Everything posted by Setright
heater fan noise
Setright replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Problem" ? This is standard on all my Subarus. One is brand new.... Of course a leaf or similar makes it much worse. You can remove the cylindrical fan quite easily. Get under the dashboard on the pass side and undo three screws and one hose. Or try this: Full speed on the fan, rotate the vent direction knob around a bit, sometimes this will blow the bits out.
anti-freeze mixtures
Setright replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo, let me get this straight...these people aren't driving air-cooled Porsche 911's ? No need to take them seriously then Snowman has already done a good job answering, but my nerdy side wants to add: Water has three times the heat capacity of anti-freeze making it more temperature stable, and giving you more time to react to an overheating engine. It is also able to transfer heat at twice the rate of antifreeze. So, yes. 99% pure water and 1% detergent to break the surface tension is the ideal in terms of heat control alone. Living in a hot area, I would probably run 60% water. Enough to make me feel smug about optimising the cooling system, but at the same time not so weak that my engine would corrode internally.
clutch life expectancy?
Setright replied to pBIIKS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've done 12k miles in a brand new Forester 2.5 XT. At 31 tender years, I still enjoy using the power available. Even so, I don't let the clutch slip and get hot. Just give it 3500rpm and step off the clutch smartly...screech! But seriously folks, a 14k clutch failure does sounds suspicious, but if the driver has a tendency to use the clutch pedal as a foot rest, then it is possible to kill a clutch in such a short distance. (My 2.0 Impreza has lived with me since 40k miles and now has over 100k miles. Original clutch.)
B9 Tribeca stinks!
Setright replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPassive Safety! The door is less likely to get jammed shut in a collision.
B9 Tribeca stinks!
Setright replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt doesn't even have frameless windows. It's a shared platform product and it shows. Also proves that Subaru does it best alone
I've been a bad boy....
Setright replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this: Go back to the dealer, tell them to connect the Select Monitor and erase the Throttle control fault. My same-engine Forester did this after I washed it in a machine that also rinses the underside of the car. I suppose a lot of water got in the engine bay and my tendency to mash the throttle into the carpet shifted the water around enough to cause a throttle servo short or something. Dealer did as above, and now I drive less violently after car washes
Subaru 1.5R impreza
Setright replied to bgd73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnyway peeps, keep in mind that Audi offers the A4 with a 100hp 1.6 engine here in Europe. A6's can be had with a 1.8. Both are painfully slow.
What rotors and pads to use?
Setright replied to elmwood22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like a myth ?
Subaru 1.5R impreza
Setright replied to bgd73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the 1.5 have the new variable cam system? That would explain the difference over the old 1.6. The only trouble is that to feel quick, the 1.5R would need to way around 1000kg. So how overweight is it? 2-300kg ?
Setright replied to elmwood22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, Brembo rotors are good. I prefer Mintex brake pads.
Setright replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRally Keith, maybe we're just divided by different markets? Brembo equipped STI's have 5x114. At least on this side of the pond. Didn't know that SVX had that size too. Now committed to memory - soon to be dispensed on Subaru boards across the world My 2006 Forester 2.5XT has 230hp. Do you guys make do with 180hp ?? (05 had 210hp, but that was without variable cams)
Setright replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBolt pattern is still 5x100, however Forester rims have 48mm offset. But that's not really a big difference. (Only 04 and on STI's have 5x114 bolt pattern, something about fitting Brembo brakes) Oh, and CONGRATULATIONS! OB XT, does that mean 230hp?
How did subaru increas the ground clearance on the new outbacks
Setright replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRanger, the center og gravity might move with a lighter hood/bonnet, but the roll center is calculated from the suspension angles
Replacing stock stereo in 05-06 Legacy
Setright replied to aboone1970's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, brus, it's time to change up to a 2007 model - MP3 compatible stereo which swallows six CDs
Pictures of my 10-11 y/o knock sensor.
Setright replied to itzik93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, classic knock sensor failure. The original one on my old EJ22 cracked in the same pattern. New ones have been revised and they don't crack. These have a white connector on the wire, instead of grey. SO, if you fitted an old style one, it may crack again..
New Suby owner with some questions
Setright replied to outbackattack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplacing my gearbox oil with Valvoline Synpower has worked wonders. Used to crunch on the shift from 2nd to 3rd, and just pouring in the right oil cured that. Castrol "Syntorq" isn't bad either, and Motul "Motylgear" will also do the job. But I prefer Valvoline. Depends on price and availability locally I guess.
ABS G Sensor
Setright replied to griz4718's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnder the handbrake handle in my Impreza, 1999MY. Hidden under the console, of course....
low speed hesitation problem
Setright replied to 97OutbackCA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFuel problem_ I find my car runs best on the RON95 that it is rated for. Upping to 98 has given me hesitation problems at full throttle. It\s as if the ECU gets too busy on the timing and cannot think fast enough and then retards timing just to be safe. Those are EURO octane ratings....
Wheel nut torque?
Setright replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDitto!
Wheel nut torque?
Setright replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClean, dry conical surfaces. Anti-seize on the threads. Torque, drive around 200 miles, re-torque, sorted. I set my wrench a little lower like, 94Nm instead of 95Nm when I re-torque as this avoids over tightening.
Wheel nut torque?
Setright replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI go for 95 Newton Meters. What's that in your money? 73ft/lbs ?
Engine making a clicking sound!
Setright replied to BSOD2600's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBe it piston gudgeon pin bearing, big end rod bearing, or even crankshaft main bearing noises, the following will apply: It will be muted at cold starts, and progressively get louder as the engine warms up and the oil thins out. It will not come and go. A busted bearing will not fix itself randomly. The noise is a low frequency, "dull" thud kind of sound. Not clicking. I think the most likely is a stuck valve lifter. The timing belt tensioner can also make this sort of noise if the oil seal is leaking. I would expect it to fluctuate and not follow engine rpm directly. You might also want to check the gaskets on the exhaust manifolds. Especially at the cylinder head end. Also makes a ticking noise.
I got new tires!
Setright replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLOL
I got new tires!
Setright replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLoving your car And I'm glad your new tyres don't screech - it's so anti-social.
Air filter replacement problem for 2004 Outback
Setright replied to 2004outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAsk for the same filter as used in the Forester 2.5XT Og Legacy GT. Subaru only has two sizes. The long and thin one, and the more square one.
