Everything posted by Setright
Piston Slap
Setright replied to Tubeamp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXErmm, Nipper those forces are "absorbed" in the bearings, crankshaft, and crankcase, not cancelled out. The boxer/flat design only means that the engine vibrates very little - pulls smoothly past 6000rpm.
15 inch wheels
Setright replied to stephen m's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWait a minute! What size brakes do you have? The "two-pot" with the 277mm discs will just fit inside the stock 15 inch alloy rims. Any bigger brakes and they won't go. Plus, be wary of the clearance on some 15inchers.
Clouds of smoke....help....fixed I think.
Setright replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, start with the PCV valve. Again. White smoke is almost certainly water, and MAYBE the PVC is pulling condensation from the crankcase and causing the engine to steam. A leaking head gasket - God forbid - would produce a lot of smoke for a very little amount of coolant, so it would take a while to notice a drop.
buzzing sound with ignition on, engine off and depressed gas pedal
Setright replied to friendly_jacek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour ABS pump can make buzzing noises too. Normal test procedure.
what type of fuel should have
Setright replied to acidebath's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, it's an EJ 18 :-)
Setright replied to acidebath's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRON 90 or above.
This year's snow tire thread
Setright replied to langosta39's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlizzak LM18. Works for me ;-)
Aww CRAP
Setright replied to Spazz698's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe coolant has probably left the system "backwards". Compression and cumbustion pressure finds its way into the coolant channels and forces the fluid out via the expansion tank. It'll drip out the vent vent hole and some of it will blow off as steam. Just a little at a time....until the temp rises.
Theory on why they made the TriBeCa.
Setright replied to TheBrian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe often misjudged "halo effect". I like it.
Grounding Mod Re-visited **56K Warning**
Setright replied to Lawsonmh15's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInspired by this post, I opened and cleaned all my grounding points. Used a glass fiber brush to clean the contact surfaces. Must say, they were all pretty clean already, but it still feels like a good thing to do. Only corroded one was behind the headlight. Lawson? Do you apply any form of electrical grease/sealant to the contacts? I am tempted to run some proper wire directly from the alternator. How could the factory leave this out?
2001 Forester Catalytic converter gaskets
Setright replied to jlawlor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX40ftlbs sounds good.
Aww CRAP
Setright replied to Spazz698's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDang it! Well, 267k on a set of HG's aint bad. Flushing the coolant system is probably done best by filling it with a weak "Coolant flush" additive solution. Holts makes some good stuff, but there are a bunch out there. Use only half the amount recommend on the bottle - no need to chew your engine up. Rinse at least twice with tap water. Demineralised water won't take as much detergent out as tap water. Of course, you need to replace the HG's first, or the flush will be futile. Please search the board for "coolant replacement without bubbles" if you feel like reading my essay on that topic. The big secret is to fill the engine via the top radiator hose.
Hi! battery disconect and cel light
Setright replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice :-)
fuel filler pipe leak - 97 OBW
Setright replied to JohnVT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt least once a year, maybe end of fall/autumn or perhaps end of winter, get under the car with an inch wide paint brush and scrub off all the dirt/sand/salt and stuff that's caked on. Use goggles (maybe a mask too) and a good light. The amount of crud in the top of the suspension towers is astounding! Then, rinse with water, let dry, and apply underbody sealant.
creaky clutch
Setright replied to kevinL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRally, that sounds more like wear inside the bearing. The shaft I mentioned is only for sliding, no rotation on it.
buying and head gasket issue
Setright replied to sisu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds about right. Do keep in mind that the HG issue is a weakness, not a certain-to-happen fault.
01 H6 major engine trouble
Setright replied to mgiff3860's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHas anyone offered the idea of a leaking intake manifold gasket? That would hit one side only. Same for exhaust manifold - but that would usually be audible.
creaky clutch
Setright replied to kevinL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe shaft that the clutch throw out bearing slides on needs lubrication. If you remove the intake/air filter box, then detach the clutch cable - or slave cylinder, and remove the rubber boot around the clutch fork you will gain access. It's tight, but a long brush with a bit of high temp grease on it (copper or lithium) should cure the creaking.
Adjusting a cable clutch
Setright replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you tighten it, clockwise, then the "bite point" will move further up the pedal travel. Loosening it will bring the "bite point" closer to the floor. Overdo this and shifting will become difficult. I assume you know that there are two nuts. A12mm that is the adjustment, and 10mm to lock it with. I would recommend loosening it 360 degrees. OR, taking you foot off the clutch pedal when you press the accelerator to the floor ;-)
'90 Legacy overheating demons
Setright replied to fj401968's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy EJ22 did exactly as you describe when it blew a head gasket. Don't waste too mcu money on replacing radiators and thermostats and water pumps. FIx the HG. Or, if you don't intend to spend that much on the car and are willing to run it into the ground: Fit a higher pressure radiator cap. 1990 Legacy will probably be 0.9 bar. Get one for a newer model at a dealer, and it'll be 1.1 bar. It'll slow the bubble process while you look for a new car :-)
Imprezza and a tape measure
Setright replied to randomizer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's what you might call a "trunk". Smart alec!
Setright replied to randomizer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOkay: Boot lid external 120cm Internal, ca. 110cm at the widest point, only 60cm wide at the bottom near the bumper.
Spark plug dilemma for Legacy '95
Setright replied to katheo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI prefer NGK, and most people here do too. Some Subaru engines work "less well" with Bosch - like my EJ20 - and others don't seem to mind - like my EJ22. You're not at risk of doing any harm, but you might get a smoother and more responsive engine if you go back to NGK. Don't sweat this one, though :-)
Aftermath of a fenderbender - other issues to be concerned about?
Setright replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry to hear that! Make sure you have the car looked over, plastic bumpers have a tendency to pop back into shape and conceal the damage to the car frame.
What is that S@#t on my windshield?
Setright replied to Urban Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX30mm canon? So much better than a horn when you need to get ahead in traffic
