2
Everything posted by mkoch
I stripped a hun on my 1985 BRAT, for the second time! The 36mm castellated nut was at the right torque, with cotter pin. What am I doing wrong?
- 2 replies
- 1985
- generation
- (and 4 more)
1985 BRAT. I have decided to upgrade my alternator to a 90amp 1989 Nissan Maxima model. Is there an online source for a v pulley? Is it possible to use the pulley from the original BRAT alternator on the new alternator? LINK to alternator at Advance Auto Parts
- 1 reply
- brat
- alternator
(and 6 more)
Tagged with:
85 BRAT, where is AC thermostat? Wiring Diagram pic
mkoch replied to mkoch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
With the battery disconnected, I tested the resistance from the AC relay, through the thermostat and fan speed switch, to ground. You're right! The thermostat is part of the circuit in the four fan speed positions. Thank you for the response! -
Azdave, thanks! -
Is 1985 BRAT wiring the same is 1984 GL Wagon?
I am trying to make the air conditioner work. I have 1984 Subaru 1600 1800 Engine and Body Service Manual and 1984 Subaru Wiring Diagram and Troubleshooting It looks like the 85 BRAT has the same dash and engine wiring as the 84 4wd wagon. -
2nd generation, EA81, what size heater hose?
I the ones which connect to the heater core. Connect on the driver's side firewall. -
I have an 85 BRAT, I replace the alternator six months ago with one from my parts car, '84 GL. The replacement seems to be bad, with low voltage shown, and light coming on. Is there any component which could be making these alternators go bad? I thought the voltage regulator is in the alternator. mkoch
EA81 had low oil, now a new sound, video
Thank you for the response, and thank you for all the posts on ultimatesubaru.org! -
My front main seal leaked, and I saw that I was losing oil pressure just as I was on a highway on ramp. I had definitely driven with low oil for a few miles, but good oil pressure. So glad I noticed the dipping oil pressure gauge! I replaced the crankshaft seal, and topped up the oil. In startup, it sounded like the hydraulic valves ticked until they were filled with oil. I have a new sound above 2000 rpm, well represented on the video. Any guesses?
The ignition control module, in the distributor, has a condenser. The 1984 GL does not have points. Could the condenser go bad and cause the problem mentioned?
I did not notice a loss in power before the balking. I tried to recreate the problem today, and I was unable to make it balk. I did some before and after measurements. Old fuel pump, 2psi (13.8 kPa) at carb, 594 cc/ minute unrestricted flow. New fuel pump 5psi (34.5 kPa)at carb, 983cc/minute unrestricted flow. The unrestricted flow was from the forward fuel filter, so there must have been some loss to the vapor return line. Is 2psi fuel.pressure a problem with a Hitachi?
