Everything posted by Don_Quixpunch
Hey Ya!
If you still have the original engine, it's got solid lifters. Were I in your shoes, I would adjust the valve lash and try the compression test again. If that doesn't seal it up, you've got worn out piston rings and the entire engine needs rebuilt. Or, you could just cut your losses and find a newer engine that runs well. When I blew a head gasket in my 81 Brat, I was able to find a hydro EA81 for 20 bucks. Several months later, and I've had to replace the water pump and am about to do the oil pump because the old one leaks. Prolly I should have just replaced both when I did the swap. Since you don't have much in the way of tools and experience, you might want to network with some guys local to you. Good luck with your hatch. You'll have a blast in it once it's mobile again.
Y'all are the best!
I didn't want to admit that I had a problem, I'm only on my third Subie. But after buying a first gen Brat in need of a lot of work, it's time to be honest with myself.
Vehicle Selection
One more thing, somebody mentioned going as far back as 79 in a GL model. I could be wrong, but I believe 81 was the first year of the dual range trans. And the earlier years of dual range were 4 speed. The 5 speed is stronger, lighter, and shifts smoother. If you do look at the older cars, keep in mind that you probably won't like the 4 speed dual range, but a 5 speed can be swapped in and you could even find an old car with the swap already done.
pics
What an interesting location for mounting driving lights. Must be nice not having shadows from them. Do they glare off of the hood?
81 Brat A/C condensor identification?
My compressor is the same shape and size, but the hoses connect to the back. But I measured around the pulleys, and I'll just buy the 45 inch belt. That should tell me which compressor I have too.
Dhoh. Why didn't I think of that? It is fairly large and squarish. I'll measure anyway. Thanks for the input.
So I'm wanting to rip the A/C outta my 81 Brat. And I have it on good authority that it's worth saving and passing on. My guess is that somebody who wants it would really want to know if it works. I have no idea if it still works or not. It's got refrigerant still, but no belt. I went shopping for a belt, but it seems there are two possible condensers and they use different belts. I checked for a name, but it wasn't Nippondenso or Hitachi. Does anybody know where I can find something like pictures, identifying marks, or even pulley sizes so I can nail down which belt I need? Also, if anybody is interested in having it, as soon as I know if it works or not, I'm going to tear the whole thing out and list it here.
Brat years?
So I take it the factory A/C in my 81 GL is something special that should be preserved?
Brat years?
So the DL model in those years was simply front wheel drive?
Brat years?
So I know that in 81, the GL package got you dual range four wheel drive. What did it provide in the other first gen Brats?
Another project added and 1st for this forum
Sexy! I really hate all you West Coast guys and the rust free Subies you find. I have an 81 GL Brat and it's got almost as much rust as steel.
Hello from Montana!
Also get involved in the Off Road forum if you're not already. Lifts are a very common topic there.
98 OBS Junkyard Fix (Heavy on the pics)
Looking very good! As sad as it is to let a Brat go, at least now you've got a slick daily driver that can carry passengers. Love the instrument panel lights!
81 Brat GL clutch cable.
So I finally drove with the new clutch cable this evening and it works great. So if anybody else has an 81 Brat and needs to retrofit a newer cable in, hit me up and I'll give you the pictures I did take and tell you how I did the rest. Now to fix the sloppy shift linkage. At least there's already a procedure for that...
The 81 is different from that. The peddle has a 10mm or so post welded perpendicular and then the cable has an eye swaged onto the end that slips over the post. The newer style peddle has a 6mm or so hole through it and the cable has a barrel fitting that is swaged on behind a stamped steel yoke, there's a pin that slides through both the peddle and yoke. The peddle and bracket geometry is different too. Had I used the newer peddle, it would have crashed into my brake peddle. So I cut off the post and ground off the weld on the other side. Then I poked a 5/16" hole through the peddle, a little wiggling of the drill and it's a nice snug fit. I ended up using the metal sleeve from the end of the original cable housing to fit the new cable into the original clamp. I used a cutoff wheel to cut a slot into it so I could slide it over the cable. I started taking pictures, but once I got into the car, I couldn't get any pictures that were meaningful. So I'm not putting up photos, but if anybody else needs to update the clutch cable in their 81 Brat, feel free to hit me up and I can answer any questions about how I did it. I haven't driven it cause I also painted my front wheels and want the paint to dry completely before I put them back on. It felt just a tad squishy, so I'll come back with feedback on how it actually works once I do drive it.
Tires in SLC.
For anybody in the Salt Lake area who might need tires, I was just at the Tear a Part on Redwood and saw a 92 Loyale in row 65 with all four stock blah wheels and matching Hankook Radialmax tires that looked to have about 80% tread. It also had a new looking full size spare under the hood. All I ask is if somebody gets them, please say so on the thread so people don't drive there for nothing.
That's what I'm thinking too. Just got home from the JY with a cable and peddle. It's looking like I can just cut off the post that the old cable connected to, grind flat the weld that attached the post, and drill a hole for the pin that works with the newer style cable. I'll take pictures for anybody else who thinks they might also encounter this problem.
I've no idea what the newer cable ends are going to look like, but if I can never again get the '81, it makes sense to adapt the car to fit the more modern cables. Thanks for the input.
Clutch problem
You might also want to check your peddle bracket. The attachment point for my cable housing bent. When I finally find a new cable, I'm going to weld a stiffener onto the bracket in hope of it not happening again.
Yeah, I went to the dealership first. They say the part has been discontinued.
Remanufactured Engines
A friend of mine owns a place called Metric Motors and he's all about the JDM engines. As I recall, he gives a one year warranty with them and while he does once in a while get a dud, you just can't rebuild an engine right and compete with the price. Plus, most of the JDM stuff is built to a higher standard than the crap they send to the states. If I were going to buy an import recycled engine, my biggest worry would be the reputation of the shop that's importing the engine. If you've heard good things about them standing behind their product, I say go that route.
So my clutch peddle bracket folded and while getting it apart I see that my cable is pretty frayed and probably on its last legs. Does anybody have any suggestions on where I might find a new one? I've already tried Pep Boys, Napa, Subaru, and Rock Auto with no luck. Or maybe can I use one from a more recent car?
Boxer buggy
Cool to see an EA drivetrain standing up to that sort of use. Gives me hope for my Brat. And a great endorsement for welded diffs.
EJ Swap - now noise in my speakers
If I were having that problem, the next thing I would look at is how clean and tight the ground for the stereo is. If it's too hard to get to, I'd just cut the wire and splice in a new ground. As long as you hit the body, it doesn't matter where it is. When I put my head unit in, I just ran a new ground wire. But the PO committed some pretty severe *********************ery in my cars electrical system.
SLCSubaru/Mark Miller Round 3- Southtowne Grand Opening Meet!!
So I was just reminded of an existing commitment for next Saturday. Turns out I won't make it afterall. I'd love to hang out, have a couple of beers and trade Brat notes. How hard would it be to talk you into a detour on your way home Ninefourteener?
