Everything posted by djmark7
how to tell
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbelt is tight put in that lucas ps stuff it helped for bout 12 hours then got stiff again, im leaning more & more towards the rack
how to tell
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthnx all, no noise except when it hits a hard spot you can hear the pump 'strain' a little, fluid is ok
how to tell
'98 legacy how do you tell if the ps pump is bad or the rack, REALLY hard to turn but it goes in 'spurts" ez, hard, ez, hard spaced approx. evenly, thnx
95 legacy & 01 outback specs??
djmark7 replied to Kingfisher's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can try here, just change the year i think? http://www.cars101.com/subaru_sitemap.html
friction/ tap in steering wheel while turning
djmark7 replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOR, (it happened to me in my '98 legacy) the steering rack might be going?
My 6th Subaru - 95 Outback
you shouldnt be taking picture of the speedometer while youre driving :>)
Average life of Subarus
djmark7 replied to outbacklover97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX98 leg wagon bought 4 yrs ago 180k, now 257k still going strong
ABS Light
djmark7 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas stated above '98
ABS Light
just replaced all the struts on my 98 legacy wagon and the abs light came on steady, all the sensors are wired and in place? any ideas? also how would i read a code (if any) from the abs system?, thnx, Mark
stuck seatbelt???
djmark7 replied to mwills's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe the belt frayed and jammed, happened to me with my '98 leg free replacement, check with a dealer first
What is this?
djmark7 replied to tricked919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen i suck on valve engine does almost stall so its working right? i dunno
What is this?
djmark7 replied to tricked919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi can move the valve by sucking, kinda ez too i dunno, NO CEL comes on
What is this?
djmark7 replied to tricked919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX'98 leg 2.2 no vacuum to back pressure transducer, EGR valve does NOT move at all, when i disconnect egr (the side with one line) and suck through hose it seems like theres a hole but no hole in line? there is NO vacuum to either of the 2 lines that go to the one side? is that the norm? also there a electric switch? thats between the BPT and the EGR valve? thnx in advance
(mileage check) Who's got the mileage record?
djmark7 replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX98 legacy 2.2 just turned 250k
hood won't pop open, 97 OBW
djmark7 replied to tracedog67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoor
djmark7 replied to tracedog67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry holding the release and slamming the door i have to do that with mine its just enuff to pop it then spray wd-40 or something like that on the latch mechanism
92 Legacy Relay Clicking Stalls Engine
djmark7 replied to gandalfthew1te's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy '98 2.2 did the same thing, crank sensor code, but it straightened itself out after bout hour and a half, been fine since then
Excessive cooling system pressure - causes ?
djmark7 replied to cagranitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry a new cap
97 OBW alternator went bad
djmark7 replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrecall no. is WXX81 mine was done on 7/10/2001 if that helps any?
djmark7 replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmine had a recall '98 leg wagon, for alt
crank pulley wobbling?!?! and some strange noise
djmark7 replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX98 leg wagon, my pulley bolt became so loose i could take it out by hand tightened it back up, seems all is well now, but i keep my eye on it 243k miles
quick question
quick question
98 Legacy Wagon, 241k on clock, motor puuuurrrrs like a kitten, doesnt leak a drop of oil, my question is: stamping on block is "EJ22" how would I find out if the motor is the original?, thnx
removing rear wiper
djmark7 replied to DupermanDave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi just did my motor on a 98 leg wagon the wiper arm is def shorter than fronts and i think they changed body design in '94 so the bolts might not match up you have to remove arm, take off plastic cap, unscrew nut open back hatch cover (pop-outs) disconnect fluid hose and elec. conn. and reinstall , 3 bolts on motor just make sure you put the bottom rubber on the right way so you can feed fluid hose through it
1999 defroster switch bulb
djmark7 replied to jkrz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsame one (short) that illuminates the climate controls
