86subaru
Everything posted by 86subaru
after all the work was done ,and ran fine , they drove it like 200 miles and started making the noise , they stopped and had it towed to the shop , and has been there almost 1 year, and the shop says rod knock , and has done nothing to it, the shop bought it , and all the other work they have to do , they will sell it to me,
well the hg was done with heads resurfaced and it does start up and run , noise goes away some what after it warms up , after all the work was done they drove it , and starting making the noise, it's at a local shop ,they did not do the work , the owner has alot of work and no time to work on it, and has been sitting for about a year,
went to look at a 97 outback a/t 2.5 , new radiator, new tires, new timing belt, water pump, hg , heads were resurfaced ,the guy said it has a rod knock , i heard it run and yes there is a noise , and not piston slap , i am thinking the valves need adjusting ,am i right or wrong,? 135,000mi on motor.would it hurt anything to drive it away, or drop a 2.2 in it,
need date of wcss11 meet
86subaru replied to 86subaru's topic in Meet n' Greet. Your USMB Welcome Center
thanks -
the car was moving when it died, so while i was at work my wife had it towed , [ roll off] everything went crazy , got a new battery [ napa] i put new battery ,nothing, so checked fuses all good, went to check linkable fuses and 1 was burnt and broken, so replaced it with one from a hand full i had from a ea82 motor, now it starts fine everything good, but could alt still be bad? and the linkable fuse i used will it work ok or should it haevier ?my wife made the post , it is a a/t awd 2.2 motor 168,000mi , , she ment to say is that it would not come out of park ,after driving it aleast 10 miles with everything on fan, hi brights, rear drfrost, flashers on, no problems, here is one thing i noticed, the old battery sonded different and possible leaking, one thing that needs replaced now the headlight [ bright side] thanks
need date and place of wcss11 meet ,thanks
