Everything posted by fshnidiot
few pics of my 81 Brat
fshnidiot replied to fshnidiot's topic in Historic Subaru Forum: 50's thru 70's
It's getting there. Still needs paint,body work, and some interior work. I also need to replace the :eek:Ford:eek: seatbelts in the back. That's just not right. My neighbor just came over to look at the new rollbar and says "Hey, I got one kinda like that over behind the house that was left here by the last tenants. I got no idea what it's for. You want it?" So I walk over there, pull back the blackberry bushes and..... It's a little rusty but now I have 2 rollbars. It's the exact same rollbar and it's been across the street from me all this time!!! all at the same time!!!! I guess I'll clean it up and try and put it in my 82. Thanks everyone for the nice comments, I feel alot better about the $2000 I have into her now! Frank (fshnidiot) -
Here's a few shots of my progress so far. After the run to Ellensburg to get the rollbar I decided it was time for some changes. #1 Peugeot 504 14" 185's. Bent 13" rims are not good on long rides.#2 Swapped drivers seat from 84 parts car. (my @R$e is still hurting from the trip! ) #3 painted roll bar and brushguard stainless steel grey and installed. Much better!! Now it rides smooth.What a difference!!! :clap: fshnidiot
Caravan :Seattle to WCSS#9
fshnidiot replied to sparkster58's topic in Meet n' Greet. Your USMB Welcome Center
Hi all, I've got to run to Ellensburg today to pick up my roll bar for my 81 but I'm looking at running down Saturday sometime. I'm coming down from Smokey Point. Anyone else making the run Saturday from up this way or meeting up somewhere along the way? Let me know,I'd like to join up with you if you don't mind . I-5 southbound covered in Subies!! :headbang: Thanks, Frank (fshnidiot) -
Early B-Day arrival **Edit **EEK**
fshnidiot replied to Turbone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sweet!!!!! I'm jealous!!!! I want 1 for my B-day too!!! Congrats and have a happy one!!! fshnidiot:headbang: -
Sweet. That little hatch seems like a pretty rare car. I've never seen another one around here since I got it last fall. Well, after an oil pump rebuild,valve cover gaskets,oil pan gasket,and some carb work she's alive (and purring like a kitten)and not bleeding like a stuck pig anymore.!!!!!!!!![ATTACH]4990[/ATTACH] :banana: The motor needs a GOOD degreasing to get all the oil off but I let it idle for an hour and found 2 drops of old oil on my cardboard. I can live with that!!!! Yahooooooo!!!!!!!!!!! fshnidiot
Hi, I'm going over to pick up my roll bar for my 81 Brat in Ellensburg this Friday ($75! ) and unless I get my Brat running right I might have to take my little Nissan Sentra. It's an 87 coupe/hatchback thingy, only one I've ever seen. I'm hoping it might have enough room if I remove all my fishing gear ,drop the backseat, and bungee the hatch closed. The roll bar is one of the stock tall bars (it came on my Brat when it left the showroom)that stands taller than the roof of the cab. Does anyone out there have 1 of these and if you do can you PLEASE take measurements of the height,width, and depth and post them so I can see if it might fit? Thanks, fshnidiot
Post motor swap exhaust question
fshnidiot replied to fshnidiot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the help! I'll suit up and crawl under there and pray it doesn't start raining as soon as I get started. You guys ROCK!!!!! :headbang: Frank -
Thanks for the quick response. I'd like to pull the one on the passenger side. At startup it stays open and is loud as %#$@ for about a minute then it closes and I can hear the exhaust leak at the manifold. Is it supposed to be like that? I have the y pipe from the donor car that I could use and go with both ASV's but if there's something wrong with the 1 I'd rather remove it and silence it. The driver's side doesn't make any noise whatsoever. I have the tools to do the PITA route and pull it but I'm not exactly sure how to get it off the head. If I cut and welded shut the pipe from it and used the y-pipe from the donor car would that silence it or can it be repaired if its got a problem? Sorry for being an uneducated subie person but most of my knowledge is from my old 1400 and 1600 motors. Thanks again for any help!!! I'm trying to get it ready for the run to WCSS! Frank (fshnidiot) -
look what i just got
fshnidiot replied to desertsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For being back in the land of salty roads that's in good shape! Definately worth a grand! Congrats!!!!! :clap: (fshnidiot) -
Hi, I dropped an ea81 out of an 84 dl wagon into my 82 Brat. The motor that came out had 1 of the air suction valves setups on the passengers side only. The motor from the 84 has 1 on each side. Now I can't seem to get the exhaust header to seal properly against the head on the passengers side and the exhaust is rattling against the frame at the end of the y pipe. Do I need both air suction valves or can I remove the 1 on the drivers side of the motor and if I do will that help the exhaust seal and fit properly? Thanks in advance for any tips/help. Frustrated Frank:banghead: :banghead: (fshnidiot)
Please help? Got ripped off on ebay!
fshnidiot replied to GwyNative's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The seller has a responsibility to truthfully describe his vehicle. If he didn't he commited an act of fraud and can be held accountable:dead: . Contact Ebay's resolution center and they might be able to get you a partial refund:clap: . If you can afford to have it looked at by a licensed mechanic and get a list of what the problems are, that could be of good use when you present your case to Ebay and/or Judge Judy. That's still a nice lookin Brat:headbang: , definately a keeper!!! Hope that helps, Frank (fshnidiot) -
Hi, I'm Frank (fshnidiot) the new owner of letitprince's 82 Brat (carfreak should remember that one) and I'm up in Marysville. If I can get it finished up in time I'd love to join up with your caravan. Let me know when and where and I'll try and be there. Thanks, Frank -
UPDATE: Group buy on door weatherstrip
fshnidiot replied to RenaissanceMan's topic in Historic Subaru Forum: 50's thru 70's
No problem, glad to help! Count me in for 25 feet for my 81 Brat. Stage II when you find it. Thanks much, Frank (fshnidiot) -
I have a couple you can have for free off my 84 parts wagon. I'm in Marysville. If that's not too far north for you let me know and I'll pull em for ya. fshnidiot
WTB 1979 turn signal lens
fshnidiot replied to michael appel's topic in Historic Subaru Forum: 50's thru 70's
If you're still looking for the taillight lense you might try contacting the subie dealer in Santa Cruz, Ca. I got 2 new lenses from them for my 81 Brat a few months ago and they still had access to a few more in a warehouse back east. I forget the exact price but I think I paid around $80 with shipping to get them sent to Marysville,Wa.Hope that helps!!! fshnidiot -
replacement screw for my weber 32/36
That's a darn good question! I asked and they couldn't give me a straight answer. -
pm sent Thank you!!!!!!! -
Hi,The screw I lost is the one that holds on the lower arm on the auto choke body.If you go to http://www.carburetion.com/Weber/weber.htm and follow the links to the parts diagram page for the 32/36 I need parts 73, 74, and 75. 73 is a wave washer, weber part #55530.005, 74 is a bushing, weber part #12765.042, and 75 is the screw, weber part # 64700.014. If you could come up with those that would be sweet. I just dropped a used 1800 into my 82 Brat and I want to dump the hitachi and put in the Weber that came with it. Thanks, Frank -
Does anyone out there know where I can find small parts for a weber 32/36? I lost a screw, bushing, and washer on mine. I have the part #s but everyone I've contacted says their unavailable. Any help would be greatly appreciated. Thanks, Frank
