Everything posted by CNY_Dave
2002 Outback VDC - 3.0
CNY_Dave replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAside from *maybe* the front speed sensor, I think a correct ratio 4EAT could be used, with the rear section swapped. The H6 4EATs I hear have a beefier part somewhere, but haven't seen pics etc.
need help draining gas out of tank
CNY_Dave replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah idled. Took about 20-25 minutes I guess. Can't let much out or the pressure drops too much to even idle it. easiest probably to use a C clamp or such, start crimped off, then loosen slowly until it gets rough, then tighten till runs smooth.
CNY_Dave replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid this last night, T fitting with needle-node channel locks holding hose mostly shut. Slow, but captured about 5 gallons that the scrapper won't get!
CNY_Dave replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tried to get a thin line into my tank, there's like 6 gallons in there! No go. I think I will just T into the feed to the engine and use small enough line/fittings that it'll still idle.
CNY_Dave replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf fuel filter is in the engine bay and has 3 lines, the return line to tank could be routed to a jerry can and the engine run. I have to drain down mine this week prior to it going to the scrapyard (my '03 LL bean H6 with exhaust gas in the coolant). Scrap prices really suck right now! $80/ton for a car (4 cents/lb!)
Broken rear diff
CNY_Dave replied to Mwood92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpiders maybe broke. Presumably you have no drive to the rear wheels. A chunk could migrate and make something interesting happen.
CNY_Dave replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBTW only the VDCs had VTD in Gen2 H6's.
Is 1 Year Old Gas an Issue?
CNY_Dave replied to Michael Anthony's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can get some out to check it visually and a 'sniff' test, you could make an educated guess. If it was ethanol fuel, it might need a good bit of dilution and drygas.
Convince Me
CNY_Dave replied to dannyboy3141's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ute idea, I like!
Tups needed on removing transmission 03 LL bean outback
CNY_Dave replied to Lverano's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the bigger HF transmission jack- I had to have the rear jacked up with jack stands with a 2x10 underneath each jack stand, and the front was on good jack stands with I think 2 pieces of 2x10 under each one. I have a decent floor jack and needed to put a 4x4 on it to raise the car high enough. The jack has a height of about 8.5 inches, pretty high http://www.harborfreight.com/800-lb-low-lift-transmission-jack-69685.html
Transmission Flush
CNY_Dave replied to sadarahu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe changeover was for 5EATs, they got the subaru-only HP stuff, our 2006 outback 4EAT uses Dex-iii
Harbor Freight Transmission Jack
CNY_Dave replied to zundfolge's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used a metal bar from top of radiator support to in front of the windshield, I think. Something like that. Bolted it right to something on the intake.
Quieting the differential 03 Bean H6 Outback
CNY_Dave replied to Lverano's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used some lucas to stretch mine out, was so thick and sticky it slung off the ring gear, up onto the bottom of the dipstick, and literally pushed it out and spewed all over.
Convince Me
CNY_Dave replied to dannyboy3141's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI went from a '92 ranger 4L 6 5spd to an outback 3L 6. Loved the ranger, love the 'roo.
CNY_Dave replied to Lverano's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you use a transmission jack to move the trans out from under the car you have to get the car very high.
CNY_Dave replied to zundfolge's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe engine on my auto sube had to be supported, from the top is best.
2002 LLBean H6 3.0
CNY_Dave replied to Rust's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have factory plugs in mine, been in there far over 100k, no problems.
Replacing front bearings
CNY_Dave replied to sadarahu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have been happy with axles from NAPA. I might just have been lucky.
ATF+4 and dexron III
CNY_Dave replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe best motorcycle chain lube used to have whale oil too!
What transmissions wil fit 04 outback?
Assuming auto, in general you can use a 2001-2003 (in addition to '04) with perhaps changing a solenoid and valve in the tail section. When I did a swap of an '04 LL bean 4EAT into an '03 LL bean, the interchange they used wrongly stated an '04 would swap right in to an '03. Hollander actually updated their interchange manual based on my info!
power window motor replacement
CNY_Dave replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI changed the whole mechanism on our '05 forester, price differential was not great between new motor and whole mechanism. I will need to do the pass window on that car soon, I might try just the motor since I happened into one.
2002 Legacy 3.0 - HG test
CNY_Dave replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy H6 has never overheated but has been pushing gas into the coolant since may. Sometimes the symptoms are hidden. A slow gas leak will not blow hoses as the system can't exceed the cap pressure. A fast leak can build pressure faster than the cap can release it. If a hose blows at or below cap pressure, it was a worn-out hose.
Transmission problems
CNY_Dave replied to Timbum36's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe pan pushed up just a little can do it with no other damage- it restricts flow into the intake.
CNY_Dave replied to Lverano's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is a lot quieter than mine was, not bad to live with at all. Of course I'm the guy that drove on a bad wheel bearing so long I had to drive with ear plugs...
CNY_Dave replied to Lverano's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy front diff noise did not come up through the shifter, was quite loud with the door open though!
