Everything posted by 93Newbaru
OEM gaskets vs felpro, and others, and who makes what
I picked up two OEM head gaskets for this 97 Outback with EJ25 yesterday. Part number 11044AA610. I don't have the proper felpro gasket any more, but from what I can remember it looks exactly like the oem gasket I purchased from the Subaru dealership.
I briefly tried to find out what the blue actually was but haven't found the info. Quote from their website is "The Fel-Pro brand by Federal-Mogul is a leader in multi-layer steel (MLS) head gasket design, the current leading-edge technology in sealing today’s lightweight engine castings with a long-term, leakproof seal called PermaTorqueMLS®." They sound good, but no blue info. Since the first gasket I installed had no coating, I'm just going to remove it and take both back to the store. I'm not opposed to buying felpro head gaskets again, but I just don't really see a reason to even bother with them.
I just purchased a set of felpro head gaskets for my 1997 Outback 2.5 from Advance Auto. They had one in stock and had to order the other. Part numbers matched on the packages. I installed one tonight, then began reading the package of the second gasket. It mentioned a "blue coating", which I didn't remember the first gasket having. I opened the package and removed the header card which had the part number on it. Underneath that packaging it was factory packaged again, with a different header card and part number. This second gasket was blue, completely different, and was the thinner than the first gasket. These gaskets might be as good as oem, maybe even oem gaskets packaged with the felpro name, but I'm probably just going to stick to buying them from the dealer from now on!
SE WI, Milwaukee Regional/Subaru Alliance
Two days ago I started installing the motor. It has been a little too warm here for me to be comfortable doing anything, and I was having a hell of a time lining the bottom studs up to the trans. I even logged on to usmb later that night to try to read some tips on how to do this (although I have installed quite a few motors and none had ever gone this rough). Tried again yesterday and immediately removed the motor mounts because I figured they were getting in the way (I had never had to do this before) but thought it would slide right in. Nothing changed, it was still fighting me. I was making up new swear words, throwing and kicking things, soaked with sweat..... With both studs started I could get one to slide in but the other would pop out, and vice versa. Any pushing, tugging, slamming the crane around wouldn't do anything. I even one time had the engine lined up exact perfectly with the trans and it wouldn't go. I took one more break to cool down, and went back at it. I thought all the slamming around maybe the bolts had created a lip inside the transmission which wasn't allowing them to slide all the way in. I grabbed a bolt and stuck it clean through one hole, tried the other hole but the bolt didn't go in all the way. My first thought was wtf, and then I looked down and saw the stud from the previous motor had unthreaded from the motor and was sitting against the CV shaft. Disgust, hate, anger quickly turned into pure joy. I guess that's what I get for trying to work on a car that I haven't touched for 6 months! All it needs now is coolant, and to steal some brake parts off of the parts wagon and it should have a new lease on life!
I used "mnwolftrack" 's technique that johneggleston posted here http://www.ultimatesubaru.org/forum/showthread.php?t=81925&highlight=torque+clip Installing the conver was very easy, it took me about 4 times and it went all the way in. Hook finger under nub on trans, slide it on and rotate, then rotate other direction, if it's not going pull out slightly and try again. Awesome. I should have replaced the seal but I was all about getting the TC on the trans today and now that it's on I don't really want to remove it again:eek: I was lucky unbolting the exhaust, every stud came out clean and I just ordered new studs and exhaust gaskets from Subaru. Going to take a week for the parts which will let me examine the rest of the car and order whatever it needs. Since I never drove this car I am crossing my fingers on everything else being in good shape, trans, axles....everything!
That's what I'm hoping for, to sell 3 decent cars. The best car has only 150,000 on it, while the motors I have are 240,000 and 200,000, so I figured I would wait to find something with lower mileage for that car. For today though I really need to know about the torque converter clip, I plan on installing the 240,000 motor into one of the cars but the TQ isn't installed on the trans. I'm going to go work on it in a little bit here and might be able to figure it out but it would be nice to know exactly what to do. Thanks!
