Everything posted by 1-3-2-4
Misfire cly 3 & 4
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm the manual says PFR5B-11? I'm looking at the service manual and it says this RC10YC4 .......... CHAMPION BKR6E-11 .......... NGK K20PR-U11 .......... NIPPONDENSO I'm not sure if it's the same as the owners manual but I'm not sure why it would say something different.. I think they are all copper plugs which is fine for me I guess no big deal.. Also no misfires this morning but it's been dry for the past 24 hours but I forgot to do the water mist last night but will do it tonight.
ELM327 bluetooth OBDII scan tool question
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow i did not know it had a windows version.. too bad I don't have any laptop with windows on it.. I'm going to play with it later tonight
Shifter Linkage Replacement
1-3-2-4 replied to doc526's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk I'm going to do it tomorrow I was playing with the shifter yesterday and I see the area where I will have enough space but man rust :-/ I don't think I saw a spring on mine but I can take a picture for you Another question on the linkage at the top is that a nut I feel? I'm not sure how long these are meant to last for but any issues sliding the new one on? here is a video showing how sloppy it is
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow that program looks nice I take it it's linux right? Which is good because I have a tablet pc that is running it. I already have a USB to serial cable.
what would cause a stuck 5 MT?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will let you know Can the hydraulic system be done by one person as far as getting the air out? I was going to get something to suck the fluid out so the air wont be trapped in? i get to drain the tranny fluid tomorrow so I will see how bad things look.. just going to use ramps tomorrow How much do you think that this nut on 5th gear backed off?
1997 Outback
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX????
Help with abs code
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere is the plug where the sensor plugs in?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm I think I have a break in the weather on Friday albeit cloudy... because I have no 5th gear I'm going to go ahead and take off the rear housing cover. I'm not sure if the nut back off or the shift fork is bent. While I'm at it I should do the shifter linkage.. this is the sloppiest shifter ever I noticed subaru has like 3 different part numbers for the shift fork for 5th gear.. one being mark 4" and the other being mark 6" and the other not saying anything at all *edit the mark number should be stamped on the fork
1997 Outback
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXenjoying the afternoon sun I was looking in the owner booklet and someone kept the sales slip for when they had service on the car.. they had the Timing belt and water pump and a few other things changed at 66,600 miles One question.. and I remember this well trying to change the spark plugs on the 98 Forester.. I forgot whats the best way to get to the driver side spark plugs? It's a super tight fit.. Also checking the valves I'd have to check the write up someone from here did but they can be done in the car right?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhahaha true at least I got SOME life out of it
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got it somewhat.. others with a MY year mine have the same issue sometimes it shows and sometimes not.. it's a program issue in the software and not the hardware. I did get it to show my oxygen sensor data and throttle and coolant temps so it works but you have to mess around with it a bit.
Show off your roos Mileage!
When I picked it up yesterday
1997 Outback
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm... sucks I ran out of intake cleaner.
removing hitch
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot pictures and some macro pictures! You could not pay me to tow anything with this.. http://www.drawtite-hitches.com/products/Class_II__1_1_4_inch_Receiver_Hitch,36234
My '95 Legacy: Trashwagon10
Nice I can't wait to get rid of my outback wheels haha almost time for the summer wheels to go on
Keyless door entry 97 outback
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXman that thing is up under the dash good I really still cant tell what model it is.. Is it worth saving? I just want the keyless entry lol. I'm so close to just ripping it out and installing the factory keyless entry.
Help with abs code
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWait I see my mistake in the picture lol Codes: 26 56 51 Just cleared it so we will see cleared the code and only 26 came back.. Right Rear sensor.. i'd have to check it when I take the wheels off
Help with abs code
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 20A fuse in car is good How do you clear the codes it might work to give me another code
Help with abs code
My abs light is on and im trying to get the code now.. I pluged the pins in 3 & 6 but the car just flashes the abs light a single time and thats it
I have this ELM327 scantool for my 1997 outback to pair the device the passkey is 6789.. So I did that and I use the program called torque and it says it's connected to the device but I don't see any live data from it and it wont read any of the ECM codes or anything like that when I had the CEL on. Anything I did wrong that I can think of? This is the one I have here http://cgi.ebay.com/ELM327-OBDII-OBD2-V1-4-Bluetooth-Diagnostic-Interface-/290557937261?_trksid=p4340.m444&_trkparms=algo%3DCRX%26its%3DC%252BS%26itu%3DSI%252BUA%252BLM%252BLA%26otn%3D10%26ps%3D63%26clkid%3D8591180643441608201
Misfire cly 3 & 4
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I'm sure it's one or the other.. the past owners did not do so well in taking care of this car.. Funny thing is I don't feel a loss of power unlike the last time I had a misfire in the 98 Forester back in 2000. This morning I was at 4K and I noticed the light blinking.. I'm going to go clear the code again but I'm going to also do the water spray test as well.
1997 Outback
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks it feels nicer then my other car however I think the rear sway bar is bigger? It sure does feel like it.. For testing yesterday when it was wet it was easy to go sideways if forced.
Misfire cly 3 & 4
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can try this when I get home I havent checked the vavles yet I do have a vac gauge to checl
Misfire cly 3 & 4
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts been damp and rainy since I got the car... Wires dont look oem and my 3 week old NGK wires only fit my ej22 Car is 97 outback
Misfire cly 3 & 4
Have not got to the plugs yet but failing coil pack? I felt no loss in power light would blink once in awhile but not all the time.
