Everything posted by fshnidiot
86 xt turbo pics
I'll be hooked up over there real soon. The previous owner just had the motor resealed in the shop and had them replace all the hoses, clamps,radiator, water pump,timing belt,etc just to be safe as all those parts were 20 years old and due for replacement. Right now that motor is about as tight as they come. I had to replace my 87 Nissan Sentra DD with something since the struts & front brakes are TOAST and I wanted a subie turbo 5 speed w/4wd so I'm completely happy. I've already got a new windshield lined up for $249 installed so once that's in I can dispose of the cup 'o noodle car and have 2 Brats and an XT to chose from. Frank (fshnidiot)
86 xt turbo pics
- 86 xt turbo pics
Merry Christmas to all!!!! And Merry Christmas to ME!! Here's my new 86XT Turbo I just brought home for Christmas. Everythings there, and it all works including the adjustable suspension and digital dash. Only 108,XXX miles. All it needs is a new windshield. Not too bad for $1000 cash. Runs and drives like a dream!!! I found it on Bellingham Craigslist, I don't know how all you guys missed it, but I'm glad you did. :banana: Frank (fshnidiot)- Documented: The 1970 FF-1 Project car...
Looking good!!!! Is that my old manifold all cleaned up?? That baby's gonna rock with that Weber on it!!! Frank (fshnidiot)- it's been asked, AND answered, but I CAN'T FIND IT!
I have a gen 1 tall rollbar I'm going to put into my 82 Brat. It looks like I'll have to drill new holes in the plate to get it to bolt into the bed behind the cab and the legs that go to the fenderwells will need modification/shortening too. I might just go without them. Other than that it should be an easy fit. Frank (fshnidiot)- To Weber or not to Weber?
I just installed mine in my 82 Brat. All the vacuum hoses can go except for 3 that you need. #1 vacuum hose from the manifold to the Brake booster. #2 Vacuum hose from the manifold to the heater controls. (check where it goes through the firewall on the passengers side) #3 Vacuum advance from the carb to the distributor. I removed the vacuum canister and all the extra hoses and connected all 4 of the large hoses from the valve covers and the air induction system together and routed them to a seperate breather/air filter. The PCV valve hose goes into the aircleaner assembly. I also removed the EGR system and capped it off with a small plate. It's nice and clean with few hoses and has a very noticeable increase in power. I haven't ran it enough yet to get a good idea of the gas mileage but it doesn't seem like it's burning any more than before. If you can find someone close by with 1 already installed looking at their setup will help alot. (I did alot of research at WCSS9 before I put mine in) If I'm wrong about something or missed something someone else please chime in and correct me but that is what has worked for me. Hope that helps, Frank (fshnidiot)- 83GL Shifter Bushing/Linkage progress & question - HELP!
Good to hear. Isn't it nice to be able to use reverse again!! Congrats!!! Frank (fshnidiot)- 83GL Shifter Bushing/Linkage progress & question - HELP!
I just finished mine about a week ago. I used the bolt from the shifter in my 84 2wd parts car that holds it to the shaft. After hacksawing my way past the hole I added a lock washer on each side and bolted it up snug so it squeezes tight on the shaft from the tranny. The bolt was a perfect fit so I didn't need to drill out the hole. It works sooooooooo much better it's not even funny. I can grab reverse with 1 hand instead of using 2 and wrestling with it. Hope that helps! Frank (fshnidiot)- The WCSS 9 Experience Thread
Sorry I missed you too, having my sidekick Odie with me kept me pretty busy going from bush to bush all day. He can't pass a tree or another dog without stopping. Send me a PM and we'll get the parts figured out. I wish I would have gone up with the others when they went up into the trails, I'd have crossed paths with you for sure then. I got to explore for a few after the awards and that place is AWESOME!!!! Good to hear you made it home safely, I can always look foward to meeting you at next years show!! Frank (fshnidiot)- Great Time at WCSS#9 ----Thanks
Thanks to everyone involved in putting on that show!!!!! That was a blast!!! How many days left till next year and where's it gonna be at? BTW the trails in there are awesome! I had the place to myself after the awards and spent an hour up there havin' a blast. :burnout: I'll definately go back there again. WCSS#10 or bust!!!!! Fshnidiot- shifter slop repair question?????
It's all pretty simple once you get that darn pin out. I agree on the hole on the outer sleeve being the culprit, mine was oval shaped as well. The improvement was worth every drop of blood and bruised knuckle though. Frank (fshnidiot)- shifter slop repair question?????
