teppichkopf
Everything posted by teppichkopf
cook out in frederick md.
teppichkopf replied to subyrally's topic in Meet n' Greet. Your USMB Welcome Center
Work schedule will determine. Won't know till Friday. Hope I can make it. -
The boot is newly installed with the axle. Work was done by a local garage. Seems like they could have done a better job making sure it was seated properly.
Are CV boots designed to work only if they are in the "accordian" position? If one of the ridges was out of place and sticking down where it should be sticking up, could this cause premature tearing/wear?
Think of the ridges on a CV axle boot. Would the following shorten the life of the boot: One of the ridges is pushed down. It's like there is a vacuum inside the boot and when the ridge is pulled out into the proper position/shape, it sucks back down. Seems like the design of the boot requires that all the ridges should be the furthest from the axle as possible.
If I don't have to work I can make the 10th. -
A cheap solution you can try is transmission fluid additive. I've heard mixed results from these products. But they work for some situation. ie, ease rough shifting, add a few more months life to transmission, etc. There's lots of companies that offer products. Try looking for Lucas products Transmission Fix.
Can't do the 3rd. Possible I could make the 10th. Will stay tuned for updates. -
You have any dates in mind?
