djmark7
Everything posted by djmark7
  1. why change the dash all you have to do is takeoff the trim by center vents, a dbl din unit fits in the orig radio mounts so sweet
  2. my button on a' 97 was mounted on the bracket that holds the hood release lever to the underside of the dash
  3. i have a '97 leg ltd changed my veh, thnx for the info guys
  4. no fuses blown, lights come on, both switches, but no heat?, they were working like 2 months ago, any ideas?
  5. pretty well,ran till fans kicked on dunno what else to do at this point and like i said doesnt seem to be leaking any coolant
  6. '97 leg 2.5 just had hg done, after driving and idling temp goes up a bit over 1/2 from a bit below 1/2 when i speed up the idle it drops back down, also some gurgling from heater core also seems like its not pressurizing, holding coolant though, is that normal for cold weather? as i said, it is holding coolant, no bubbles in overflow, thnx for the input
  7. blowin bubbles pushing coolant in overflow tank, no coolant in system after depressurization
  8. pretty sure hg took a dump, i cant afford changing right now, any advice as to what head gasket "repair" stuff to use, i know its not good but right now its my only option what kindI should I look for and buy, Thnx Im in a pretty tuff spot here, Mark
  9. All you old-timers '97 Legacy Ltd. 2.5, use OEM, or is aftermarket ok?
  10. ok mines a '97, so whats the point of a 'valet' mode?
  11. but if you dont 'arm' the system and just lock the door the alarm wont go off anyways, right? btw, Thnx John
  12. Does anyone know what the 'Valet' Mode actually does?, Thank you
