mrdeep2001
Everything posted by mrdeep2001
  1. man i need a new driver side door and hood, but thats too far for me...
  2. careful when you pull the hoses off the fuel filter. I pulled the fuse and let it run till it was done, but there was still gas in the lines that sprayed on my face when removing the lines. So you may want to wear some goggles as well.
  3. Having a little trouble finding the neutral switch on my tranny. Is it viewable from the top down, or should I get underneath the car? Any color/wire info?
  4. I was just reading an old post... Is code 5 coming up b/c I have a manual transmission?
  5. 92 Loyale, FWD, manual My car recently started to shut off while idling. When you start the car, it will start, and after a few seconds die down. It will stay running if you give gas to compensate. Also when driving, it sometimes dies when you put it in neutral. NOTE: It was doing the same thing this past winter, but it eventually went away... Checked codes: No connectors: Code 5??? White Connectors: Code 11--11 Crank Angle Sensor or Circuit Code 13--13 Crank Angle Sensor or Circuit Checked codes for 1988 and Later Models With Single-Point Fuel Injection http://www.ultimatesubaru.org/forum/showthread.php?t=49918
  6. regarding the pivot, do you mean the part where the end of the clutch cable goes through? and also which bushings should i be looking at?
  7. Hey guys, A fuse which i think is for my A/C compressor keeps blowing. W/o fuse, air wont be cold. Pop a new fuse in the fuse box, and it may work for a few mins and it blows again. Any input on past problems you've had, or things to check, such as wires to trace?
  8. Whenever I push my clutch pedal in, i hear a squeaking noise, similar to the noise i heard when my clutch cable was on its way out. I replaced the cable less than 6 mos. ago with an OEM cable from Subaru. Anyone have ideas? car is a '92 Subaru Loyale FWD non-turbo
  9. ive never heard of this....what exactly do you do with the egg?
  10. what does it mean to have your tires "siped"?
  11. if i am able to rescue this from the yard, would anyone be interested in getting it? I have no idea how much the junkyard would charge me tho....
  12. Ok, I'll do that, probably wont have time till friday tho. But then I can take some pics of my new shift knob!
  13. Yea I may go pick that up, where is it?
  14. hey you wanna fly up to philadelphia from honduras and work on my car? then after that Ill fly down there with you and we'll party it up? :cool: haha alright electrical huh? how do I see if a fusbile link is good? I remember reading about them on here before and it is difficult to tell.
  15. GO GET IT BACK!!! I need a new driver side door
  16. alright MAF sensor readings=good gave her a tuneup: plugs, plug wires, distributor cap and rotor, pcv valve, air filter, oil filter, fuel filter after all that my car was running better for a week or two, but now its back to crap. Yesterday, I also seafoamed her, dont know if it didnt anything, but lots of smoke! P.S. I was getting an intermittent O2 sensor code from my ecu. It would come on for a bit, go away, come back, go away. I havent seen it for a few days now tho. How do I go about cleaning my IAC?
  17. depending on whether i pick up another car or not, rear disc and 5 lug swaps may be in my future...
  18. 5 lug swappin isnt over, just gotta figure out a new way to do it!
  19. guys ur shift knobs look awesome! cant wait to get rid of my stock one.
  20. its 2WD and I am doin this for a number of reasons: 1. I will be cutting down my shifter a few inches so I'll need another knob, or need to rethread it. 2. I like customizing my car. 3. b/c I can and this will be the only time i have access to free metal and machines.
  21. Should I go with more of a long cylinder-type shifter, or short cylinder with a rounded top?
  22. LOL I love that movie! but yea thats one thing I was worried about with that...but I'll be gettin one made either way b/c it's free and probably the only time I'll ever have access to all of these machines and people who know how to use them.
