136
Mixed opinions on synthetic oil in Subarus. If it has ANY oil leaks, it will spew synthetic like a broken dam. Some people also think it makes these throw rods through the block. I tend to think oil pressure is more to blame for that. There are known issues with the oil pumps on these, and synthetic oil will clean out any grime that might be in the pump preventing problems. Once that grime/buildup is gone the oil leaks past and pressure goes \/ . I plan to switch to synthetic once I get the leaks on mine sealed up, which might be the next oil change.
Any check engine light? Probably not if it passed emissions (will fail if any current codes are set or if the light doesn't work), but it might be worth it to pull the codes anyway. You can search here and get directions for that. There might be a How to in the USRM section. Look like cold engine numbers. Retry with a warm engine and see what you get.
Pull the fuse for the airbag module and disconnect the battery before starting. Not sure how you remove the airbag from the wheel on these, but when you get to removing the wheel, loosen the bolt or nut that holds it on but don't remove it. Then you can pull on the wheel and pop it of without a puller, when it pops loose the nut will catch it so it doesn't hit you in the face.
Obviously a popular choice for timing kits here amongst the experienced members. I'm looking at their kit for my 96 Legacy, sitting at 180k on the ticker, I believe a leaky front crank seal, and a water pump or gasket that leaks roughly a quart of coolant between oil changes. I'm wondering how their water pumps are? Is it worth getting the full kit with pump, or should I just get the belt kit and tensioners and go to Subaru for a pump? Already going there for cam and crank seals, oil pump O ring, and the little bypass hose on the side of the water pump.
Have to find out where it's dripping from, but the drain plug washer is the easiest to change. If it's wet in that area that could be a possibility. A leaky input shaft seal will trail down to the same area around the drain plug. Everything else that might leak, besides the seem between the case halves, is towards the back of the transmission. Time to break out the purple power for a good degreasing.
A failing diff would be clearly evident. They don't go silently. The steering wheel will turn fine, but the car will keep trying to go straight, then you'll get a loud bang pop and click, the car will jump up and down and jerk around, then it will turn... for about 3 feet. Then you go through the motion all over again. Going the steering shaft U joint route with everybody else.
Camo door cards FTW!!! Should have done Mossy Oak.
You get that type of behavior when the trans is left in park. Center diff maybe, but I'm thinking something broke and has wedged itself in one of the planetary gear sets. Either way, Something asploded in there, exactly what is gonna take a teardown to find out. Tell your mechanic to take some pics and post them so we can see the carnage!
