mountainwalker
Topics posted by mountainwalker
Subaru auto parts salvage yards in Silicon Valley/SF Bay Area?
By mountainwalker, in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 9 replies
- 6907 views
What's the SealAct Blending Solution and Cloth in this Dr. Colorchip kit?
- paint repair
- paint
- (and 4 more)
- 1 reply
- 4067 views
Help - Best Source for Subaru White Frost Pearl Paint Match?
- paint
- paint match
- (and 5 more)
- 3 replies
- 1976 views
When to rotate these tires and which pattern? Alignment? Happy Thanksgiving
- tires
- tire rotation
- (and 4 more)
- 2 replies
- 1832 views
Valve Cover and Front Timing Cover Gaskets Leak; Spark Plug recommendation
- gaskets
- valve cover gasket
- (and 3 more)
- 9 replies
- 6814 views
Recommendations for Quality Spark Plugs for 2003 VDC 3.0L H6?
- 2 replies
- 2339 views
Cause of muffler rattling sound when Outback stationary in Drive?
- muffler
- muffler rattle
- (and 3 more)
- 7 replies
- 2588 views
Best tires for Outback & Costco tire replacement policy
- 7 replies
- 3423 views
Where to buy replacement parts - fog light protector?
- 9 replies
- 776 views
Cause Oil Leak/Check Engine/VDC light after Idley Pulley, Tensioner, Belt replaced?
- Idler Pulley
- Tensioner Assembly
- (and 3 more)
- 5 replies
- 2071 views
Best/Favorite windshield wipers and source?
- 5 replies
- 1217 views
Shift lock due to blown fuse or other cause? Brake lights out too
- 10 replies
- 17912 views
Cause of not starting when gas low, then starting after 2 pumps of gas pedal?
- 22 replies
- 5892 views
Stalled,Lost Power Steer,Brake + Battery Warning Light,Burning Smell,Rattling Noise
- 23 replies
- 5234 views
Do you use Fuel Injector Cleaner every 3K mi. as Subaru recommends?
- 10 replies
- 8951 views
Can bad wheel bearing cause more damage until serviced? Cost Parts & Labor?
- 18 replies
- 52459 views
Cause of burning smell from R front tire well only???
- 24 replies
- 32617 views
Correct amount/type of oil for Outback 3.0 L H6 2003? 1 2
- 33 replies
- 37642 views
Optimal tire inflation for 2003 Outback VDC 3L H6? Subaru recommended way too low 1 2
- 27 replies
- 10361 views
Cause of higher pitch sound when accelerating after 90K servicing by dealer?
- 15 replies
- 943 views
Is service needed for Valve Gasket/Head Gasket tiny leak/Slightly Dirty Coolant?
- 19 replies
- 3161 views
Outback VDC 2003 OEM Alarm System problem or setting change?
- 4 replies
- 888 views
How often do you change your Air Filter?
- 9 replies
- 1424 views
Cause of slight left wheel jerk at stops, slightly higher rolling resistance?
- 2 replies
- 561 views
Best online Subaru parts
- 5 replies
- 1005 views
