Everything posted by ccrinc
hovercraft with ej18
You can increase EA81 HP by using 1600 (EA71) pistons and decking the head 30/1000ths. This will give approx. a 10-15hp increase. We've done it many times for aircraft, hovercraft and mudboats. No other mods necessary, although switching a Weber carb also (allegedly) will add power. Oh, and you can also do the SPFI intake as well. Not sure on the HP increase, but if you need to go from carb to fuel injected, this would do it.
early ej22 headgasket failure
ccrinc replied to subarurx yo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat makes them different is: 1) They are mostly aluminum. Most engines over the years had a cast iron block with either aluminum or cast iron head(s). Since those two metals react to heat differently, retorquing was a common procedure. 2) Um, duh. They're horizontal.
ccrinc replied to subarurx yo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only heads that ever needed retorquing were the early EA series; After the advent of the EA82 engines, retorque is not necessary. Mazdas are a whole different engine. What works for them does not work for a Subaru.
There's no way in hell you're going to get an EJ18 anywhere close to the weight of an EA81. Hell, just the crank is twice the weight of the EA81! You're really looking at about a 100 lb. difference between them. That's a lot of weight for a difference of about 30hp. They may be similar in physical size and displacement, but the similarities end there. Either the location of the engine is going to have to change, or something else is in order to balance it out.
Fair Price for '99 Outback? Needs Engine
ccrinc replied to RedMtnRacer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow. Here in Denver, you can barely pick up an early Legacy in bad shape for under $1000. Especially off Craigslist. A year ago, I could buy them for $300. I'm jealous.
weird overheating issue after new head gasket
ccrinc replied to dm88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+ 1. Also, remember that these engines are primarily aluminum. Every time they overheat, even briefly, additional warpage occurs loosening the head gaskets even more. Everything has to be right the first time, there is no cutting corners on a Subaru. Done right, they are amazingly reliable. Do or do not: there is no trying./Yoda
Does Outback fuel pump turn on with key ON (not start)? Traveling out of state!
ccrinc replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll check mine here in a few minutes and let you know!
Newbie requesting expert opinion
ccrinc replied to 2002ForesterGuy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo bad you're not on the Big Island. I know a guy over there. Oh well...
Loud Banging Noise & Felt Vibration from tunnel area
ccrinc replied to timzoy89's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have it backwards: only automatics have flexplates: it's what the torque converter bolts up to. Manuals have a clutch pressure plate.
Subaru Remanufactured Engines
We are now a recommended seller on Angie's List! As you may know, a business can not pay to be on it: a customer MUST recommend you first. We feel very honored. Emily www.ccrengines.com
ccrinc replied to timzoy89's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy money's on a broken/cracked flex plate. I don't have a sound, logical reason to back this up with, but it's my gut feeling, and I've learned to trust my gut feelings. One question: Does it do it while not in gear? Like in neutral?
weird over heating problem
ccrinc replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMeh. You should see what would happen over on AWD Pirates forum. As one guy's sig says, "it's not a car forum, it's a grammar forum".
differences between 2.5 and 3.0 radiators?
ccrinc replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure, but I do know that when we did the engine in my '02 LL Bean, we had to get the radiator from the dealer. They were the only place that had it. (Oh great...another SVX-type car!) Interesting note: I sold my SVX about 3 years ago to a guy in CO Springs. My grandson spotted it in Provo, UT last week. Identification positive due to the unusual pattern of spotting on the hood. Small world.)
ccrinc replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere DO you get your information? Initially, you have to fill it not running, but the only way you're going to get all the air bubbles out is to have it running, so the coolant can circulate and move those air pockets!
Head gasket not the big problem here
ccrinc replied to ivans imports's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI disagree. Aftermarket PCVs are not as good as Subaru Genuine. This is one of those parts where you want to stick to Subaru parts. It's only about $10-12 from the dealer.
ccrinc replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's because there's air in the heater core instead of coolant. Reread his OP. Carefully. (Just imagine there's all the proper punctuation. ) Plus, whatever the crack is, it blew coolant all over the engine compartment.
Length of HG issues
ccrinc replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse the 11044AA642 turbo head gaskets.
ccrinc replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will defer to you on the OEM thermostats. But looking at the original post, the car had a close encounter with a deer: there is coolant all over the engine compartment on one side. Does this not tell you that there is very likely a crack in the radiator itself, or maybe a coolant hose? It's certainly worth checking out. It just annoys me that everyone always starts shouting "HEAD GASKET" without trying to find out WHY the damn thing started overheating.
ccrinc replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEarly EJ22 head gaskets don't just "blow" on their own. Engines don't just randomly overheat without reason. The reason is lack of properly circulating coolant, especially for an EJ22. Is it the original radiator? Very likely. Therefore, you have a 22 year old radiator which is well known to corrode from the inside out. Are your upper and lower radiator hoses the same temp? If not, you have a blocked radiator. It's true that you probably have to beat yourself up doing the head gaskets and water pump, etc. by now, but I still am quite certain you will end up having to replace the radiator as well. BTW, I am not trying to denigrate your financial status: believe me, I've been there more times than I care to. But it irks me that I hardly ever see anybody mention the radiator when it is the heart of the cooling system. Sometimes, ya gotta bite the bullet to keep your car dependable.
ccrinc replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRadiator. Again I ask, why does nobody ever recommend changing the radiator? And, after overheating, ALWAYS change the thermostat (Subaru Genuine only, thank you). They never work correctly again once they've been overheated.
Anyone put a wrx engine in a legacy auto?
ccrinc replied to pyroblade86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReread GLoyale's post: if you don't know anything about it, you don't know enough to even start the swap. First, the WRX wiring loom is double redundant and feeds every sensor in the car, even ones like "hey, your tail light is out!" You have to cut out every wire except those that make the engine run. You have to swap your intake, exhaust, add a turbo and all the plumbing for that. If this part makes you even slightly confused, take the advice and put a 2.2 in it. Safe, cheaper, easier, more reliable. Emily
Any EZ30 is the same price. Although I DO give a USMB discount (you'll have to call me for that.) Remember, that includes all non-residential shipping and the installation gasket kit as well.
Hi Ed! Thanks for the kind words. I should add that, if anyone has any questions, don't hesitate to PM me or post here. I'll be happy to answer ASAP. Emily
what year marks off the end of ...
ccrinc replied to cz777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat he said.
I used to post here all the time, but for no good reason stopped being an active participant. I was never here to "sell" something, just try to help out with advice when the opportunity arose. Well, now that there's a vendor's forum, and with the extremely active and growing membership who may not know us, let me re-introduce us! We have many current and past customers in the USMB community. We're located in the Denver area of Colorado, but we ship worldwide. Visit our website: everything you need to know is there, including prices. www.ccrengines.com Hope to talk to you soon! Emily
