136
abs light
Fairtax4me replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There are scanners out there but not all will read every car. I had my eye on one made by Innova. But you can expect to pay upwards of $200 for them. And I still can't find if they will read Subaru codes. I think there is a way to get the light to flash the codes. Try searching the boards here, I'm sure it has been posted. It may even be in the USRM. -
Sounds like a worn cv joint. Which side or sides did you have replaced, what brand of parts did you use, and were they brand new or re-manufactured axles? Unbalanced tires don't generally make noise or shake until the car is rolling 35-40mph or higher. If this is from a dead stop I'd say it's either a CV joint or a U joint or carrier bearing/bushing.
Chances are the used compressor was near failure in just the same way yours was when it went to the yard. Rebuilt compressors are big gamble. Generally what gets replaced is only what's actually bad. Your best bet for longevity is brand new, or a reman with a warranty. But most reman compressors with a warranty require replacement of the condenser, evaporator, and accumulator at the same time so there is no chance of debris (dirt, metal shavings, oxidation, etc) getting into the compressor and destroying it. That can get quite expensive, so unless you really want to spend $1,000+ on renewing your entire ac system, stick with the used parts.
I saw that one while I was searching. I like it but I'm not sure if I want to make a replacement bumper or something that just fits around the outside. I'm also not sure how I would mount the thing. I looked behind the bumper cover on my car and it looks like the reinforcement is actually fiberglass/plastic. Which is nothing unusual, but it means I can't mount it to the existing reinforcement, I'd have to make something that will mount directly to the frame instead. I need to remove the front bumper cover anyway to fix up some ghetto rigging that was done by our wonderful body shop when it was in there a few years back for a front end collision. I think it's only attached by 3 screws right now.
Handy I am, with a welder, not so much. The most I've done with a welder is burn a hole through the pipe trying to weld an exhaust hanger back on on my old Toyota truck. Though it would be fun, and certainly cheaper to custom fab something, I have no clue what would be best to use, nor where to get it.
So here's the deal. I've hit two deer in the past 3 months with the soob. Not hard, I've been fortunate enough to see them coming. The first one broke a tab on the passenger headlight and put a shallow dent in the end of the hood and fender, and broke one of the clips that holds the bottom of the grille. The second bounced off with no visible damage, except for breaking the same clip on the grille, which I had just replaced after the first encounter. So I just know the big one is coming. I put a grille bar on my truck and within a week I popped one good that would have surely gone through the grille. Now I know there are decent bullbars and grille guards for the Legacy, but are there any that won't cost me $2,000 to get it? I would LOVE to have an ECB bar like this one: http://cgi.ebay.com.au/SUBARU-OUTBACK-BULLBAR_W0QQitemZ220526086308QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item33586108a4 but I'm not paying 5, 6, $800 or more JUST to ship it across the pond from Australia. Does anybody know of a closer (in the U.S.) source for a decent bar that will keep the deer out of my radiator and away from my headlights? (and not cost $2,000 like the Subaxtreme bars, even though it would be sweet to have it, I don't see buying a grille bar that costs more than the car is worth)
Now honestly, what's wrong with good old stainless steel from your local hardware store? I bought screws from the local chevy dealer once. $70 for 14 screws for a flywheel and pressure plate. I could have had the same things in grade 8 steel from the hardware store for less than $5, but I was young and stupid.
Harmonic balancer. My ej22 has it, I'm not sure which ones should have it and which ones didn't but I've seen a few that are one way and some the other. Crank but no start. Do you have spark? Id suspect damage to the Crank angle sensor, but a broken belt due to debris getting in under the belt isn't out of question. Got a scanner you can hook up to see if you have any codes?
That's part of it. The main thing is atomization of the fuel, which makes a much cleaner, more efficient burn. Direct injection uses a MUCH much higher line pressure, in the 1,200 - 1,800 psi range (some even higher maybe), whereas port injection is around 35 - 70 psi in most applications. The Mercedes Benz new Bluetec common rail diesels with direct injection run over 20,000 psi.
Yeah they're two entirely different beasts. I've been picking up some info about diesels here and there from the techs at work. I always wondered why diesels don't make vacuum, why you have to have a separate pump for vacuum driven parts such as the brake booster and engine shut off valve. I was watching as one of the techs disassembled the top end of one for a head job and finally noticed it had no "throttle body". Technically it does, but not in the same sense as that of a gas engine. Running lean is bad for gas engines due to the nature of the combustion of gasoline. A leaner mixture is a hotter flame. While it does make more power, (to a degree) it will eventually lead to hot spots in the combustion chamber that will act similar to a glow plug on a diesel. The thing about detonation is, most of the time it is due to high temperature in the CC, an overheating engine will start pinging like there's no tomorrow. But it's a snowball effect. The higher pressures created in the cylinder by the detonation make the CC temperatures even higher. At some point some some part part of the internals (exhaust valves most of the time, or carbon buildup) will start to ember (glow) and a hot spot of that nature can ignite the fuel as it enters the cylinder during the intake stroke. That means near instant death for a gasoline engine. You might get away with that once. What happens is the ignited mixture is already extremely hot, add to that the pressure created by the compression stroke. That can drive the CC temperature well upwards of 3,000°F which is enough to instantly melt a hole in the top of the piston. http://www.aa1car.com/library/piston_preignition_damage.jpg
The ECU can and does adjust timing to a degree. But it's not always ignition timing that causes pinging. Fuel quality, air quality, air density, air temp., combustion chamber temp., and many other things can affect the way the mixture ignites, and how stable it is before and after the spark plug fires. Pinging/detonation occurs after the spark plug has fired. So there is heat and pressure building in the chamber which causes the mixture to burn unevenly and/or cause spontaneous combustion in another area of the chamber. These two separate events cause a rapid pressure spike in the chamber which creates a sound wave that resonates through the block and internals of the engine, similar to that of a hammer strike. Funny thing is that it's an almost mechanical function of internal combustion. No mater what size the engine is, or who made it, the sound produced by detonation, though not always audible to human ears, is always the same frequency. The basic underlying cause is an unstable/incorrect fuel:air mixture for the conditions that the engine is operating under.
So is that to say that a filter does not catch any of the smaller particles until after it has filled with the larger ones? Yes filtration does increase due to the gaps in the filter becoming smaller as particulate is captured. But I don't agree that a good quality filter is not designed to work as effectively as possible from day one.
A larger filter means more filtering media. You'll get less of a pressure drop through the filter at higher rpms, and increased flow which is good for the bearings and whatnot. K&N filters are generally larger than OE parts, and they also have tighter filtering tolerances. Plus a nifty 1" hex spot welded to the can for easy removal. Although I don't see the point, because if the filter is installed correctly you should be able to loosen it easily with your bare hand.
