tubesoob
Everything posted by tubesoob
  1. tubesoob replied to tubesoob's topic in Off Road
    I have the JD Squared tubing notcher. Great product. As far as bending the tube I went to a guy in Ephrata, WA that makes sprint car chassis. I just met the guy when I showed up there and him and I knocked it out in about 2 hours, very unexpected. And he only charged $200 including the tube, which ended up only being $75 in labor. When I do buy a bender I am going to get the JD Squared model 3. The bender itself is only $300, $500 with the stand and degree wheel. Hopefully with my tax return:banana:
  2. tubesoob replied to Uberoo's topic in Off Road
    If you can find a 12 or 14 inch wheel, get some ATV tires and swap them on when you get to where you wheel. You have a choice in tread. You can also get sizes from 24 inchs tall up to 27 or 28 inches tall. If you go this route, look for something designed for a UTV, they are usually 6 ply
  3. $427 after conversion. Not too bad
  4. tubesoob replied to tubesoob's topic in Off Road
    Ok thanks. What vehicles came with the d/r 5 spd? Do they use the same crossmember mounting locations?
  5. tubesoob replied to tubesoob's topic in Off Road
    Here are the pics of the front end out of the car, and then set under the frame. Hopefully I will the engine bolted up tomorrow and the struts mounted on Monday. Anyone have any recomendations on where to get a driveshaft shorten in Eastern Washington? Also if anyone is interested, 3 of the 4 doors are in good shape. The passenger front has a slight dent. They have all the hardware, glass is good if I remember correctly. Also The hood is in good shape, so are the gauges, driver's side front fender, cruise control and headlight switches. I am not looking to make any money off of it. If anyone wants any of it let me know and we can set up a time and date for you to come get what you want
  6. tubesoob replied to [HTi]Johnson's topic in Off Road
    That is a pretty sweet bumper, maybe add a winch mount. One thing that I have noticed is that a lot of you carry your spare tire on the roof. What about a swing out tire carrier for the rear bumper. You could also add accessories like mounts for a winch down low, racks to hold gas cans, chainsaw, high lift, shovels, things like that. Just my 2 cents.
  7. You are going to like that stereo. I have installed Pioneer Premier decks in 3 different rigs and have never been disappointed
  8. tubesoob replied to tubesoob's topic in Off Road
    Finally got the engine out of the donor car. It got dark on me but I will take some pics tomorrow. Also got the mounts for the rear end tacked in. I am finding thing that I do not like about the original design so I am making changes as I go. For example, the plans say to mount the battery between the struts with the top of the battery even with the top of the struts. I am planning on running dual batteries and I didn't like the battery being mounted that high, so I am going to move it in front of the fuel cell. Small things that make it mine.
  9. Looks like a great rig that shows what these cars are capable of. You definatly have gone a good job of turning it into a vehicle that will get you and your family anywhere you want to go.
  10. tubesoob replied to tubesoob's topic in Off Road
    The red fuel cell is mounted in the same location that the stocker was supposed to be mounted and that fuel cell was a freebie. I didn't know if it was going to fit there but it does clear the rear diff. The plans call for mounting the battery up front by the firewall, with the top of the battery at the same height as the top of the struts. I think that is a little high. I was thinking about mounting the battery, maybe dual, right in front of the fuel cell. Don't know yet
  11. Thanks Sweet! That's exactly what I was looking for.
  12. Thanks guys I really appreciate all of the input
  13. I did, sorry I should have clarified. I plan to be going slow enough that front impact airbags would not even deploy.
  14. yeah the plan was using an engine hoist to lift the vehicle and one of those wheel dollies under each wheel. I don't think that I will have to lift it that high, the rear end is already removed so the back of the car is sitting on the ground.
