Everything posted by Setright
I'm running 205/55R16 on my MY2000 Impreza. No clearance problems. I don't think you should bank on getting any serious mpg improvement. I certainly haven't....but of course I'm running either winter tyres or R050A's which get bad ratings in the tests regarding rolling resistance. Bear in mind that your odometer will show ever so slighty fewer miles, and that will make your mileage look worse
Erm....lots of interesting comments and views here. I have one too Discs should be made of steel!!! Iron with carbon makes steel. Plain iron, cast and machined would wear out very fast indeed. Carbon not only gives surface hardness, but also a more uniform matrix. Personally, I do think there is a difference in quality of discs. I do agree with AircraftEngineer that casting is casting, and then maybe I don't. The temperature of the molten steel, the temperature of the cast, the speed of cooling, and so on will affect the uniformity of the finished product. Not all foundries will cast with the same care. They won't use the same percentage of carbon either, and 0.5 and 1.0 percent make for very different qualities of steel.... Having said that, the PRICE is only a guide to finding the best quality for your personal application. "It is not always true that you get what you pay for, but unless you pay for it, you certainly will not get it." Leonard Jerome Setright
Hmmm....a worn damper(shock) would cause cupping of the tyre surface, but I wouldn't put my money on it causing carcass separation. Maybe the tyres are really lousy. Or they are being massively over-inflated causing undo stress on the carcass. Or they could be under-inflated, and driven fast enough to overheat and cause the separation. Have Walmart replace the tyre again, then take the wheel to another shop and have them balance it. Make sure you run the correct tyre pressure (28-30psi?) and see how you get on.
Really??? Explain more. I have found that the 1.1bar caps have "bad" internal seals and begin to lose the ability to hold back coolant and keep the pressure up. New caps read 108Kpa - same pressure, but new text to indicate new cap. I would suspect that a cap with 89Kpa written on it would solve your problem Paul. And: The correct burp is to run without the cap on, until the radiator fan starts running. That means the thermostat is open and all the air can be circulated out.
I had the same light show (but no starting problem) happen to my 2006 Forester XT after a trip to the car wash. The code for TPS came up, we unplugged it, blew dry air in, reconnected, never saw it again. Maybe they're getting to busy at the factory? We've had a local Legacy H6 with some odd perfomance problems, and it turned out to be an ill-fitted intake hose connection. Air was entering the system aft the MAF.
For a few years I have sworn to using Bridgestone winter tyres, but Continental TS810 has surpassed them. Had these on a Forester 2.5XT last year...so much grip it was hard to get it to slide...on packed snow. I've got a set on my Impreza 2.0 now and they still impress me. If you look closely at the tests you'll notice TS810 is the best for stopping hard in wet conditions -but they move them to 2nd and 3rd place because of wear and fuel consumption. To me, that's daft. Over here the big discussion every winter is the longer braking distance of winter tyres in rain....then someone addresse the problem and makes a tyre that grips in wet and snow. And the testers almost ignore it. Conti's for me
Erm....the 1.5 has a very disappointing 124Nm to go with it's 104bhp. Even though it has variable DOHC. It feels a bit slow, but it's willing to run to 7000rpm again and again. Next step up is the 2.0 with ~190Nm and 150bhp, doesn't feel slow. From there we lose the 2.5 N/A option. There's a huge jump from 2.0 to the WRX and STi. Oh...did I forget to mention that ALL 2008's have Dual-Range over here in Denmark?? Getting jealous?
Looking at those last photos, the "jiggle pin" is also mounted incorrectly by the thermostat manufacturer. (Even though that way round seems right to me, can't understand why Subaru put the pin the other way round. Still, Subaru engineers most often seem to know what they're doing, so there must be a good reason!)
