Everything posted by Setright
First Imp on 08 Imp in real snow
Setright replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFit some snow tyres. Right now, I'm finding Continental TS810 to be the very best - also for wet conditions. Of course, you'll lose out on some of the tail-sliding fun. My Forester Turbo wouldn't kick the tail out on compacted snow after I fit these last year. My Impreza (my 2000) is now wearing these tyres too.
Uneven exhaust on '06 Outback ...
Setright replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's due to the branch. The driver side is almost straight, the curbside branches off above the rear axle.
Water pump
Setright replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, and even if the supplier uses the same molds/parts and so on when producing for the Genuine and aftermarket....do they run the same quality tests? Do they test every part, or just every tenth/hundredth ?
upgrading rear disc to ventilated: is it worth it?
Setright replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnly useful for track work - or very heavy cars.
Wheel Lug Question *Wheels On*
Setright replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXforester2002... ..I understand the logic, but copper grease/paste has a high viscosity and I wouldn't bank on it reducing friction in the bolt threads. The anti-seize aspect is the greases ability to keep water/dirt out of the threads, and stop nut/bolt rusting together, as opposed to lubricating.
PCV Valve Gunk
Setright replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's normal for gunk to build up here. Running good full-synth oil in my engine seems to have kept the build up to a minimum.
**call For Pictures**
It's a very special place. Coming down for the Scuderia course at the end of April - as co-driver.
2.0 liter Impreza "Sport", which means a factory fit Turbo body-kit. My mods inlcude Turbo rims, springs, brakes and a Subaru Sports Muffler: A couple from tracks in Denmark: http://img.photobucket.com/albums/v684/Setright/Padborg.jpg http://img.photobucket.com/albums/v684/Setright/rd1.jpg Yep, been there, done that, doing it again soon: http://img.photobucket.com/albums/v684/Setright/nurburgstick.jpg In "her" natural habitat: http://img.photobucket.com/albums/v684/Setright/PC290013.jpg
95 legacy caliper replcement ?
Setright replied to joshuacoyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can get buy with a "seak kit". That has new piston seals and boots for the caliper sliders. Use a lithium or silicone based grease. I have learned the hard way that copper grease swells the rubber boots and causes caliper seizing!
Genuweenie Subaru or STP air filter?
Setright replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYEah, the Legacy and OBK filters are just some kind of fabric gauze now
Setright replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReduce torque? Okay, maybe a thick copper paste will add friction in the threads, but oil?
Timing Belt/Tensioner question
Setright replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the tensioner, the water pump and the toothed follower. The money you spend on these parts now, could save you a big bill later. The smooth followers are "optional", as you can hear which ones are getting tired. If they begin to fail halfway to the next cambelt swap, they will start to whine and screech - giving you advance notice to replace them pronto.
Could A Clogged PCV cause.......
Setright replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say you've got a 70% chance of internal breakages in the plug wires - especially if they are the original wires. It's a good place to start. You could try just purchasing the wire for #2 - to avoid spending too much money.
Setright replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru genuine filters are oiled paper.
Air in Cooling System
Setright replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStart with a genuine Sube thermostat and new rad cap.
Grimmspeed gear oil cocktail made shifting worse!
Setright replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRedline couldn't do it for my old Legacy.
Setright replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKeith, my 1992 Legacy was capable of this "feat" Any car is, really, provided you do the right dance on the pedals
any potential harm if underfilled ATF?
Setright replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it possible that the 'box was underfilled at the change 2 years ago? If your car still performs well, now with the correct the amount of oil, you've probably not damaged it very much.
my 04 outback sport needs more, well...sport
Setright replied to litewaitdave1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXErm....I think you'll find that the largest portion of cracked Borla's are replicas. Look to cobbtuning.com maybe ?
Part-time AWD transmission????
You cannot switch to RWD without a serious bit of fettling on the driveline. FWD or AWD. Your car divides torque 90/10 favouring the front wheels in full traction driving conditions. The transmission will automatically send more torque rearwards when it detects oncoming slip/spin at the front. The fuse causes a permanent 100/0 split, by activating a solenoid to disengage the rear wheels. The long term "fear" is burning out that solenoid. Hope that helps
Mold Smell in Cabin
Setright replied to mrtoyou7747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFull heat is kinda useless unless you run the recirculation on the ventilation. The air-con evaporator is upstream of the heater core.
Setright replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShifting on the move: YOu could try to teach yourself about "rev-matching" and "double de-clutching". Basically, car still rolling, gear stick in neutral, clutch pedal up, tap the throttle to rev the engine to maybe 2000rpm, clutch pedal down, shift into first (double-de-clutch) then, before releasing the clutch pedal, tap the throttle again (rev matching) to avoid excessive engine braking. With practice, you will become super smooth and able to select a lower gear smoothly.
DexCool in an EJ25?
Setright replied to crazyhorse001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, finding (and paying for!) genuine Subaru coolant could be a problem. To flush: I would recommend a full drain, fill up with pure water (destilled, milli-Q, whatever, just not tap water), leave engine on with rad cap off to expell air, when the rad fan comes on, install the rad cap. Drive...enjoy life behind the wheel of a Subaru. Come home, drain again and fill with any good "regular" coolant. Most of these are green or blue. Avoid red or orange. Having said that, the Motul "Expert" coolant I am running is yellow, but it's the same ingredients as the blue stuff - only a lower concentration. And it's meant for bikes. The only real difference is a higher freezing point. This coolant is very good though, excellent heat transfer.
5w50 motor oil
Setright replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure, but even Mobil's own 5W-40 is better suited for freezing weather. It's thinner in the cold than 5W-50. I always like to remind that the xW-xx is just a consumer label that covers a range of viscosity. To be serious about oil choices, you must look at the tech. data sheets. European Shell Ultra 5W-40, for example is so thin that it is almost a 5W-30 oil. Mobil Delvac 1 5W-40 is close to being a 5W-50 ...
Setright replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI understand. You could try Motul "Motylgear" - they even make a 75W-80 to ease shifting, but the 75W-90 stuff isn't too bad either.
