Everything posted by porcupine73
All-Wheel Drive Legacy issue
porcupine73 replied to Lucenut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGrounding terminal # 5 of connector B82 a 6 pole black, right side of steering column. Trouble codes will be displayed through AT Temp light. There are 14 possible trouble codes communicated from the TCU.
porcupine73 replied to Lucenut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds good. You may have a failed duty c solenoid then (considering the AT temp light flashing). I'll look up the method to get it to flash out the code.
porcupine73 replied to Lucenut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi and welcome! When you had the tires replaced, did you get all four new tires, or just two new on the front or rear? It sounds like your soob has what is often called 'torque bind'. Do you notice the AT temp light flashing at all on startup? My typical torque bind spiel For auto trans, if the AT temp light flashes 16 times on startup, then the TCU has detected some issue. Read the code(s); it may be a failed duty c solenoid (which can cause the binding). All tires should be same brand and nominal size and tire pressure should be correct. Measure the circumference of all four tires (wheel will have to be lifted off the ground to do it). They must all match within 1/4" circumference. You will not be able to visually see this much difference so the tire circumferences must be measured. For automatic transmission: For auto trans, flush ATF using a new quality fluid. Sometimes if the torque bind isn't too bad or just started, fresh ATF can help. Sometimes it takes multiple flushes over a period of time. For auto trans, this one is a little controversial, but many people do it with success: put in a few ounces of differential limited slip additive (NOT gear oil - just the limited slip additive). If this helps, people often say they have to add a few ounces periodically. This was mentioned in an early 90's issue of Subaru TIPS newsletter. For auto trans, you can try installing the FWD (front wheel drive) fuse to see if it makes any difference. If the above did not help, then you may need to have the AWD transfer clutch replaced or at least serviced. For manual transmission of that era, there isn't much that can be done short of replacing the AWD viscous coupling in the gearbox. Other torque bind causes: improper towing (i.e. only two wheels off the ground on a dolly), running on a soft/flat tire for a period of time, getting a flat tire and replacing just that one tire while the others are worn, replacing just the front or rear tires, etc.
Strange email
porcupine73 replied to korrupt66's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNeed more specifics, mainly what were the code numbers read? What dash lights stayed on? Elaborate on shifting wrong?
knock sensor?
porcupine73 replied to ashleem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have some basic sockets and good extensions it is easy to replace. The vehicle may suffer lack of power and reduced fuel economy if it has the CEL for the knock sensor. Also the code just means an electrical issue has been detected in the knock sensor circuit - it doesn't necessarily mean the knock sensor itself is bad (though that is typically the culprit).
Long haul trip @ 100,000 miles - maintenance suggestions
porcupine73 replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX? Coolant flush and cooling system inspection Yes at least check the hoses. If you replace the hoses, the Subaru OEM hoses are not very expensive and are top quality. Since you had the water pump replaced, the coolant was at least drained then. Don't know whether new coolant was put in or they reused what was drained out. Note SUBARU recommends against coolant flushing machines. ? Fuel filter Looks like it was done a few thousand miles ago so should be good? ? Air filter (need to check) Also cheap and easy to replace so if you don't know when it was done last go for it. ? Transmission/gear oil checks Yes I would replace the diff gear oils and the ATF if you don't know when done last....if ever. ? Axle shaft checks Easy to check the boots visually. ? Wheel bearing lubrication check (huh?) Yes I've seen this one on the list too. You have to extract the axle from the hub and maybe pull the hub to check it though, which is a bit of a pain just for a 'check'. http://www.subaru.com/owners/schedules/index.jsp?navid=SCHEDULE_2003 Also, spark plugs are 30k mile replacement interval, so those are probably due for replacement again now.
1998 is the price to outragous
porcupine73 replied to xr2guy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat should be a solid vehicle provided it has been maintained properly. The price does seem a bit high even being in soob country. If it has calif. emissions, the timing belt interval is 105k miles or 105 months (so if it hasn't been changed yet it is due to be replaced because of time like nipper said). If it is not calif. emissiosn, the interval is 60k miles or 60 months, in which case it is overdue on both accounts if it hasn't been replaced yet. That would be an interference 2.2L also so if the belt breaks bent valves, etc.
QUICK ADVICE PLEASE - Looking at an outback
porcupine73 replied to cobcob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belt is overdue for replacement, if not done already.
Odd RPM drop just after starting
porcupine73 replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour setup (ej25 sohc phase ii) doesn't have the ton of little hoses connecting to the bottom of the air intake snorkus like earlier soobs did. There are only the two breather hoses from the valve covers, and those connect to the bottom of the airbox itself, the part that attaches to the throttle body (which you wouldn't disturb even changing the air filter). That other boot you describe does sound like the inner tie rod end boot. Do it look like this?
