pulls right by design?
Fairtax4me replied to turin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCars tend to pull one direction or the other because of the grade of the road surface. Roads are not flat, they are higher in the center and lower on the sides so that water will drain away when it rains. (supposed to be at least) This causes cars/any vehicle with wheels to drift to the lower side of the grade. If you're right of center it will drift right. Left of center, drift left. A drifting problem which slowly develops over time may be an indication of more drag in the driveline on one side. Bearings, brakes, tire pressures maybe. Even normal tire wear can affect driveability. I kind of assume that you've checked the tire pressure in all 4 tires with a known accurate gauge and made sure it is at factory spec. If the roads in your area are rough (potholes) then drifting to one side or the other is something you'll have to learn to live with unless you plan to get it aligned once a month.
My Legacy 2.2 has started interfering??
Fairtax4me replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe intake valve should not be opening at TDC. TDC refers to the number one cylinder being at the top of the compression stroke. All of the valves for the number one should be closed, and they should not be opening until the cam has moved about 1/4 turn. And it should be the exhaust valves opening next, not the intake. So your cams are off by a half turn. As a matter of fact, it would, slightly. Shaving off the block or heads would essentially move the cams inwards closer to the crank. The distance between the teeth on the timing belt is what 3/8"? There's no way you can cut 3/8" off the block, or the heads, probably not even if you did both. So the number of teeth on the belt between the crank and cam pulleys would be the same, but the distance from the crank to the cam would be shorter, the only way to account for that would be to turn the top of the pulley away from the engine. It would change the angle of the cam slightly, which would then change when it opens and closes the valves. A slight change, yes. Is it enough to matter though? That in itself would probably not make enough difference to let the piston hit the valve, but the head/block being shaved might.
Planning to buy Legacy, looking for details
Fairtax4me replied to Vermonter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt may run like crap (misfiring). White, sweet smelling smoke in the exhuast. There might be foam/ bubbles in the coolant when it is running. Coolant might be dark green or brown in color. There might be oil in the coolant. There might be coolant in the oil. (looks like chocolate milk) There could be coolant dripping from the bottom of the engine nowhere near any hoses.
Wheel bearing preload set by axle nut?
Fairtax4me replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere should be a step that sits against the outboard inner race. Otherwise it might be pressed on too far and the hub would rub against the outter race. Then with no room to get a tool between the only way to remove the hub form the bearing would be to destroy it because the outboard inner race would be pulled out of the bearing assembly. The axle nut should not affect bearing preload on this type of setup unless the hub was installed incorrectly. Are you sure the movement wasn't because of a worn ball joint or tie rod end? Were the lug nuts tight or just snug enough to hold the wheel on?
Rear EJ drum brake question from a noob
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure the squeaking is from the rear? Drums don't usually squeak unless they're really hot or the shoes are worn out. If the shoe material is riveted to the backing plates it may be time to change them.
know whats wrong?
Fairtax4me replied to timfreddo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry searching for Torque Bind and see if it sounds like what you're having.
2001 Outback Check Engine Light-Catalytic Converter??
Fairtax4me replied to Mikle48's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBG 44K is a super strength fuel system cleaner. It mainly cleans fuel injectors, intake ports/ valves, and combustion chamber carbon buildup. If one can doesn't fix the problem then stuff has to start being replaced. I've never heard of it helping a possibly bad catalytic converter. To continue to use it is just a waste of money. At least your fuel system got a good cleaning out of the three cans you did use. So is the O2 sensor... But instead of creating cleaner exhaust it creates a small amount of electricity. I'd change both O2 sensors. Recommended change interval for those is usually 100k miles anyway. What other maintenance have you had done recently? Has the fuel filter been changed? Spark plugs? Plug wires? Coolant flush? Anything like that?
transmission removal
Fairtax4me replied to DupermanDave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think you'd be asking for trouble doing that. No doubt it would work, but when it pops loose what's it gonna hit first? You also run the risk of just pulling the car off the jack stands. Be absolutely sure you get all of the fasteners out and work your way around it with a pry bar. That's the best and safest way.
hi-lights do not work
Fairtax4me replied to jdmwerx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVolt Ohm Meter. also knows as a multimeter or volt meter, or that fancy dohickey that tells you the voltage.
a/c shuts off intermitenly
Fairtax4me replied to jdmwerx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you set it on the coldest setting does it do the same thing? Some systems will cycle the compressor more often if you put the temperature setting in the middle. Others will move the actuator flap and allow some warm air to bypass the core to control temp.
