Everything posted by CNY_Dave
Wheel bearing brand?
CNY_Dave replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFactory bearing with grease already in place has been my choice.
Lower ball joint time- yay!
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBTW napa has the 12x1.25 tap in the sprk-plug repair section, 6 bucks. Used my brazed-on lug nut though.
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBall joint is in. Tool worked great! Got the area around bolt pretty red to get it to loosen. I shielded the CV boot well, don't think the wheel bearing took a lot of heat.
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, now I have lots of time to work on it. Got laid off today.
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought in the south they just fell out when you asked them nicely?
Front Differential whine = exploded transmission?
CNY_Dave replied to telpernian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked the diff fluid levels? Here is my bad front diff noise
CNY_Dave replied to telpernian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA squeal is less likely to be an axle or diff. More whine, or more squeal?
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm counting on heat, planning to get the threaded end a bit red. I have plenty of metal plates to use to shield the CV joint, and the acetylene torch can get it cherry (and hopefully loose) and I think I can can cool it before the wheel bearing takes a lot of heat.
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLowes- useless. No 1.5 black pipe caps (I have the rest of the black pipe bits already), and get thisd- they stopped carrying taps (not that I was too hopeful they'd have the right size). I cut the head off a 3/4 grade-8 bolt and used a 1/2-inch black-pipe union to join the bolt and a spare open-ended lug nut, brazed with a tight-fit.\ Ground/sanded off the chrome at the coating on the bolt first. Those gold bolts- cad plated? Plenty of air etc when I did it, now the garage is frigging cold.
CNY_Dave replied to telpernian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I understand it, you pull everything off the front, and the tail shaft and MPT, so the valve body doesn't get disassembled and the internal spinny bits except for the front drive shaft stay in place. I went the used-trans route as you can get one knowing the mileage, and doing the R&R myself it was affordable. I plan on keeping the car long enough it would have been worth $1500 having the one in there repaired, but finances didn't allow.
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrill into the end of the pinch bolt? Does that mean a new bolt is required?
Lower ball joint time- yay! Detected a tiny bit of wanderlust in the sterring, bit of play in a lower front BJ. I have cleaned the gap to expose the bit of the BJ and threads, heated with the blue wrench and let some kroil hopefully get sucked into the joint and threads. I guess I'll be searching for that homemade BJ puller thread... I will keep the slot doused with penetrating oil, and will heat the heack out of the part the bolt threads into when I pull it. Next week hopefully...
EZ30 Swap into Forester S 2000
CNY_Dave replied to plastickmat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the 4cyl radiator have 2 top hose connections? Is the 4cyl radiator big enough for the H6?
Doors locked me out while car was running
CNY_Dave replied to maestrosteve's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI always open a window or open a rear door (so the snow from the windshield doesn't fall in the car). Paranoid drives home, others try to figure out how to call triple-A with the phone and work access badge locked in the car
how to *QUICKLY* remove 60 rusty/stuck/stripping timing chain cover bolts
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've only been off dial-up a couple years, no cable, no DSL, sure as heck no fiber, satellite's a scam, finally had to go with a 3G modem (verizon mifi).
Wheel Bearing Hub Knuckle Troubleshooting
CNY_Dave replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe way to check a hub (if it falls outta the race it's way bad) is to look at the fine lines on it wgere it goes into the race. Fine scratches along the length where it was pressed in/out are fine, any scratches that go around or any discoloring shows the bearing race has been moving on the hub. It's not so much that if it rotates the rotation will damage the bearing, but that if it rotates the inner race will not be held perfectly centered and the balls/rollers and race contact points will be overloaded, too few balls/rollers will be taking all the load. When they get overloaded they fail quickly. Also, if one race spins and the other does not spin with it, the face where the races contact each other will wear and the bearings will at first get too much preload (axle stretch acting like a spring), then as it wears they'll get too little.
dented transmission pan, 2 solenoid connectors cracked - is the trans still good?
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe TCU and much of the car harness are different for VDC. You can put a VDC trans or just the rear bits into a non-VDC car, you just need to control the lockup clutch manually. The mpt in the vdc trans is designed to be locked or free, not to be partially slipping. It is the same size in diameter as the non-vdc MPT but has fewer plates.
CNY_Dave replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will need a new hub as well, that one will be loose in the inner race.
Problem starting my 02 Outback
CNY_Dave replied to watermelon35's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't forget to check the neutral/park switch interlock, just because it's easy. Try starting in N, even turn the key and then move the shifter a bit.
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh, that's why I didn't catch it- I was thinking vdc/non-vdc 4eats that were mated to an H6, all the H6 outbacks that gen have the 4.11s.
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the VDC front diff different? Thought it was the same. I am pretty sure 4EAT non-VDC and 4eat VDC are identical except for the rear housing and the VTD center diff with VDC instead of the mpt. All the magic is in the TCU and the center diff.
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say the chances are good the valve body is OK. If you can pull the solenoids and give it a good visual inspection I'd say you can be sure. Bigegst concern might be if you pull a solenoid and you see it may have loosed chunks into the valve body. Not likely, but something to check for.
Abs testing went wrong help !
CNY_Dave replied to jmclaren380's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn fusible links, if the gauge is known it can be purchased at auto-parts stores, you just have to cut it to the correct length and solder it in.
ABS not kicking in
CNY_Dave replied to provin1327's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the ABS light comes on key on, engine not started. Check for power to the unit, key on.
Trouble starting - too many cranks P.2. Subaru experts please give me your .02!
CNY_Dave replied to gc8guy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould it be the fuel pump isn't running briefly to prime the system when the key is turned on?
