2
Posts posted by mkoch
I need to replace the clutch plate on my BRAT.
While the engine is out, what else should I do?
delete please
On 2/28/2021 at 1:43 PM, 88SubGL said:
Did the vibration start before or after you installed new tires? If after then it’s the tires. If before then possibly something in the front suspension, tie rod ends, ball joints, etc.
I don't know! I installed the tires 1st thing upon buying the car.
I don't know. Here is some information about the P7157. Maybe you can find a cross reference. http://random.removed.us/altswap.html
mkoch
On 2/26/2021 at 9:20 AM, Sasse said:
Installed. All went pretty easy. The cat-back muffler/pipe will be installed next week.
Thank you for the follow up. I'd like to see pictures after you install the next piece.
moch
At highway speeds, there is a vibration, feels like it's from the front, steering wheel cycles left-right about 5 times a second. I just had new tires put on. What besides tire imbalance can cause symptoms similar to tire imbalance?
mkoch
The vapor separator is available over on ebay.
mkoch
1985 Brat non turbo. I have a "vapor separator near the firewall, driver's side, (left, USA). Fuel comes from aft low in the separator, leaves low to go to the carb. Out of the top vapor returns to the tank. Mine is opaque, probably from age. Is it also a fuel filter, and should I replace it as preventative maintenance? Part number 7420 72020 .
mkoch
1 hour ago, DaveT said:
No. Not in the sense of an intentional controlled system.
Well put! I guess every engine has a rev limiter of some sort!
Does my Gen 2 Brat 1985 manual transmission have a rev limiter?
mkoch
I don't have one to sell right now
but
I did take apart one on my GL, 1984. It is a pretty simple mechanism, and easy to clean.
I only had to clean off the grease, and polish the parts, and then it was like new.
Take lots of photos, and be aware that there are some ball bearings and small springs which can fall out. Magnets can help retain these.
mkoch
- 1
10 hours ago, GeneralDisorder said:
Not true. A single wire narrow band sensor will create it's own 0-1v signal. It won't be useful in any real sense of the word, but it will not require power.
GD
It should indicate that the engine is running lean, or rich, or in spec. How is this not useful?
Thank you GeneralDisorder! I plugged the hole with a sensor, I'll run a voltmeter off of it just for grins.
My suggestion is to follow all laws all the time.
Some garages doing the inspection for the state will look under the hood, see a Weber in an '80s Subaru, and pass it, even though the Weber does not have the emissions stuff on it.
My mechanic saw the two catastrophic converters on my Brat, and asked my why there are two. The second one looks like a resonator, but also, it sure has a honeycomb inside.
The what looks like original catatonic converter for my 85 Brat did not have an O2 sensor, no place for it. The replacement had a place for the sensor, so I put one in, just to plug the hole. He said it had to be plugged in to pass. He didn't say where. Of course, I found the right place to plug it in, but he would have no way of knowing.
These cars, 30 and 40 years after manufacture, might not have the original setup.
mkoch
I am not a lawyer. Consult your attorney for legal advice.
"Also, before you get into the project, determine if you need a catastrophic converter in your area.
mkoch
I ordered the one by "Davico" from RockAuto, for my '85 Brat. It should be the same as the 82.
It fit at the exhaust manifold, and only sort of fit at the mounting bracket further aft. The bracket on the y pipe met the car's bracket at a 45 degree angle. Not easy to bolt up, but doable.
I used my own welder to replace the stock type flexible joint from the y pipe to resonator pipe. The Davico 120021 Y pipe that I received had the wrong style of flange.
edit-
The DEC one is $70 more expensive. Knowing what I know now, I would still buy the Davico one, or fabricate my own. The stock flexible joint is just a bother. I now have the flexible piece connecting the Y pipe to the resonator pipe. There are only three flange gaskets my exhaust system. The two at the exhaust manifold, and one between the resonator pipe and the muffler. So, essentially, a two piece exhaust system.
mkoch
Heya,
1985 Brat 49 State, Hitachi carb. I replaced the Y pipe, which looked original (it had the air heater). It did not have an oxygen sensor. The replacement has one, and I wonder where in the wiring harness it connects.
Thanks GeneralDisorder!
My plan is to remove the windshield on my 1985 Brat, repair the rust around the edges, and then have the a new windshield replaced professionally.
I have a new gasket!
How do I remove the old one?
85 BRAT, Hitachi, ok at 2k rpm, balks at 2,500 rpm, what is my problem? 49 State
Posted · Edited by mkoch
typo
,85 BRAT, Hitachi, 49 state, new fuel filters, old loud fuel pump, new front and rear fuel filters.
The car will hesitate and lurch under certain conditions.
If I let the car just idle still for a while, and then accelerate, there is not problem accelerating, until about 20 seconds into it, then the balking begins. The normal acceleration indicates to me that both carb barrels are working.
I just drove this car up a 1/10 mile 7% incline several times. I let this car idle, still, at the bottom of the hill every time before I did the test.
2nd gear, 2,000 rpm, the car makes it up the hill just fine.
2nd gear, 2,500rpm, the car starts balking halfway up the hill.
I am guessing the problem is the fuel pump, or the valve which fills the float bowl.
Am I missing something?
