Everything posted by 86BRATMAN
EA81 tranny matchin up to EA82 Engine
it will bolt 100% guarantee on that, a few years back me and dad put an ea81 into an ea82 wagon so we could sell it and get it out of the car lot(nickname for our driveway), gave no problems at all,
EJ22 Brat Swap, couple questions for those who have done it
alright, now for my next question, since i've got the car, the wheels and all that fun junk, how hard is it to fit the 5 lug on the back of a brat and keep my stock suspension setup
Just bought an 84 Turbo BRAT
either one of you guys please post a pic of the carpet, the wife has to see the stuff before i can actually buy it, lol
it's been a long day, i pulled the motor and trans out of both the brat and the donor wagon today, i measured both of the transmissions, the ej is about 6 inches shorter than the d/r ea, so wouldn't i be semi correct in thinking that would be close to the distance needed, or am i just trying to think to late at night
looks like i'll be callin up my buddy at the parts store and see if i can sneak out the back door with an axle or two, lol there is a shop about 30 miles away that does custom driveshafts so i'll probably go talk to them about that, any rough idea of how much different the length will need to be, as for the linkage i figured as much, i'll look into that after i get the trans installed,
EA81 performance, what do you guys reakon about these mods?
thanks for the info, i was going by my mechanic and his things he told dad a few years back when i had my white brat, we swapped carbs and distributors from my brother's wrecked car and it seemed to make a good difference, but my parts could have just been in bad shape
'95 EJ22 Into '83 Brat
Gary, here we are about two months later man, how's it coming?
using the ej setup, i've got pretty well everything in a donor car i gave 300 for, just tryin to straighten out the small stuff
Legacy suspension/brakes on an Impreza?
i would concur based on my mom's 98 legacy L, only suby owners i know of that don't complain about crap for brakes are the 02 up impreza crowd, twin piston calipers and all that fun stuff, these are also found on the 91-94 legacy turbo
EJ swap; axle inquiery
how much longer is the ea82 axle than the ea81, i'm contemplating the use of a moddified ea82 lower control arm as illustrated elsewhere on the board to remove the camber that the older cars have, does it sound remotely possible to use an ea82 axle for the ej swap into the brat
Bell housing swap for an 4eat?
i'm pulling the ej out of my donor tomorrow and i have already pulled to ea from the brat, i'll take a look at them, and try to post some pictures
interesting, i'll have to get an axl from the advance and test it out, do you know anything about the driveshaft length i'll be lookin at
i've got everything i need for the swap, 90 ls wagon 5spd awd as the donor,the labor and wiring are not my concerns, what i'm wondering is will the ej motor mounts and trans crossmember line up properly with the ea81's or will i have to drill and or fabricate new ones, and for the drive shaft will the brat shaft work or will i need to have the legacy's cut to fit in the shorter wheel base, and will my existing ea81 axles fit the splines on the ej trans and rear end? also inthe future i'm going to upgrade the motor to either an EJ22T or an EJ20T and run more than stock boost, how much power can the cable EJ transmissions hold without failing
URGENT!! i need help tonight! 86 EA82
have you checked for voltage going into the coil itself
heres a method i've seen talked about and considered if i were to keep the ea81 in my brat.... step 1. pistons) ea71 1600 series engines us the same bore size as the ea81, they have a bigger compression area, i'm not sure how much bigger or anything but i know putting these in the ea81 would raise compression, the ea71 have a comp ratio of 9.0:1 comprared the the ea81's 8.7:1, they use the same wrist pin height, so a swap of this wouldn't be too hard for someone with the proper tools and knowledge of how the motor comes apart step 2, cam) the small aircraft industry uses the ea81 for a lot of applications, there are many companies that offer cam regrinds of your stock cam, a list of some of these can be found on www.subarubrat.com, depending on what grind you go with(how much material they remove) you would need to have your heads shaved by the same amount so that your stock push rods would be the right length... one company for instance offers a regrind that removes .040" from the cam to make the new lobes, your heads would need to be decked the same amount step 3, heads) simple, have them decked, it'll further raise compression, also a port job could be done at the same time, but keep in mind the power band you want to operate in, the larger the port job the higher in the band your power curve is moved step 4, feed it) take into consideration all that you have already done here and either re jet your existing carb or look around for an upgrade... if you can find a 2wd ea81 laying around somewhere that carb caomes stock with better jetting than the 4wd does, also get the distributor from said 2wd car as they have a better advance curve built into them sorry its a little lengthy, hope it makes some sense
Brat Jump Seat Removal?
how much you think you would want, i'm about two and a half hours away, i'll come help yank 'em
congrats on the brat, i now envy you, you could however make it up to me buy selling me the carpet, the strip that holds it down and possibly the rear bumper when you remove them as you plan,
Rust! Break it to me gently.
it all comes down to how much time and effort you want to put into it, and how much your love the vehicle, a guy about a mile down the road has done a miraculous restore on an 83 brat, rear frame was rusted out so bad that the driveshaft was banging suspension, he drive it every day now, he's the only reason i haven't sent my current brat to the crusher
what are your plans for the jump seats and mount bracket when you get them removed
e.c.u. rewrite
86BRATMAN replied to legacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXteagues auto sells one, http://www.boxer4racing.com, and i've seen a few others around but i can't remeber where
strut tower braces
86BRATMAN replied to capewaveride's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've had a little experiance with strut braces and they seem to do a lot with the vehicles i've had them on, 97 eclipse rs. and a 94 integra gsr, which had a factory brace on it, but i could tell a great difference when i put on the aftermarket piece
Dude, can we put something to rest...How do you pronounce...
86BRATMAN replied to lastchance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've always called it "Tine"
simple ecu question
86BRATMAN replied to 86BRATMAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Would you pay $31,000 on a new car...
86BRATMAN replied to duane b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$31,000!!!!! you got a hella deal, they are wanting $35 K for one at my local lot, but they are the only subie dealer for 80 miles in any direction, but even at 35k i'd have one in a heartbeat if i could afford it, and besides i've lost my lisence before, its not so bad.
simple ecu question
I just bought a 95 legacy wagon brighton model with a ej22 5mt. It had a bad bearing, but i'm swapping in a 91 motor, with the heads shaved .030" and i'm having a set of phase II 2.2l valves installed as we speak, now my question is will an ecu from a 2.5GT 5mt plug into my harness and run my engine. the reason i'm wanting this is because of the higher rev-limiter and higher speed governor. If it won't work do you have any sugestions. Thanks. oh yeah check out my sound domain page at http://www.sounddomain.com/memberpage/525711