I lost some blood but I managed to get it out. Did the sloppy shifter mod and put it back in in the dark, but it shifts soooo much better. Thanks for the offer on the bushings but I've already ordered the 1 piece on the end of the shifter shaft that had completely disintegrated to dust.I can grab reverse without using 2 hands to do it so I'm doin the banana dance!!!!! :banana: :banana: Thanks, Frank (fshnidiot)- EA81 Shifter bushing help.
:banana: Much better!!!!!!! Now if my thumb will stop bleeding from the hacksaw slipping.... Fshnidiot- EA81 Shifter bushing help.
I already have that at the top of my list for both my Brats. That was planned before I got either one but for now I'm in the middle of hacksawing that piece of #%$#$%@! so I can clamp it up and go. I thought the pin in the halfshaft was a pain. Yikes!!!!! I finally busted it loose with a 6" long 1/4" extension. After an hour or so of hitting my hands and everything else in range but the punch I was using. Well, break's over,back to the hacksaw... fshnidiotzzz- shifter slop repair question?????
I'm trying to get the sleeve that holds the shifter off the shift selection shaft on the tranny.I've got the cotter pin out but I can't figure out which direction the pin gets driven out from, up top or down below. Where's my BFH when I need it!? It's a 4 speed dr in an 81 Brat. Any suggestions? Frank (fshnidiot)- EA81 Shifter bushing help.
OK, so which direction do you drive the pin out of the sleeve that sits on the tranny shift shaft, from up top or down below? It's so sloppy loose I can't get it to hold still in the right position from either side. It's a 4speed dr in an 81 Brat. Thanks for any tips, Frank (fshnidiot)- EA81 Shifter bushing help.
I'm in the middle of the same thought process and they're completely different. The 5 speed 2wd shifter sits up top on a plate and the 4 speed shifter sits along the drivers side. I'll bet you have the same worn out pin he mentioned, I certanly just found out I do. Off to the manual to reread the shifter slop info.... Frank (fshnidiot)- Lynnwood PAP update
Sweet!!! I'm headin' for Lynnwood..... Frank (fshnidiot) Thanks for the update!!!!!- few pics of my 81 Brat
I've got 'em (2 full sets)but it rides sooooooo much better on the 14" peugeot rims and I like the added ride height with the larger tires. They might get painted and go back on when I do my custom paint scheme in a few months but I'm happy with it for now. Frank (fshnidiot)- Looking for Subaru advice in Seattle...
It's still there!!! :banana: PM with info and phone # sent.- Looking for Subaru advice in Seattle...
I'll go for a drive and check. If it's still there I'll get the phone # and get back to you in about 1/2 hr. Glad to be of help, I wish I had it when I was looking. Frank (fshnidiot)- Looking for Subaru advice in Seattle...
There's a mid 80's (85-87?) Brat I saw for sale up here in Arlington the other day. Body needs work and some paint, but it had the cleanest, brand new wagon wheel rims I've ever seen :cool: with chrome hubs. I think he wanted $1950 obo. If your interested and it's still there, I can check on it and get you more info. Keep an eye daily on Craigslist, you never know what'll show up next. Good luck on your quest, Frank (fshnidiot)- few pics of my 81 Brat
It's getting there. Still needs paint,body work, and some interior work. I also need to replace the :eek:Ford:eek: seatbelts in the back. That's just not right. My neighbor just came over to look at the new rollbar and says "Hey, I got one kinda like that over behind the house that was left here by the last tenants. I got no idea what it's for. You want it?" So I walk over there, pull back the blackberry bushes and..... It's a little rusty but now I have 2 rollbars. It's the exact same rollbar and it's been across the street from me all this time!!! all at the same time!!!! I guess I'll clean it up and try and put it in my 82. Thanks everyone for the nice comments, I feel alot better about the $2000 I have into her now! Frank (fshnidiot)- few pics of my 81 Brat
Here's a few shots of my progress so far. After the run to Ellensburg to get the rollbar I decided it was time for some changes. #1 Peugeot 504 14" 185's. Bent 13" rims are not good on long rides.#2 Swapped drivers seat from 84 parts car. (my @R$e is still hurting from the trip! ) #3 painted roll bar and brushguard stainless steel grey and installed. Much better!! Now it rides smooth.What a difference!!! :clap: fshnidiot- Caravan :Seattle to WCSS#9
Hi all, I've got to run to Ellensburg today to pick up my roll bar for my 81 but I'm looking at running down Saturday sometime. I'm coming down from Smokey Point. Anyone else making the run Saturday from up this way or meeting up somewhere along the way? Let me know,I'd like to join up with you if you don't mind . I-5 southbound covered in Subies!! :headbang: Thanks, Frank (fshnidiot) - 86 xt turbo pics