Fairtax4me replied to jdmwerx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably the dimmer switch. Do you have a VOM?
Fairtax4me replied to jdmwerx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe compressor has to turn off periodically to defrost the evaporator core. Otherwise it would cover with ice and no air would flow across it. No air flow = no AC. It also cuts off when the engine is revved high. The pressure in the system builds as the compressor turns faster. If it gets too high it can blow the lines apart. So to protect the system from damage the compressor cuts off until the engine RPMs come back down into normal operating range.
Fairtax4me replied to DupermanDave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only automatic transmission that I've ever pulled, didn't go back in the car. Engine/transmission separations are kinda hit or miss. Sometimes they fall apart on their own, sometimes you have to fight it for an hour with prybars big enough to lift a house with. The biggest thing is just to get a gap started. Once you get that you can work your way around the bell housing with a screw driver and slowly pry it apart.
MAF sensor or... ?
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell it ran for about 35 or 40 minutes. Didn't cut off once. Drove it all around the lot at work a few times, it wasn't happy to be driven, but it didn't ever cut off. Killed it and hooked the MAF back up, ran for less than a minute and died. That's the proof positive that I've been looking for.
TY752VA1AA transmission - The mystery is gradually clearing up!
Fairtax4me replied to casm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could take it apart and measure the size of the gears. Or try to get in touch with Subarus technical help.
Axle Replacement
Fairtax4me replied to sussman00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I'd say at least a new bearing as well. Pop the axle out and spin the hub by hand and see how it feels. I believe the bearings have to be pressed out of the knuckle. Take the whole knuckle off and take it to a shop with the new bearing to have it pressed in. They might charge you 40 bucks to do that real quick. To just take the car to a shop and have them do the whole job you're looking at maybe 3 or 4 hours labor plus parts. The clamps that hold those boots on are kinda finicky. If they're not installed tight enough or in just the right place they can slip loose just from turning and fall off. And sometimes things like that just tend to work themselves loose with time. Hard to say exactly.
Axle Replacement
Fairtax4me replied to sussman00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it has been making noise then a replacement is certainly the best route. Noise means that dirt and rocks have gotten in there and are chewing up the bearings so there's really no saving it at this point. Don't waste your time with rebuilt axles, buy a brand new one.
Axle Replacement
Fairtax4me replied to sussman00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKinda hard to tell how long it has been that way. If you're sure it just happened it would be fine to just clean it and repack it. It kinda looks like there is some grit stuck to the housing though so its kind of a tough call. Do you live on a gravel road?
MAF sensor or... ?
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA thought just struck me. I've spent all this time on trying to figure out what's been causing this problem. It never crossed my mind to just unplug the MAF and take it for a drive. I know it runs with the MAF unplugged, but I never thought to just let it sit and see just how long it would run. It makes too much sense, so I'm gonna do it tomorrow and see what happens. If it dies the same way again, then I can start looking elsewhere. If not, then I'll know damn well that its the MAF and I can rest assured that replacing it will solve the problem.
check engine light on, knock sensor
Fairtax4me replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the engine pinging any? Any signs of mice taking shelter under your hood? (random fuzz sticks or straw stuck in corners)
1997 Outback Sport Impreza - Sad Tale
Fairtax4me replied to Balewolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood to know. What changes did they make to it that made the difference?
Engine miss fire and cut out on start up
Fairtax4me replied to mr.ed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like our Saabs do when the plugs get fouled. Take it to the dealer, make them keep it until they find out what it is and fix it. If they won't do it, take it to another dealer.
AC Valve Core Leak
Fairtax4me replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a section of small tubing and cut a notch in the end of it. Instant valve core tool. I've had several of those that were just loose, a little twist and the leak stopped.
Fairtax4me replied to Balewolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom what I understand, all of the EJ22 motors are non interference. I'm a sewb newb though so I may be wrong. I believe the engine ID tag is dead center on top of the block at the front. Get the numbers off that and post them.
subaru head gasket replace fallowed by trouble
Fairtax4me replied to littlecars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXId do a leakdown test. That will tell you exactly what the problem is if it's compression related.
