djmark7
Everything posted by djmark7
  1. here ya go http://www.cars101.com/subaru/keyless.html#code
  2. Hi all, 97 outback automatic trans. what is the procedure for using Trans-X, Thanks
  3. this? http://www.cars101.com/subaru/keyless.html#code
  4. http://opposedforces.com/parts/legacy/us_b11/type_25/body/back_door_parts/ see # 14 & 15 looks like youre missing the guts on mine theres a spring loaded thing in there
  5. can anyone tell me where the IAC is located? '97 2.5 thnx
  6. bout half hr drive for you,but i use Jeff's Auto repair in Port Jervis, NY, Subaru Trained, does good work 845 856 7171
  7. no overheat fans seem to be working good heat in cabin
  8. oem used coolant is full, stays full no bubbles in of tank, thnx Tex
  9. 1997 Leg 2.5 hg were done, prob is...looking from front of car, radiator side by upper hose half of rad gets kinda hot, half by cap stays cold, system has been flushed, is that normal? thnx p.s. i only felt top of rad where i could slip my hand in, thnx
  10. or......http://www.amazon.com/Cardone-Select-66-7055-Axle-Drive/dp/B000CFHCTA/ref=pd_sim_sbs_auto_2
  11. axle is clicking now ill chk c-p thnx gg
  12. anyone hear of these? yea or nay pls http://www.ebay.com/itm/350977701210?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
  13. happened to me whole strut tower rusted off the rest of the car check that
  14. ok pull out cup holder 2 screws take out ash tray 2 screws on top grab vents and pull whole thing out gently, but with force, itll pop out, disconnect 4 way switch and cigarette lighter so you can remove ctr piece then unscrew radio and voila reverse to install (in a nutshell)
  15. use the original mounting brackets from the subaru radio 3 screws on each side hold it in the dash
