Olnick
10
Everything posted by Olnick
Sept. 27-29 Mt. Rainier, WA Old-Gen Meet
Olnick replied to jj421's topic in Meet n' Greet. Your USMB Welcome Center
Thanks for sharing your "lemonade!" The scenes look magnificent--and so do your cars.- 31 replies
- september
- mt rainier
(and 4 more)
Tagged with:
Forester 2003
Olnick replied to rkautar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Welcome to USMB, Raman. If you will put your query in the "Newer Generations--1990 to Present . . . " forum you'll have a better chance of getting answers. -
Welcome to USMB, Javier. Car looks beautiful, especially under the hood!
Let me put it this way--I've replaced timing belts and rebuilt the front ends on two Legacies (EJ22s, I admit!) and I ain't no great shakes as a mechanic! If I can do it, I'm willing to bet you can too. Study, study, study. Read everything you can about the procedure. Then read it again. Make sure you know exactly what marks go where. Take your time, make notes, take pix if you need to. And if you get stuck come on here and ask for help. That way you can use your hard-earned money to buy the new belt, new idlers, new tensioner (if needed), new water pump, thermostat and gasket, new crank & cam seals, new oil pump o-ring & sealant--you know, all the good stuff! You can do it. Good luck & enjoy!
A while back I had squealing on start-up and, IIRC, when engaging the AC. Checked the belt--it was in good shape, tension was fine. But I decided to take the tensioner mechanism off and check the idler pulley. Turns out the pulley mount had gotten slightly cockeyed--the axis of the pulley wasn't exactly perpendicular to the belt! Cleaned it up, remounted it, adjusted the tension and it's been running quietly ever since! Hope this helps. Good luck to you.
That's great news HadrianV--and thanks for letting us know. Years ago I had to replace the ECTS on my '95 and it was magical how the car immediately ran "like new!" You might want to check for OBD2 codes again, there might still be some stored. Probably needs a new KS. And I'd be tempted to pull the thermostat to make sure it's the correct (Subaru) one. You don't have to open up the front end to get to the T-stat--can do it from under the car. Good luck & happy driving.
Don't panic--I'm sure your car is totally "salvageable!" How long have you had it? How many miles on it? Do you know any of its repair history? From the codes I'd suggest trying a new ECTS--engine coolant temperature sender. New knock sensor too. They're not very expensive and not very difficult to install. Also drain and flush the dirty coolant--maybe pull the old thermostat and replace (make sure you only use a genuine Subaru 'stat!) Don't know your level of "expertise," but these are all fairly simple "driveway repairs." Try a search here on USMB, they've all been well documented over the years. The '95s are great engines, I've driven mine for years and it still "runs like new!" (But the body ain't gonna' last much longer!!!) Good luck--and by all means keep asking questions if there's something you don't understand. Oh, and welcome to USMB!
Welcome to the USMB, Reidy. Always nice to meet someone who would "rather repair than throw the vehicle away!" The first gen Legacy/Liberty is a great vehicle. The usual fix up here is to simply tear out the pneumatic suspension and replace with standard coil springs and struts, generally with parts from a salvage yard. It's been talked about a lot in the past--maybe you can find useful information with the "search" function. Hopefully someone with more suspension knowledge than I have will jump in with suggestions and links. Good luck.
- 3 replies
- 1
- EP-SHeight Control
- Rear Suspension
(and 1 more)
Tagged with:
"I went out and stared at the suby again this morning, thats when I noticed that the marks on the timing belt no longer match up with the marks on the camshafts. They should be lined up right? Or is it the marks on the cam's and the marks on the engine that I need to worry about. When I put it on it all lined up... :angry:" What you saw is perfectly normal--the belt marks and pulley marks only line up once every-so-many revolutions (can't remember the number of revs offhand.) The big question is what marks did you use to align the crank and cam pulleys before you hung the belt?
