sube4x4
Everything posted by sube4x4
  1. I was told that the timing belts had just been done when I purchased this car. I believe the guy still however, I think thats all he replaced. The right side tensioner is to blame for this. The bearing seized up and melted the belt. I did not here anything come from the engine that sounded fatal but i'm not sure if you would?? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400077536007&viewitem=&sspagename=STRK%3AMEWNX%3AIT This is the kit I ordered. Has anyone ordered from them? If so how's the quality? Thanks for any input. -cody
  2. Is there supposed to be a fourth link on the left side? Seems like there should be to me... thanks for any help -cody
  3. Yep. Broken belt. thanks for all the help. -cody
  4. I was driving to Longbeach today and as I pulled up to a stop light the engine promptly shut off. I pulled off to the side of the road and and went straight for the coil. I had my girlfriend crank the motor as i held the coil wire just off the coil to check for spark. No spark. So I got the multimeter out and started testing. I measured roughly 10 volts at the negative terminal of the coil and at the positive terminal. I then measured the output where the coil wire plugs into the coil and measured about 2.2 volts. Then I measured the resistance across the coil and got the suspected 1.3-1.4 ohms. I then checked the fuse box and found no blown fuses. So i've come to the conclusion that the problem is before the coil in the ignition system. I'm not sure where to check? The ignition switch maybe? Any help is greatly appreciated!! -cody
  5. I've been searching around on here for awhile but can't seem to find the answer i'm looking for. I'm gathering parts for an EJ swap into my 86' loyale. I picked up up a turbo 89' loyale today for some various parts. I know i'll need the FI fuel pump from the 89' but will I need the fuel lines too? Is anyone running the stock carb fuel lines with an EJ? Should I just buy all new fuel line? Thanks for any help. -cody
  6. Have you personally been to any of these trails? I'm used to muddy trails and deep ruts in dense forest. It sounds like we may be doing some wheeling in the coming days. -cody
  7. Like GD said and also try grabing the upper cup and pulling up and down on it. Just before my last transmission blew the output stubs had an extreme amount of play in them. Just my 2cents Good Luck -cody
  8. I've heard some mentioning of "exit 38" around here and was curious to know if this was exit 38 on I90? I was heading over to Cle Elum to view a house to move into and we were driving across I90 and I saw exit 38 one mile. Its roughly 50 miles from a house I may be moving into. So some clearification would be extremely appreciated. Maybe even tell me a couple things about exit 38? I've sold my hardcore wheelers that were covered in dents but i don't mind doing a little wheeling in my newer subaru. thanks all:) -cody
  9. Yes, however it will also make it harder. This is the method used to make swords a long time ago. Hard=brittle and less malluable. Vise-Versa. Being an experienced TIG welder. If it were say 304 stainless it wouldn't make a difference. Good Luck and don't blow your self up. -cody
  10. I'm moving to the Cle Elum area in a couple weeks from the Portland area and was wondering who lives near Cle Elum? Say, within 100 miles. -Cody
  11. You said you had access to a TIG welder? Just weld something onto the broken stub. Such as a piece of bar stock or some scrap. -cody
  12. I saw this picture a long time ago and was going to do this to my last subaru (2nd GEN) but then i sold it before i did. The 3rd GEN doesn't have that convenient ground strap bolt there dang it! -cody Yes, it is grounded to the bracket i attached it to. Tomorrow I will try grounding it with a wire to the engine as i have it grounded to the body now. Maybe a bad engine to body grounding strap? Do you think maybe if i have it mounted upside down to what McBrat has shown in his picture could be the problem? Mine is opposite of his. I wouldn't think it would affect it as it is pressurized. -cody
  13. I'm relocating my sending unit on my 86' loyale and i'm having trouble getting it to read any pressure on the gauge. I started the car and loosened the fitting closest to the sending unit and bled all the air out of the line and i still can't get any pressure to the gauge. I measured wire to the sending unit and it had voltage. Also my oil line is about 48 inches long. Could the extreme length be the problem? And help will be greatly appreciated. -cody
  14. Anybody going to be out there this weekend? -cody
  15. It also depends on what Gen brat you have.... Theres a big difference in the wheel well size between the first and second gen brats. -cody
  16. I'm out. I'm in the middle of building some bumpers and rebuilding a winch. -cody
  17. Just start the car and let it idle and start pulling lines. You'll find out which ones are important! -cody
  18. Sounds good to me! Count me in. -cody
  19. Exactly what GD said. I've got swampers i only run when i'm going wheeling other than that they just sit in a stack. Not to mention the horrible gas milleage they'll give you. My DD tires are BFG AT's they do good on ice and sand. Also some drier trails they'll do pretty good. Just my 2cents. O ya i fit 29" swampers on a 1980 hatch with zero lift :grin: It was cheap n' easy. -cody
  20. Just playin around out on some logging roads near my house. -cody
  21. This is the newest one and by far the nicest one that i own. Mods are: 4" SJR 27" BFG AT's Allied Armament wheels 15's Yakima rack Stock ea82 with D/R 5 speed New cat back with flowmaster Alpine deck with 4 Focal speakers Cobra CB Soon to come mods are" Tube bumpers front and rear 10,000lb winch Window tint 20% LSD if i can find one GM100 amp -cody
  22. Some friends and i are gonna be heading to sand lake saturday and going to camp out till sunday. So just letting everyone know there will be a few subaru's down there so please tag along with us. -cody
  23. Make sure you get the bolts that go through the body on either side. Just look under the car...... -cody
  24. dwuollet- Have i seen you around town before? -cody
  25. Yes very true. The part that really attracts me towards the car is its all done and exactly what i wanted to build. Its even the color i wanted. And at this point i'm really pressed for time so i can't exactly build a car up and i'm in need of a better vehicle than i'm currently driving. -cody
