98sub2500leg
Topics posted by 98sub2500leg
Removing speed sensor 98 subaru outback ej25 manual t
By 98sub2500leg, in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 5 replies
- 3510 views
Need Engine-transmission mating tricks
- 24 replies
- 11761 views
98 Subaru Speedometer stopped working
- 6 replies
- 5103 views
Removing speed sensor 97 subaru outback ej25 manual t
- 0 replies
- 510 views
Subaru OEM parts
- 6 replies
- 853 views
Ac questions
- 14 replies
- 2105 views
Current Head Bolt tightening procedure-What is the Lastest procedure?
- 17 replies
- 24980 views
Engine won't start after reinstallation 1 2 3
- 59 replies
- 7318 views
Removing 14mm 12pt. stripped cylinder bolt head
- 19 replies
- 11451 views
Check engine light on after HG job
- 7 replies
- 757 views
new clutch; pedal has a soft spring to it
- 19 replies
- 1845 views
Oil pump rotor re-installation positioning; alignment
- 15 replies
- 2208 views
Oil pump test, oil flow test, new HG reuse
- 15 replies
- 2170 views
Timing Belt removal cam calibration to marks
- 16 replies
- 2639 views
really bad news-TB came off during warmup 1 2
- 26 replies
- 1520 views
Hatchback strut removal for replacement
- 10 replies
- 657 views
Cleaning sludge from coolant resevoir
- 9 replies
- 765 views
98 Legacy Outback 2.5L Manual TM & rear diff. - (real world) oil change intervals
- 7 replies
- 839 views
Removing front crank seal from oil pump housing 1 2
- 26 replies
- 3019 views
Mouse problems
- 16 replies
- 1233 views
Flywheel pressure plate balance marks (MT)
- 3 replies
- 5165 views
Cam alignment of marks, TB -Lifter Shims
- 2 replies
- 505 views
Timing belt rear cover adhesive backed foam gasket material
- 1 reply
- 881 views
98 Outback Cargo cover parts/taillight reflector sources
- 4 replies
- 1221 views
Valve cover gasket & plug & bolt seals sealants
- 4 replies
- 911 views