94 Legacy won't start
porcupine73 replied to rigfennid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEy ya go mate! I've a '94 too. One test might be put 'er in neutral set parking brake, if assistant available maybe have clutch held in, then put the key in run. Then using a jumper, apply +12V to the starter solenoid. If she cranks, the starter isn't the problem at least. If it doesn't crank, the starter may be having issues.
P0302-cylinder-2-misfire-detected
porcupine73 replied to 2X2KOB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmmm...not sure, does this pic answer the question? 2000 Outback - spark plug tubes penetrate valve cover 96 Legacy 2.2L - spark plug tubes just above the top of the picture.
porcupine73 replied to 2X2KOB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI went with the Subaru OEM plug wire set SOA430Q119 for my '00obw, it was $37. I had no issues with any wires not being long enough? Note that if you apply antisieze to the spark plug threads, I have seen in the soob service manual it says to reduce torque by 1/3. Replacing plugs on the phase II 2.5L sohc's is not that difficult. At least not compared to some of the other vehicles with transverse mount engines on the road today! Good luck with those. That's why they have to say 100,000 mile plug intervals, so the warranty is up when they need to be changed, since some need engine rocking to get at them all.
Tranny shifter position on the dash?
porcupine73 replied to Bigbusa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhaha no doubt the victim of some Six Sigma / Lean / Kaizen project or some combination thereof!!!!!
Exhaust Flex Connection Leaking
porcupine73 replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhehe...no problem. Sorry I didn't have a chance to get any dimensional measurements though... :-p
98 legacy brake question
porcupine73 replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, one question would be....was the 'whoops' more of a... Oh man that is really going to leave a scratch in my paint...or Oh man I hope no one notices this gaping hole in the concrete block of this grocery store....
porcupine73 replied to 2X2KOB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn that era one reason Subaru recommended shorter plug change intervals was to help prevent spark plugs from siezing in the cylinder head, which is/was somewhat common on vehicles saying 'dont worry dude, plugs good for 100,000 miles..oh by the way you'll be out of warranty when you need to change them.'
porcupine73 replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAhhhhh ok now I get it So did you drop a TT in there yet?
porcupine73 replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhehe..hmm, ok, not sure exactly what you mean. This is a US spec/LHD '96 legacy brighton? Here's a nice blurry pic of the whole underhood.....
Free Delta Camshafts??? WTF ?
porcupine73 replied to Deltacam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhehe yes that would make a nice roadtrip from Buffalo NY to Tacoma!. There was a great write up about Delta Cams in a recent issue of Subiesport or Sport Compact Car. If I can find it maybe I'll scan it in and post it, I learned a lot!
porcupine73 replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm..not sure about the flush part. I've only had this issue on one soob, my '00obw. I had to use an air chisel to get all the residue off. Then I wire brushed thoroughly, then applied copius amounts of nickel antisieze, reassembled and it seemed for sure like it would still leak but so far it hasn't.
My 2000 Out[boat] wagon needs some freshening up!
Hm yes not sure, I know from monitoring the scangauge, in the summer in '00obw without the intake snorkus attached, she's pulling 130-150F intake air temp. With the snorkus on it goes down to maybe 90-100F or so. Typically on my soobs I run without the snorkus in the winter, and with in the summer.
porcupine73 replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure the surface where the donut goes on was clean, and the mating surface where the exhaust piece attaches was clean? By clean I mean free of foreign material such as pieces of the old donut, etc. Otherwise it won't seal.
Ah I don't know. I've heard about drilling holes in the airbox too. But then it's going to be sucking in warm/hot air from the engine compartment rather than cooler air from the front. If you want to really hear your boxer, run some flex tube into the passenger wheel well. The hole is already there. I did it as a test, and man you could really hear the engine pretty loud. Unfortunately intake noise isn't the prettiest sound, it sounded more like a ricer with the farty muffler. When it shifted made a neat sound though. LIke this:
Used Subie Owners: Disgusting Left-Overs From Previous Owners
haha wow that's pretty bad. I don't have any really odd stories; the only soob I bought from a private owner so far is the '94, it was a college kid. There was all kinds of stuff in the vehicle he left, change, receipts, maps, a bar-mitsvah cap, birthday cards, student id, parking permit, stuff like that. So I contacted him and offered to mail it to him, which is what I did. It was all under the seats and in hidden places. Oh also something spilled in the rear, like battery acid or something, that has really rotted out the left rear part of the cargo carpeting, no idea what it is though.
Dude for the engine check out the deltacams offer - it's a current thread, and it looks like you are a lot closer than I am! http://www.ultimatesubaru.org/forum/showthread.php?t=85745 I replaced my '00 houseboat struts with GR-2's, replaced the sway bushings and end links, and fitted scorpion lift springs last year. That firmed the ride up quite a bit. The butt end likes to sway a little still, I think it's the mulilink suspension since my earlier soobs don't do that.