Hello again Alliance. I am back up to 6 Subarus on my lot and have a question I'd like help with. One of the 4 97 Outbacks has the TQ removed from the trans, I see the clip inside which doesn't let me slip the TQ back on all the way. Upon reading a little, I see that I should try to remove the large hollow shaft and install it in the TQ before putting everything back together. Is this correct or is there a better way of doing this? Does the clip really need to be there? OBW #1 has been sitting with no motor for quite awhile OBW #2 has a motor issue that I haven't even looked at yet OBW #3 runs and drives but beat up body, awd doesnt function, recent timing and HG's with 240,000 OBW #4 purchased last night, 199,000 and blown head gasket First thought was to put the motor from #3 into #4, scrap 3 and sell 4 as a good car. Now I'm thinking put motor from #3 into #1, scrap 3 and sell 1 as a good car and fix HG on #4. Only problem with 3 is the TQ is off and I need to get it on. Then all I have to do is -Complete reseal, timing, fix stripped heads, install new brakes on 89 GL -Install brakes, maybe timing kit and reseal, replace broken lights and maybe body work on 95 Legacy -Find a motor to install in car #2 because it is super clean I'm sure I'll be back with a few more questions, I've actually been thinking of paying you all to come up here and bang out 4-5 good cars! Not sure I could do that but it would be pretty damn cool to move all of these!
It's possible. I think there were 2 of them around here, and the one on craigslist was rusty and had really crappy tinted windows. I believe that's why I didn't care to make much of an offer because it was rusted out pretty bad. If it had been the car at the junk yard things would have been different. I try to keep the cars I have, or at least fix and sell or use them for parts. I just can't stand having this many vehicles taking up space sometimes, and I'm really not supposed to be doing this in town whatsoever. Nobody is complaining yet though:lol: I can't pass up buying a car for scrap value or under scrap value especially if I could for any reason use parts from it or possibly fix it, so basically I would buy any Subaru that fits that criteria. I'd like to pay attention to the cars I have, but I keep getting overwhelmed with having too much stuff.
The last time I hauled scrap metal I saw this white car far in the distance as I headed towards their building. I immediately knew what it was and was pissed as this place sells absolutely nothing on their lot. I'd seen a few of these driving around town for awhile, I just can't believe it ended up at the scrap yard and not on my lot. Hopefully I'm not too guilty, this is the body of one of my 89 wagons hanging from the loader bucket. I kept most everything from the dash area, the entire front and rear ends, and all of the doors. Plan is to build the other wagon into something worth driving. I wanted to swap windshields but I royally screwed up when trying to remove the good one, instant huge crack so I bashed it with a hammer multiple times.
Your lifted wagon is very good looking, if only I could spend the time with something I own! That "lovin winter" license plate is cool too. As promised, I started tearing one of the white wagons apart yesterday. It had a blown head gasket when I bought it, stuck another motor in it and had head gasket issue with that motor after a few hundred miles, could be my fault. When I hacked the exhaust apart last night it poured water all over my trailer deck. :-\ Here is a picture of my fix on the center bearing mount. When I bought this car it had a wicked vibration. Months later I finally looked underneath it and the driveshaft was hanging on the exhaust. Figured that was the problem. Made this mount and test drove, still lots of vibration! It was the rear U joint in the driveshaft. Good to get the center bearing fixed though, when you'd go to put it in 4wd it would slam into the underbody with a big thud before.
Good points. I just have a hard time getting rid of things that I could use or that could be useful to somebody. There are a number of loyales/gl's around here. The main reason why I was going to scrap the one 89 wagon is that it's pretty rusty, I'd keep the DR trans, driveshaft, rear diff, axles, basically I was going to unbolt the undercarriage from the rust and haul the body in. The idea was to swap everything into the other car, much less rust, only 83,000 on the only EA82 motor that I have that is good, although the windshield is cracked. The rusty car is up on the trailer and hopefully I will have it torn apart soon.
All the cars I have right now are automatics, I haven't been lucky enough to find many with manuals.
I wanted to build one really sweet car out of it but was quickly realizing that I may never actually build it like I wanted to. Wanted 4" lift, repaint entire car, do all the EJ swap work, rebuild one of the EJ22's I had, have a set of my pugs blasted so I could paint them, buy good tires for them....im sure theres more. Couldn't see spending the time doing it all and was scared to start spending that much money I guess. I'm sure it's at a better home now that won't let it sit around forever!
