136
Air mixing flap is broken or stuck, or the cable has fallen off. Look under the dash, passenger side, and slide the hot/cold lever/knob back and forth and you should see a cable move. Make sure it's attached to the lever for the mix flap. Lever is usually white plastic. If the cable doesn't move, its broken or disconected from back of the HVAC control head. If cable does move, disconnect it and move the lever by hand. It should only move about 1/4 turn, and you should hear the flap as it slides and stops against the inside of the case. If it moves more than that or feels like its very loose, the flap is broken inside.
- 1 reply
- 2
Super tack gasket sealant may hold it. Have to clean the seal area very thoroughly before applying. Not sure why an OEM seal won't stay put. I've almost always been able to push the seals in by hand, but with some difficulty, and coated in ATF or fresh oil. Never had one pop out. Possible the cap is stretched, or someone went to town in there with some sand paper trying to clean it out.
Fuse grounds the TCU circuit. Key On, Check at the fuse connector for 12v or maybe 5v on the black/Red wire. If no voltage there's a poor connection at the TCU or break in the wire between the TCU and Fuse connector. That wire sruns straight from TCU to the fuse, so not many places where damage or poor connection can occur. Insert the fuse and check that the voltage drops to 0 or very near 0. If voltage stays high the ground for the fuse is dirty/corroded or ground wire is damaged.
They're so easy to change, its not necessary to change them during a belt job. One thing I do make sure of, is that the crank sensor can be easily removed from the oil pump housing. The housing corrodes and can cause the sensor to get stuck, and often requires destroying the sensor to get it out. I always make an attempt to remove the old sensor, clean the bore and apply antiseize to the sensor and bore, so that IF it goes bad its easy to change. If the old sensor is stuck, leave it alone.
Don't need anything extra. Some people replace the front mounting bracket that the trailng arm attaches to, but it's not necessary if you're just doing a strut lift. Disconnect the sway bar links so you can push the control arms and knuckle down when attaching the strut to the knuckle. Now is a good time to flush your brake fluid, if it hasn't been done recently.
For a Non-turbo engine, no reason at all. Higher octane Might get you an extra MPG or two if you drive with a heavy foot, but its usually not worth the cost. There are usually more detergents in higher octane fuel that keep things like injectors and valves clean, but you can simply add a bottle of fuel system cleaner once every 3-6 months and accomplish the exact same thing. I buy the quart size bottle of Lucas fuel system cleaner when I can find it on sale and use about 3 ounces in the tank every three months or so. Between the 4 cars I maintain for myself and family, a bottle lasts me about 9 months. I got it last time for about $12.
Sounds like lifter noise based on the description. A half quart of MMO should clear that up. If it doesn't, the rocker shaft assemblies will need to be removed and cleaned, and the lifters cleaned and bled. Its a weekend job for a DIY mechanic, only because the parts are small and takes several minutes to clean each of the 16 lifters.
Don't know what cam switch bank 1 is. If you got a code for it, post up the actual P0 code number so we can look up Subarus definition of that code. If you have a code for the cam sensor, it's probably the cam sensor. Make sure it's plugged in tight and there's no dirt in the pins. Coolant temp sensor could be possible, but usually takes a longer cool-down.
Subaru does specify an orientation for the jiggle valve even on non-turbo engines. Its either straight forward, or straight back, but I don't remember which off-hand. I'm not sure it makes a huge difference, but the wax pellet is offset from center on the thermostat, so correct orientation of the jiggle valve can make a difference in temperature regulation.
I would guess the booster has failed. In your other car, start the engine, release the brake, then turn the engine off. Press the brake pedal 4-5 times and you'll hear it whoosh a few times and the pedal will start to get harder to push. Do the same test on your 98 and if the pedal gets hard to push sooner, the booster is bad.
The technical term is Roll connector, but yes, clockspring is the typically used term to describe the ribbon cable that connects the airbag cruise control and horn wiring through the steering column. Its a ribbon cable wound around about 6-10 times inside a housing, so it looks similar to a clockspring inside. If you're having trouble with the drivers seatbelt connector, that could be the source of your problem. Pulling the airbag codes will tell you for sure.
