Everything posted by Setright
Or the factory manual method: Igniton - OFF Connect the black and green connectors under the steering column. Both are single wire, normal-state is disconnected. Igntion - ON Press the throttle to the floor. Lift it back to approx. half-way, hold it there for 2 seconds. Release throttle fully. Ignition - START! Let the engine run for a few seconds, the CEL will be off if there are no present faults. Start driving....sooner or later, within minutes, the CEL will flash at a steady rate, indicating the ECU is reset. Igntion -OFF Disconnect both green and black wires. DONE!
When we take delivery of brand new cars at the dealership I work part-time for, there's a fuse or two to install in the engine room before the car will run. These are left out by the factory to avoid batteries draining on the ship from Japan. Sounds like you should wire in a switch to kill the auxlillary power during parking.
NO! NO! NO! I don't want some alarm going off because I have turned my lights on! The best system I have witnessed was in my parents old - 1979 - Toyota Crown. Start engine, lights on. Drive around. Park, turn off engine - lights still on. Open either front door - lights automatically switch OFF. To activate the parking lights, you had to turn the light switch back to the OFF positon and then forward one click to parking lights. EXCELLENT! No flat batteries, no unintended parking lights on. Bring this system back and all people should be happy!
Peter, the large amount of overflow is caused by a big bubble somewhere expanding quickly and backing fluid out. It's best let it flow over and wait til the fans come on because that way you can be sure the thermostat has openede fully and the circulation will release the air traps. Still, seems like a quick burp worked, so you're ok
As far as my calculations go, the parking lights can be left on for about 24 hours and still leave just enough juice in the battery to start the car. Automatic transmission cars will have more time, since they have bigger capacity batteries. I like that switch, and it's location. Try accidentally knocking the indicator stalk on the way out of an Audi/VW see what happens.
Park car with nose up a slight incline. Let engine cool for at least four hours. Remove radiator cap. Start engine and let it run until the radiator fan starts running. Top of level in rad filler neck. Install cap - preferably a brand new genuine part. Be aware that some coolant will spill over, so a cloth wrapped around the filler neck is a good thing. Also, as the engine heats up and the thermostat begins to open, you should have bubbles leaving via the filler neck. Drive for a few days, report back here
I bought a "kit" that was comprised of two metal brackers that screw in into the blower hosing just aft the blower itself. And a metal lid with a rubber gasket to hold the filter in place. The brackets attach with self tapping screws and have fine threaded holes to secure the metal lid. Had to cut out the plastic blanking plate.
I'm gonna have to be a real drag here: You're car is too young to be subjected to discount-price service. Put the cost of an authorised service in perspective to the price of your car. Yes, an authorised dealer visit is not certain to get you 100% perfect work done, but the chances are much better, and you won't void your warranty by accidently tripping over some technicality. IF you do chose "Oil Changes R Us", PLEASE purchase a genuine oil filter from the dealer and have them use that.
