lastchance
Everything posted by lastchance
naru was right... he said vacuum/unmetered leak. the intake boot from the air flow meter to the turbo was not only cracked on the base but the entire middle section was COMPLETELY ripped, almost completely in half. i was worried when i noticed oil at the base of the boot, thinking that something was dying, but nope... just the boot itself completely ripped apart. haha! will the intake boot from an ea82t fit? i assume it's the same part???
for fuel injected cars a vacuum gauge like this is still useful, correct?
and as for the miss/rough running, here's the exact sequence: in park and idling while cold - fine in park and idling while warm - okay, but will randomly idle low and die in drive and idling while cold - fine in drive and idling while warm - bad, will idle low and die. when on the throttle (driving) a misfire develops, car runs rough all through the power band (gas is constantly manipulated to keep car running while warm, while in park or in drive)
good deal. i have a propane torch that'll do the job. i've actually noticed some excess oil seepage around the intake plenum and had recently replaced the PCV valve, i seem to remember the hose being really fragile and/or cracked back in that area. inside diameter on the PCV valve hose should be 3/8" or is it 3/4"?
Vacuum check? You mean for leaks, right? I just did the other day and was pretty convinced that was part of my issue... I sprayed starter fluid around all the vacuum connections (while running, on a cold engine) and didn't notice any real changes in idle. It definitely starts strong, idles perfect when cold but once the engine temp starts to come up it runs really poor.
round knock box plug? is that one of two right above the air flow meter in the engine bay? those are the only two round plugs i can think of. i'm beginning to think my issues are mechanical since i've diagnosed almost all of the trouble code issues over the last few months. do you think a compression check is in order?
good deal, thanks.
how easy was it? pics of the setup? did you have to fab new/different brackets? what car did this go into?
