Everything posted by porcupine73
Lousy gas mileage
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$86 wow. That's more than OEM. 22060AA070 Forester 1999-2002 knock sensor msrp $97. Can be had for $78 from Subaru dealers who sell parts online. There might be other cheaper aftermarket alternatives if that is the desired route.
Weird (loud) harmonic noise from engine
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure all the hoses on the bottom of the intake tubing is reconnected? There are a number of hoses down there that come off somewhat easily if messing with the air filter or maf, plus they're on the bottom of the intake tube so it's not immediately noticeable if one came off.
Lousy gas mileage
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXP0141 is for the rear o2 sensor. Did you unhook any connectors or anything? DTC P0141: REAR OXYGEN SENSOR HEATER CIRCUIT MALFUNCTION (RO2H)
134-a in R12 system?
porcupine73 replied to Nate007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow with R-12? Sweet. Did they have a secret stash? I thought that stuff hasn't been available for years.
Lousy gas mileage
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou don't have to take the throttle body or anything off to get the knock sensor out. Yes just use a wobbler extension and maybe flex joint if needed. Not sure about the impreza, but on my legacies I can get my hand down in there by reaching in to the side of and below the throttle cables. For the front o2 sensor, really oem is the way to go. Order it from a Subaru dealer who sells parts online to save $ over going to the local dealer (unless they'll price match or happen to wholesale parts). Some earlier Subaru's the o2 sensors were Bosch, some are Denso. The way to get the right one with the connector for your vehicle is to get it from Subaru. Even though the parts store sensor might be made by the same manufacturer, it may not be the same specs. If you get a bosch generic, you'll have to cut the connector off your old sensor and solder the wires onto the new sensor. Also physically inspecting the o2 sensor isn't going to tell you a whole lot.
Lift Kit - progress report
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice very nice!
Love my Subaru 96 Outback!
porcupine73 replied to RapidFire's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh ok cool! Did you use king springs? Here in the states if we want king springs we either have to get them air shipped or get them from renick. Wow that XT6 looks hott!
Need Fav: A Pic of 96ish OBW dash lights...dead alt no light?
porcupine73 replied to DrKrazy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood info, I didn't know that about the battery light. That's a good troubleshooting tip. So the alternator field current must be pretty low then? For some reason I thought the field current was in the amps range maybe as much as 10A?
porcupine73 replied to RapidFire's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell that's great! How many miles? Is it AT or MT? Do you have some pics?
93 Imp AC question
porcupine73 replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome people just switch over to 134a from 12 and don't seem to have problems with it. Here's the info on the conversion kits in case it's of interest. Subaru Air Conditioning Retrofit Procedures from EndWrench R-12 to R-134a Air Conditioning Retrofit Kits and Procedures from EndWrench
Torque Value
porcupine73 replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK. The oil in the spark plug holes is those seals. Four of these should be in your kit. When I put the valve covers back on, I got all the bolts in first, then eased up the torque in a couple of rounds. It takes a little bit to compress the new spark plug hole seals down. The valve cover bolt holes can handle a little overtorque. I just realized I looked at the wrong torque when I did mine and went to 7.6 ft*lb(f). One did start to strip so that is probably about the limit.
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhaha yes having food in the house for such emergencies is good! Ohh the possibilities..... :cool:
porcupine73 replied to Nate007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight on, also the PAG oil for 134a is not compatible with the mineral oil for R12. Check out the Subaru Air Conditioning Retrofit Procedures from EndWrench Check out the R-12 to R-134a Air Conditioning Retrofit Kits and Procedures from EndWrench
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSweet....are you going to go with super swampers?
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm...that INT999013 kit does have lots of parts! Summit has that part number too but I think Summit's description is wrong: they list it as just eccentric bolts. Does he look meaner?zzz
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got some of these camber bolts from Summit but haven't used them yet. They're Ingalls IEC-I-81260 14mm, supposed to be good for +/- 2 degrees of camber adjustment (I think that's if you use their eccentric bolts in both the upper and lower hole). edit: It seems like these would also work to make the rear camber adjustable, if your strut/shock is the style that uses bolts, not that double wishbone thing on newer models.
multiple 12 V adapters
porcupine73 replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've run a 1 to 2 adapter. There's no risk of overloading the vehicle's outlet since that is fused. The three devices you mentioned are not power hogs anyway so it shouldn't be an issue. Also there is a Subaru accessory you can get that I think gives you two more outlets. I think maybe nipper has one installed? It kind of mounts where the ashtray is I think
Torque Value
porcupine73 replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat engine? For '96 2.2L it is 3.6 +/- 0.7 ft*lb(f). Or 43.2 inch*lb(f).
Lousy gas mileage
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis one?
Lousy gas mileage
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeafoam in the gas can help clean up the fuel system and clean out the combustion chambers. Sucking seafoam in through a vacuum line on the top of the intake manifold will help clean out more. Also with engine off blocking throttle wide open and using some throttle body cleaner and soft brush can clean up the butterfly. This all helps reduce intake resistance to airflow and increase efficiency.
Splash guard replacement
porcupine73 replied to RBGERSON's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know if '99 Outback had the full underdoor. The parts list shows just the little left and right covers you mentioned. If you check out this link, then click on the item description, the full underdoor would be 'item A'. But since no item A is listed for '99 Outback I don't think it came with one. But if you look at this link for an '00 Outback you'll see what it looks like with part #. Probably won't fit a '99 though as '00 was the five year design.
Lousy gas mileage
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe the intake and throttle are all gummed and coked up. Maybe you can give it a good seafoaming to clean things up in there.
porcupine73 replied to RBGERSON's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNearly all Subaru's have the two little plastic things over the bottom of the fender openings. Not all Subaru's come with the plastic underdoor which covers the engine bay. If you want to replace it, a salvage yard might be a good place to look. Or this can be a great excuse to get a skid plate!
Lousy gas mileage
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. If you replace the O2 sensor, go with OEM for the front. The rear can be aftermarket. I would replace the front only. The rear is purely for detecting catalyst efficiency and unless you're getting P0420 or something I wouldn't mess with the rear. In NY, it depends whether you had to pass the high enhanced emissions (New York City and outlying areas) test or just the enhanced (most of the rest of the state). The enhanced does not even sniff test the exhaust; it's purely an ODBII test. As we can see in this thread. there are lots of factors that can impact fuel mileage. Also if your knock sensor isn't in prime condition it could be giving you reduced economy. And it is common on that year model to need to replace it. You might also try switching brands of gasoline.
Same shocks/struts on 98 Impreza RS as 98 Impreza OSB?
porcupine73 replied to Infidel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only difference is probably the ABS version have a little welded on mount/clip thing for the ABS sensor wire to bolt into. So you could use the ABS struts on non-abs vehicle and just not use the mount point. But to use the non-ABS struts on an ABS vehicle you'd need a way to support the ABS sensor wire.
