Everything posted by djmark7
why (some) Subaru engines fail
djmark7 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery Interesting, Thank You
Gas Filler neck tube advice
djmark7 replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had to replace mine, mine had a 8 inch long rubber line subaru wanted $50 for the hose, I ot a rubber hose at napa for like $2.50 ripoff
Got a visit from the airbag police....
djmark7 replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttps://www.marketsource.com/looks like a sales company i dunno if id let him touch my subie but then again https://www.linkedin.com/jobs/view/market-area-recall-specialist-at-marketsource-inc-1723911007?refId=c2bbef50-3f43-4fbd-bd5f-678739aea369&position=8&pageNum=0&trk=guest_job_search_job-result-card_result-card_full-click
96 legacy low gas mileage
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, Tex
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCEL is for tha cat, no other codes popped up
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1st engine blew hg lost oil pressure it ran, made a lot of noise, 171000 on replacement Thank You Bennie
hi akll, i have a 96 legacy just replaced the 2.5 motor cel is on cat code with the old motor was getting 23-25 mpg with same code, the new miotor im getting 16-17 mpg, any suggestions?
`99 Impreza switch and climate control bulbs
djmark7 replied to Kenword's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.randomsoup.com/subie/how_acpanelbulbs.html
'99 OBW keyless entry is busting my chops
djmark7 replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes this help? http://www.cars101.com/subaru/keyless.html#code
Shift Lock?
1996 Outback Wagon, AT sometimes when i turn key I cant press the shift button on side of shifter to get it in gear when I press the brake, also no start the release mechanism is not releasing, any ideas? Thnx
Neutral Safety Switch
Hi All 1996 Legacy Outback Wagon AT 2.5 throwing Neutral Switch Code, I see switches from 32.00 - 200.00 whitch one should I get? or do I need molre info? Thanks
98 OBW, how to remove glove box?
djmark7 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXleave door closed unscrew from hinges on bottom 2 screws on each side then release door and 'presto'
98 OBW, heater fan motor control problem
djmark7 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtake out the glove box youll be looking right at it
3.0 H6 ENGINE REPAIR MANUAL?
djmark7 replied to kennycoulter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdunno if this will help, but...... https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals
MAP sensor
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsurvey says...... it was the solenoid, thnx again everyone
MAP sensor
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTY
MAP sensor
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI read a clogged EGR would kick it off also? is that true?
MAP sensor
MAP sensor
OK,I put a 1998 2.5 motor into a 1996 body that had a 2.5 in it, same body style, leg wagon kicked a CEL Map sensor with the original 1996 sensor, also with the one from the 1997 car, the 1997 car had no CEL, the motor was swapped into the '97 car with no CEL I'm puzzled, BTW, same sensor in both cars PLEASE HELP !!!!
99 outback key stuck
djmark7 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes the key turn all the way back to the 'off' position?
2.5 swap
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXappreciate everyones help, THANKS
2.5 swap
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwill the bolt patterns line up for the tranny?
2.5 swap
2.5 swap
1996 Leg outback Wagon Body 2.5, can i put a 1998 2.5 engine in it from a outback? ,will it swap right in? from a wagon also
