Everything posted by crazyhorse001
I may get the years wrong, but im pretty sure legacy, impreza, forrester struts will interchange across the board from '89-'04. Also throw XT6 struts into that mix, just cuz air suspension rocks (when it works) lol *edit* If you use struts from another vehicle, its best to use them as a full set. ESPECIALLY Forrester struts as they are taller. (poor boy's lift kit)
Can the dealer cut keys from the vin on an 82 brat, or will i need to get the code from the lock cylinder?
EA81 special care and feeding tips?
crazyhorse001 replied to crazyhorse001's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the tips. These will help us keep our newly acquired Brat healthy, and happy -
Not all of it drew, but a good portion of it so far. The floor of that car was so bad that when i jacked it up by the rear diff, the doors jammed shut. Ive been parting it out slowly. Most of the parts have gone into my silver 89
But what if i want it to multiply, and get all evil n ugly? Lmao -
Since you have a few months to source parts, you might want to source a 4.44 phaseI tranny. Some outbacks, and ALL LSI Legos had the 4.44. I'm sure there are more donors though. Short of that, you may need to source an OBDII harness for your EG33. Those are available in '95-up SVX's. I agree that most EG33 swaps are manuals. That said, when the 4eat dies in an SVX, any phaseI can bolt in, and talk to the stock TCU. I'm not 100% if the phaseII will be compatible with the OBDI EG33. The phaseI with an SVX TCU is your best bet, for simplicity's sake. Best of luck with EG33 goodness in your outback.
Nope no nukes, just the Oak Ridge Uranium enrichment plant to the west, in Knoxville (sorta) Holston Defense Army Ammunition plant, and storage bunker in Bristol (sorta). Lest I forget Nuclear Fuel Services just down the road, where they make the fuel rods for submarines! Something tells me I'll do a good impression of a burnt matchstick
I can has EMP proof car:clap: My '74 Pinto will be putt putting along after the Ruskies drop the big one on us The only solid state electronics on it are the alternator diodes, and the stereo. Everything else is points, and relays.
1/25 scale FrankenBrat
It hasn't been re-released, yet. There are rumours though, now that the AMT/MPC brands have new owners. -
This is a model built by Bob Downie, a professional builder. Odds are if you've looked at the models at Wal*Mart, you've seen his work on the boxes. On to the model itself. It's the rare AMT 1gen Brat, mixed up with Revell, and Fujimi WRX kits. Now, who's gonna do this in full scale!?!
Did you pull the harness tight anywhere, or maybe nudge a curb to stretch it? What I'm getting at is, an internal break in a wire. If you're using a powered test light, check through your harness for continuity, by poking the sharp lead thru the insulation. If it's unpowered click on the switch, then test the length of the harness for power.