I towed it to Superior WI along with an EJ22 that was pulled from the 90 Legacy I have, and the EJ swap kit. I figured he was a USMB member but not sure. He said he knows Numbchux.
Not sure if its a 3 or 4 speed. I'd guess its a 4 though? I havent done much with a lot of the stuff I have but I'll look one of these days. I've been thinking it kind of sucks that you guys aren't up here, I have been collecting cars from all over and hope to make bank on them but they keep sitting around. Right now I have a 90 legacy wag, 95 legacy LS wag, the 2 matching 89 GL wagons, Two 97 Outbacks both purchased by the same gentleman and both had motor problems, and 2 more in the works possibly for next weekend, 95 legacy wagon and 97 legacy wagon. The good news is that I just picked up a 20 foot flatbed trailer from down in your fine state of WI today so I can move/strip/acquire vehicles even easier. I'm addicted for some reason. Are you asking when I am coming to Milwaukee? I could almost have a meet of my own seeing as I own like 6 Subarus:grin: The only problem is not a single one is roadworthy!!! It would suck to have to show up to a Subaru meet with a minivan or truck :-\
I'd rather cut through all the bs and have the experts from the alliance help me:grin: Plus it was kind of a random question that I didnt want to throw up on the board. I try to figure everything out on my own but I have once again collected many cars and would like help on a few things so I can possibly make some casholaaaaa.
Is it bad if I pulled the center shaft all the way out of my 97 OBW transmission? Only asking because I was poking around here again and read that if the shaft is pulled all the way out, then some kind of pin will fall down inside the trans and the trans will have to be torn apart to put the pin back in place. If this is the case then my plans may not go as smoothly as I wanted
just got a new scooby :) lots of pics
Talk about clean, what a score! Doesn't even look like a hint of rust on the steel wheels. Well worth whatever the price was!
Jack Stands
I've always used the 6 tonners on everything. They are overkill, but overkill is good. Larger pad, larger surface area on the bottom etc. If money is tight you could skip the trans jack and buy the 6 tonners and be a little safer while under the vehicle. I've always just used a floor jack when removing transmissions anyway, and with a little modification and maybe a strap you'd be more than set.
Harbor Freight "quick pump" floor jacks
I'd like to know how this ends up working. When I purchased my floor jack probably 4 years ago I was looking for a quick pump type jack, one that would actually lift a vehicle with less pumps rather than just getting the jack pad to the vehicle quicker. I couldn't find one that would actually lift a vehicle quicker, and ended up with a $100 Craftsman. It uses the same chassis as the HF one you just bought, just different internals. I'd almost wastefully spend another $100 if the HF one is truly quicker:grin:
finally pics of my 84GL
Looks much better, at first I didn't even realize the fenders were cut! Nice
timing belt
93Newbaru replied to dgoughnour1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. Did something happen, broken, seized, jammed? I just purchased the same car, somebody had not changed the water pump or pulleys and everything had failed. Pump seized, pulley broke and belt was jammed behind pulley. I tore the engine apart but haven't looked too hard for anything yet. Pistons are not damaged but a couple valves didn't look like they were seating properly, possibly bent.
New Subaru Owner Dude!
Thats what I figured, you guys have all the luck down south and out west. Looks like it's in really nice shape. We have a handful of them around here, all rusted out or on their way to be. The only reason my 87 is basically rust free is because it was transported a few times from NC, and it still has some wicked paint fade. As far as lifting, SJR is the way to go. http://www.sjrlift.com/ He will get you up to 6", and that is pretty big if you look in the gallery section.
Welcome, dude. Sounds like a good trade, the GL's have a special place in my heart for sure. I currently own an 87 GL10, and two 89 GL's. All project cars but once the warmer weather comes I will become more of a garage rat. There is tons of info here and a lot of it needs to be searched for. Post some pics of the car if you could:headbang:
Do I register or sell?
93Newbaru replied to HankG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHoly hell @ those fees! Who the hell are these people? I forget to register my crap and either plate it with a spare legal plate I have or buy a new plate. Like $100. I'd never pay $700