  15. I 100% agree with keeping things as simple as possible to avoid breaking complex parts. However if I was going to put an ARB in a trail vehicle you had better believe that I would have all the necessary parts to repair any damage on the trail. ARB puts out a good product that people knock because they break something on the trail and didn't bring any spare parts. Not trying to argue with you, just my 2 cents. Some things that have kept me up wondering have been 1 has anyone put airbags on their subaru? 2 serious fab work but fitting a Ford explorer or escape IRS rear end into a subaru. I would guess that this would lead to an increase in breaking, and possibly more gearing and lockers What do you guys think?
  16. tubesoob posted a topic in Off Road
    The snow melted in the Tri Cities and I need the engine, transmission and front end out of the donor car for the buggy. I am waiting for schucks to get me the chilton for my 82 subaru, so I figured that I would ask you guys. I was looking at it and it looks like all I need to do is 1 Remove all cables, hoses, and electrical from the engine 2 Disconnect the shifters from the tranny, driveshaft is already off 3 Disconnect steering, brake lines, and upper strut mount 4 Unbolt engine and transmission crossmember 5 Lower engine, tranny, and front end to the ground 6 Lift vehicle up and pull engine assebly out My question to you guys is will this work, or will I have to pull each part seperatly??? Thanks
  17. Looks like a good time. Be sure to take loks of pictures if you go, for those of us that live too far away to go
  18. Hey guys. I was wondering iif anyone has any expereince setting up rear suspension. My question is when mounting the rear shocks do I want the trailing arm extended all the way when I measure for the shock length? Sorry for the newbie question but I have never done this before. I want to get the most travle that I can get but I don't want to overwork the cv joints. Thanks.
  19. Everything needs aftermarket anything But seriously you might notice a slight improvement in hp, gas mileage, etc. Where you will notice it is if you plan to take it a step farther with exhaust, injectors, and so on. So it really depends on what you plan to do with the car.
  20. Pics and description posted in buggy build in the off road forum
  21. 10 degree? From what I hear Spoke is like -10
  22. It is going to be alot easier to find a cheap factory 4wd an save your 2wd for use as a daily driver. Converting from 2 to 4wd is a lot of work. It is not bolt up by any means. just my .02
  23. tubesoob replied to tubesoob's topic in Off Road
    Sweet82- I know what you mean. Looking ahead I can see where there is going to be some brain scratching. I have even had to do a little trial and error on some of the angles. I have decided that I am going to use the plan as a guide. I am going to use rancho rear shocks and modify the mount. As you can see I haven't even started the front suspension, the plans look a little vague and I am out of tube. As for the tire I was going to run a set of 27 or 28 inch ATV tires and 12 or 14 inch wheels. What specifically were the problems that you ran into, hopefully I can avoid them. Here are some options that I am looking at. Of course I will have a set of steel wheels and some all terrain tires Wheel Tire options Bill- we will definatly have to get together. I am kind of working on this in my spare time and everything is only tack welded right now. I am hoping to have it fully welded and painted by memorial day. If you have room, maybe I can ride with you on a couple of trips. I haven't been wheeling in a couple of years.
  24. tubesoob posted a topic in Off Road
    So I figure that I should post some some pictures and a little back ground on my buggy project. I found the company rhino buggies in Austrailia back in 1999 when I was in high school. I wanted to build one of them but never had the opportunity. Then in Feb 2007 on a random trip to Big Toe Auto Recyclers in Finley, Washington I found a running 82 Subaru, bought it for $200 and drove it onto the trailer. When I got home I tried contacting rhino buggies only to find out that they had closed that part of their business and would not send out ony plans for building their buggies. 6 months later I found a guy in Austrailia that had plans to build 2 different buggies, the stalker and the bandit. So $25 later both sets of plans were on their way to Washington state. I recieved them in October 2007 but had no time to start building because I was in school full time trying to finish a Criminal Justice degree. I started the Buggy in May of 2008. Between working full time for my National Guard unit in Pendleton, OR and going to 3 Army schools and a 2 week AT these pictures show how far I have gotten in the last 7 months. And between the donor car and metal I am into it $450
