd
