Timing belt change progress
Fairtax4me replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat should work, but to avoid stretching, use the old belt to hold the cams while you tighten the bolts. Then reset and put the new belt on. A light smear of sealer means you put a dab on your finger and run it around the sealing surface until it's coated. Remove any blobs or drips on the inside. I usually make it thin enough to see through it. This (which just so happens to be a subaru oil pump ) is too much IMO. http://beergarage.com/imgs/Suby/OPump/14.jpg Crazy what you can find with google! http://beergarage.com/SubyOPump.aspx
Another Pulling Auto Transmission Question
Fairtax4me replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe majority of the fluid is inside the TC. It's not pretty if it slips off. Make sure that the TC stays fully seated the whole time during removal. Ideally you want to use a torque converter retainer. It's just a bent piece of metal about 3 to 6 inches long that you bolt to the bell housing. You can make one pretty easy. Looks like this. http://www.handsontools.com/OTC-Tools-ZTSE9109-Torque-Converter-Retainer-_p_45783.html
Fretting corrosion on axle splines?
Fairtax4me replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad it worked for you! I usually just run a wire brush through them a few times to take care of corrosion and scale in there. Never had to use a triangle file for that specifically, but it seemed like it should work. Not sure how you ended up with "black rust" in there, but Id have to guess road salt and heat had something to do with it.
repair or replace?
Fairtax4me replied to griffenrider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDriveable but barely. I'm kind of surprised I can still drive it to work. If I give it over about 35% throttle it will start slipping. It gets worse at higher speeds, especially if the engine rpm is over 2500 where the power band really starts to pick up. I don't think it could fight the wind on the interstate, and trying to make it up any hill is tense. I keep watching the tachometer and hoping that it doesn't start climbing while the car is slowing down. I appreciate the offer though.
Chronic brake problem
Fairtax4me replied to pmf823's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe tire guy might be trying to get some extra $$$$ to make up for what he spent on Christmas. About the only way I could conceive that both rears would be bad already is that they're dragging. Which would be due to sticky or locked slide pins, degraded brake hoses, or the parking brake is sticking. That or the last job was done with very poor quality parts, which I would hope a Subaru dealer would not use. But you just never know with dealers these days. Normally the rear rotors will last twice as long as the front rotors, because they don't get as much use. If the rears are worn out already, the front rotors would be shot. If the brakes are/were dragging you would certainly notice it in your fuel mileage, and the rear wheels (one or both) would be very warm after a drive. If there were a problem, I would bet on the slide pins. But like I said, I think your tire guy was trying to come up with some work.
LSD? Want to remove OB diff guard!!!
Fairtax4me replied to AWDfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo, why does the service manual say that there's an ID sticker there? Maybe they just fall off easily? I mean, I know for a fact that my 96 doesn't have a tag, because I've looked. But I have nothing to compare that to. I do have the service manual though, and it says... Unless something changed between 96 and 99...
Timing belt noise and slack
Fairtax4me replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAren't the mounting holes still there for the old style tensioners? Might be worth it to switch.
Why does my Outback with manual transmission have nuetral switch?
Fairtax4me replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you did an auto to manual swap the ECU is still looking for the Park/Neutral Range switch for the auto transmission. I seem to recall there being a fix for that, but I can't remember who posted it.
repair or replace?
Fairtax4me replied to griffenrider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know how you feel about the cold. I'm getting ready to drop the transmission on mine to replace the clutch. Too in depth for me to do at work on the lift (takes too long and our service director is touchy about non-service personnel tying up the lifts) so it will likely be in my friends driveway, rolling around in the snow that hasn't yet melted away, and probably won't before next weekend. Cracked runners in the sunroof, yeah that's a good way to ruin your day. I'd try for a junkyard unit. I wouldn't figure on spending more than a couple hundred bucks for the whole thing from a yard. Probably less from a U pull it place if you can find one.
5mt transmission swap 01 LOB
Fairtax4me replied to Tahoe Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to determine ratio by checking the option code on the number plate under the hood. For the 2004 models (closest year I could find a manual for) code EC, EK, or K4, Outback with 2.5 will have a 3.90. Code KA outback 2.5 will be 4.11. OR if the label is still on the rear diff, check there for an ID code. Again these are from a 2004 manual but I can't imagine they would be different seeing as the body style is the same. Code ratio LSD XJ 4.111 None T2 4.111 None VB 3.700 None EZ 3.900 Viscous XU 3.272 Viscous CF 4.444 Viscous XT 3.083 Viscous JE 4.111 Viscous
Whirring noise in rear
Fairtax4me replied to Subaru_dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the fluid in the diff first for sure. It doesn't sound good but a fluid change may help. It uses just shy of a quart of fluid so a change is cheap and easy. Thank the genius designers at Subaru for putting a drain plug on the thing! My Lincoln has a similar style mounted rear diff with no drain plug. Draining requires either a fluid evacuator or nearly removing the diff to get access to remove the cover. Catch the old fluid in a clean container so you can check for metal shavings. More than likely it will have some. Most of the time some of that is OK, but if it looks like liquid silver, you have some real damage going on inside and should replace the diff.
Fairtax4me replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA short lesson on "Black rust" that I found. Pretty interesting stuff. Found in nature it's known as Magnetite. Easily synthetically produced by mixing sodium hydroxide and Iron. Apparently it inhibits formation of regular red rust, is used in cosmetics for black coloring, and inside TV tubes. Assuming that these people know what they're talking about. http://www.finishing.com/95/49.shtml And then there's some stuff on Wikipedia, which should always be read with a grain of salt. http://en.wikipedia.org/wiki/Iron(II,III)_oxide If it inhibits further rusting, maybe you should leave it in there?
repair or replace?
Fairtax4me replied to griffenrider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can find much better prices for OEM parts if you look online. Subarupartsforyou.com lists the converter set for $799, and they offer an aftermarket set for $499. http://www.subarupartsforyou.com/cp_partlistbymod.php?model=Legacy&subcat=Exhaust%2C+Converters&year=2002 Depending on where you live it may be worth it to order online and have the parts shipped, but not always. The converter is a fairly straight forward replacement if using the O.E. part. Unbolt the old one (usually easier said then done, I usually just cut the old bolts off and replace with new ones) Then bolt the new one in place with new gaskets. You may have to swap the heat shields, but that isn't too difficult once you get it off the car. Sunroof problems are... well just that. Most of the time unless there is a problem with the track (broken cable, worn guides) there is no reason to replace the entire unit. If it's not draining properly it usually because the drain tubes are clogged or not connected properly. There is a gasket around the glass, and the glass itself can be replaced usually. Perhaps you should consider that before opting to replace the entire unit. How did you come to the conclusion that the drains are not at fault?
Pic request, Flywheel locking tool
Fairtax4me replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's Kent-More tool prices for you. Really nice tools though.
Engine is clacking clacking and clacikin
Fairtax4me replied to legacysubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell first you have to find which one it is. Hope for your sake that it's just the one for the rocker shaft. Usually removal of the rocker shaft will reveal the culprit and it can be flushed out with air or spray cleaner being fed from the opposite direction of normal oil flow. At worst you'll have to stick a piece of wire in there and try to dig it out. I'd remove the oil pump and reseal it with anaerobic sealer. It doesn't dry the same way that RTV does so it won't clog the oil passages.
Fairtax4me replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a triangle file and try that? I've had to deal with some pretty rusty hubs living here but some of the horror stories I read on this forum are just insane. Using any kind of high temp grease or anti seize is better than nothing. Hell I bet even thread lock would work!
so has aney one used the copper head gaskets?
Fairtax4me replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWut elts u expek us 2 learn in skoo We knt all B geenieuss lyk U
95 Legacy EJ22 losing coolant
Fairtax4me replied to q959fm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems like the fix for that would be to fill it with RTV. Or cover the O ring with Indian Head before installing it. I will remember to check that on mine when/if I ever get around to pulling the engine.
Fairtax4me replied to legacysubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you use RTV sealer on the oil pump? That stuff has been known to cause trouble by plugging up the incredibly tiny oil holes in the rocker shaft. The ones that feed the lifters.
Strong smell of exhaust
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm. I would expect a bit higher than that on the highway. But terrain, load, altitude can all make that change. Among other things.
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah checking the condition of the plugs might tell you if it's running rich. Do you have any idea what kind of fuel mileage the car is getting? Any complaints about driveability or rough running? What is the exact code you're getting?
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGarage with the door open or closed? The O2 sensors don't do anything until the ECU comes out of open loop. They don't work at all until they reach about 600°F which is pretty hot. Certainly not going to be that hot immediately after starting. My 96 will make you choke on a cold start if you try breathing anywhere near the back of the car or have to back up into the cloud of unburned fuel that pours out of the back of it. But I still get 30+mpg on the highway (got 33 on the last trip) so I'm not too worried about it running a little rich on cold start. My best guess would be a faulty coolant temp sensor if anything. Those can generally be tested with an ohmeter if you have a known good one to compare readings with at the same or similar temperature. A scan tool is ideal for that. "Strong" is kind of a relative term. If you're used to smelling 4 cyl engines at startup, a 6 banger is gonna put out 2 more cylinders worth of exhaust under the same conditions. I like to figure roughly 50% more depending on displacement. So maybe a 6 cyl is just strongER smelling than a 4 cyl...
Sirius in 2010 Outback
Fairtax4me replied to MtnBikerChk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are generally only available for popular head units. You can get some that are direct link and some others that use a transmitter similar to the remote for the head unit. The direct link ones are the way to go if the head unit you have is compatible. If you just want steering wheel controls some companies make little remote that fit on the wheel and work fairly well. Similar to this: http://www.rainbowappliance.com/CDSR100.html?utm_medium=shoppingengine&utm_source=googlebase&cvsfa=673&cvsfe=2&cvsfhu=43445352313030 Just find one that will work for the head unit you want to buy. Much cheaper than buying a wheel with controls and an interface to connect it to the head unit. Also a ton easier. The buttons in the wheel probably won't work unless you swap the clock spring with it. Then you have to figure out wiring...
Fairtax4me replied to MtnBikerChk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe steering wheel interface adapters are SO worth it! Once you get used to using those buttons on the wheel you just can't go back to reaching for the volume knob on the dash.
Fairtax4me replied to q959fm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThermostat gasket or water pump. Try the gasket first, it's much easier. The buildup on the drivers side of the engine is oil residue. Hit it with some degreaser (purple power works pretty good) and spray it off with a water hose. I'd bet on the valve cover gasket there, but it's nothing to be too concerned with, it's a Subaru thing.
