Everything posted by Setright
If you're going to try and force your way through a big pile, select a low gear, and don't touch the clutch. If you are just crawling and disengage the clutch, you will get stuck. Keep moving! You also need to be careful about what could be hiding underneath all that snow. Road signs, stones, other cars....
Okay, but please be patient : In April, I noticed some coolant spillage around my expansion tank. YIKES! Thought about HG problems.... Went for a drive, stopped with the engine running, popped the hood and sure enough the expansion tank was full to the brim, and the air hole was letting coolant escape. No bubbles. A quick check on the upper rad hose: It was soft and easy to compress. SO, I deduced that there was no pressure in my coolant system, hopefully due to a bad cap. A few days later, a new cap solved the problem. I note down my mileage during my working hours, because I get a certain allowance per mile. Sometimes, I switch off the engine before I note the mileage. Since the odo only shows up on the LCD with the key in "ON" I need to swing the key back to read the mileage. That's when the temp needle also resumes its readout. My hawk like eyes had noted that the needle was returning to full op temp. I thought it was a warm weather thing. However, after fitting a new rad cap, the temp needle ALWAYS stops short of full op temp after the engine has been switched off even for a short while. SO, it's not a BS theory, it's based on real events. Theory: The pressure in the cooling systems ensures a good contact between coolant and walls, this allows enough cooling to let the temp needle drop after a short switch off. With no pressure in the cooling system, the temp stays higher for longer. It also means risking local boiling inside the engine block, which must be a sure-fire way to stress HG's. The scary thing about rad cap failure is that it doesn't leave many clues. No overheating on the temp needle, just a slow loss throught the expansion tank - which I only noticed because I open the hood at least once a week!
Is there any trace of coolant spill around the expansion tank? If so, your problem could be as simple as a faulty radiator cap. With the engine running at normal operating temp, switch off. Then wait one second, turn the key back to the "ON" position and watch the temp needle. If it rises all the way back to normal op temp, your rad cap is bad. The needle should come to rest just below normal. (All this from the comfort of the driving seat!) OR: I was recently losing a similar amount of coolant, and I could not figure out where it was going!! Turned out there was a TINY leak where the upper rad hose connects to the engine. Most of the time, I reckon the coolant was getting out as steam, but after a 500 mile motorway journey, I noticed the dreaded smell of coolant. There was a small puddle on the engine block below the hose. Took the hose off, cleaned and sanded the coolant pipe, put a new hose on and the coolant level is steady.
New member
Setright replied to bneal1950's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Drive for a while and it'll learn all by itself. A reset won't hurry things very much. Within about a tankful of gas you should find the ignition getting more advance and the engine pulling a bit more decisively above 4000rpm. -
Piston Slap
Setright replied to Tubeamp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The tech papers from Subaru on the EJ engine series - from 1989 - mentions pin offset to "balance" the forces. Maybe they forgot on newer engines?? My 2.0 EJ201 slaps, too.
