Everything posted by SUBARU3
Kinda....I just don't want it sucking air in my new engine!
Paul.....you asked a master tech? Todd
MAJOR brake problem... (after install)
SUBARU3 replied to Kostamojen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did you turn the piston, so to line the groove up in the piston straight across?????? If not , the "nub" on the inner brake pad will not be recessed into it and that will force a new pad too tightly against the rotor...... AND with new rotors too, you can't afford this. Todd -
I had to replace the oil pick up tube, (bent), in an EA 71 that I am building up. How can I be sure that the tube is sealed well in the block? I know it was difficult to get the old one out, (very tight) I have a new o ring on the new tube, but I'm still afraid that it might not seal as well as the original. Ideas?
Yes. I can have the stripes made fresh. The pattern is on the cutter at the shop. There were a few variations on that stripe. color differences some of the colored stripes ran to the front of the fender. some of the colored stripes ran to the front edge of the door and then tipped up. some stripes ended like Mary's BRAT and curved up, just behind the door. There were lot's of variations in a lot of things in the Gen1s. That's just Gen 1! Todd
These are the "reproduction" gen 1 BRAT stripes I have sourced. Complete choice of colors. High preformance, commercial grade vinyl.
79 4wd GL Wagon - What's it worth?
SUBARU3 replied to korimako's topic in Historic Subaru Forum: 50's thru 70's
Boy....all the Gen 1 lovers out in force!! :cool: -
CHEAP '78 Wagon on E BAY !!
SUBARU3 replied to Esteban32696's topic in Historic Subaru Forum: 50's thru 70's
Yea...those Florida cars rust!!!!!!!!!!!!! -
4EAT question
SUBARU3 replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Well, it was not the resistor. I'm going to try a fluid change next. Todd -
4EAT question
The car is a 95 /awd It does it all the time cold or hot. However sometimes it seems OK, but generally, it consistently happens. Yes, I have changed the fluid at frequent intervals. It does seem like it started AFTER a fluid change. Fluid quality issue maybe?? I'l also try that resistor. -
What would cause "hunting" between 2nd-3rd shift. The trans is fine otherwise. 80K AWD. If you floor it, it shifts through all gears fine. Under normal acceleration, it shifts 1-2 OK and then 2-3 feels like it goes to 4th for a sec and then back to 3rd. Then shifts to 4th normally as speed increases. Torque converter lock up is ok too. Downshifts are fine also. Ideas? Thanks, Todd
*...Just picked up a 79 Brat...Question?*
SUBARU3 replied to bakerman1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All axles and all hubs interchange between ALL 77-81 BRATs and ALL 77-79 subaru cars. (2 or 4 wheel drive) I think the 74-76 will work too. The BRAT "originally" had thicker CV shafts. No big deal though, as most axles are all mixed up now anyway. todd -
77 From Hamilton City
SUBARU3 replied to RenaissanceMan's topic in Historic Subaru Forum: 50's thru 70's
Nice! I bet it's glad to have a good home!!! Keep us posted on the progress! Todd -
GREAT!!!! I can't wait to see it!!!!!!!!!!!!!!!!!!!! Todd -
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7997072870&sspagename=ADME%3AB%3AAAQ%3AUS%3A1#ebayphotohosting The guy selling asked me, I don't know. I DO know it's no Gen 1. Todd
