Everything posted by CNY_Dave
JDM H6 3.0 EZ30D issues
CNY_Dave replied to laegion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCertainly check crank pulley bolt and flex plate bolts are tight, and try without the serp belt, and make sure the crank pulley isn't rubbing the front cover (I had that happen, the rubber degrades).
still chasing a shake
CNY_Dave replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat axle seems to move too much (in the not rotational direction)
CNY_Dave replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had the shaking under power be a bad inner CV joint, can be surprisingly hard to track it down.
Wheel hub stuck
CNY_Dave replied to Wizard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a little hub puller but no slide hammer, so I bought a stout threaded rod with washers and nuts and bought 4 5lb barbell weights to go on the threaded rod. I literally had to be careful I didn't yank the car off the jackstands.
'08 OB heater temp control
CNY_Dave replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoth control cables seized in my forester when it was about 10 degrees out, with the heat off of course. (In snowy weather I cool the windshield before parking and leave the heat off to help keep it cold) I ended up putting 2 small holes in the dash with stiff wire coming out, the wire connected to the doors.
HELP!! Forester stuck in Drive (auto)
CNY_Dave replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, exactly as on mine.
FB25 engine reliability
CNY_Dave replied to Stelcom66's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. Has some weird rust in places, mostly paint that flaked off under-hood spot welds and brackets and a little on the rear diff carrier.
CNY_Dave replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh and gear lube, my magic mix had gear lube. My magic hatch lock grease was atf, bearing grease, and silicone grease.
CNY_Dave replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had my cable (2005 forester) start to bind, from top and bottom I would lube with paste mix of ATF and wheel bearing grease every couple of years. Well, more the little round thing that holds the cable in the shifter than the cable.
CNY_Dave replied to Stelcom66's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKind of glad now my unicorn* forester is a 2010 not a 2011. *(bought in April, 28,000 miles, manual trans)
OEM 6cd changer fit in a 1995 Legacy?
CNY_Dave replied to bendecker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a slightly different OEM 6 disc changer and yeah I had to take it apart to get my disks back. It wouldn't even play them...
H6 HG replacement possible without pulling engine?
CNY_Dave replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a coolant weep from a head gasket for almost 200,000 miles, the subaru / holts rad weld conditioner kept it under control up to and beyond the combustion leak into the coolant. If something was beyond a weep or maybe a small trickle yeah it probably wouldn't work.
CNY_Dave replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI favor the JDM engine route.
What have you done to your Subaru this week/lately?
CNY_Dave replied to pz99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOld motorcycles to be fixed up in my case, late 70's yamaha XS750 triples, plus there's my XR650L to haul to further riding places.
2010 Forester, auto trany filter
CNY_Dave replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just bought a 2010 and reflexively clicked on this then recalled it's a stick... Haven't had a stick since 06? 07?
CNY_Dave replied to pz99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRecently bought a 2010 forester manual trans with 28k miles and stuck a hitch on it.
Starter motor hesitates
CNY_Dave replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can always try starting it in neutral, could be the neutral safety switch.
loud whirring sound after driving 30+ minutes 2002 Subaru Outback
CNY_Dave replied to SubiMountain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWheel bearings increase the tone at the same rate you speed up, 2x as fast and 2x the pitch. Differentials pitch up by 4x the speed change, also diffs usually only make noise when on the gas and get quiet coasting.
Can rear diff bushings cause both rear tires to wear excessively fast ?
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your tires are now worn differently front-rear you are inviting AWD problems.
Coolant leak
CNY_Dave replied to jonbfish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBTW I have had an upper hose that leaked very slightly, it seemed to be coming from anywhere but the hose.
Antifreeze leaking from weird hole on driver's side bottom
CNY_Dave replied to Dan092181's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrverdoold, yes, spot on. For a small leak on this car I would be tempted to try some seal conditioner, but a major leak like this, no. This is a fairly unusual failure for this engine.
Did a couple oof quarts of transmission fluid blow the main seal of the transmission?
CNY_Dave replied to 01L.LBeanH6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf going the used trans route, H6 transmissions are different, and one from a 2004 is an option if you swap a part in the tail section.
Duty solenoid C no voltage when testing at try.
CNY_Dave replied to Dom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the AWD mechanical bits are working then it should have bound up a little in limp mode, which is what the trans goes into when disconnecting that. You get 3rd forwards and reverse and full AWD. The TCU can only detect the voltage at the TCU so it's either a busted or shorted wire from TCU to solenoid, or it's the solenoid.
CNY_Dave replied to Dom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year and model is the car? What year is important, and the test they talk about with the fuse isn't measuring at the fuse, it's the wire to the solenoid. in 2003 the fuse would do one thing, in 2004+ it would do the opposite. The resistance would be measured with the TCU disconnected. The TCU solenoid is in the removable tail section of the transmission. With the FWD fuse out, and with it in, what does the car do when turning in tight circles? 2004 and after when the solenoid fails you get front wheel drive, which doesn't hurt anything. before that when it fails you get full lock front-rear.
CNY_Dave replied to Dom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you tested the resistance, it was with the TCU disconnected? The signal from the TCU to the solenoid is a pulsed pattern, you need an oscilloscope to see it, although you can get some idea of what's going on with a voltmeter, but it's not really a measurement you can use to say 'good/bad'. The pin at the FWD fuse is hust a signal line input to the TCU, it's not in the circuit with the solenoid.
