Everything posted by ccrinc
Look what happened today!
ccrinc replied to bratman18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNAPA probably won't have it. It's called a Time Sert. http://www.timesert.com Emily
SVX tranny?
ccrinc replied to bratman18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAdding a transmission cooler helps a lot. Also, there is a kit made by Transgo for the valve body which pretty much eliminates the shift issues for SVX trannies. They were made to shift smooth and easy, but that increases the wear and tear on them. The kit makes them shift quickly and firmly. I've had both on my SVX for about 4 years now, and the tranny is perfect. The only transmission which is a direct swap is a Legacy Turbo model.
Valve Springs
ccrinc replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, there is a top and bottom. On EJ22s, the difference in the spiral is more difficult to see, so Subaru painted the top (either green or yellow). They have to be clean to see it, and it's faint, but it's there. Emily http://www.ccrengines.com
Wedding --Mine
The setting really was awesome, in every sense of the word. No cathedral in the world could equal the backdrop of the snow covered peaks behind them. ps: Joy isn't the kind to "keep Shawn off the forum" now that they've made it legal and are no longer living in sin
Not a happy camper...new motor blues
ccrinc replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOf course, and we pay for the return shipping as well. Emily http://www.ccrengines.com
2002 Outback Ltd consuming oil - Help
ccrinc replied to PeterP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat Gary said. Emily
Help me ID my engine for oilpan replacement
ccrinc replied to Tommymc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBetween the EJ22 and EJ25 engines, there are only 2 differences: a 4 qt oil pan or a 4.5 qt. oil pan. (Which, btw, are interchangeable). The 4 qt has a rounded bottom, the 4.5 qt. has a squared-off bottom. Either will work just fine. Emily http://www.ccrengines.com
2.2L rocker assembly compatibility
ccrinc replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll of the lifters used in EJ22 engines from '90-on are identical, even in turbo engines. No compatibility problems. One note: if you decided to go with roller rockers, you would also need to switch to roller cams: different profile. Emily http://www.ccrengines.com
Will 2002 Forester cargo cover fit a 1999 Forester ?
ccrinc replied to jimrichard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm 98% positive they will. Emily http://www.ccrengines.com
ccrinc replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI must put some feedback in here: Mal, the reason you haven't been contacted yet is that Rick (the owner and best diagnostician) injured his back very badly in January and has not been able to work consistently since then. (It's hard to work when your legs and feet are so numb that you can't walk.) Yes, we are aware. Yes, we are trying to diagnose the problem. Yes, we stand behind our work. I hope that he will be able to be in the office Monday or Tuesday, will be able to check this out further and offer his advice. Emily http://www.ccrengines.com
IT'S DONE! Swapped EJ22 for EJ25 in '97 Outback
ccrinc replied to kaltree's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX'95 was the first year of the EGR port on an EJ22 engine. Emily http://www.ccrengines.com
98 Legacy: Cooling system problems
ccrinc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry Performance Radiator. They have a website. Emily http://www.ccrengines.com
Wtf, cooling issue!! please help
ccrinc replied to codytotheh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe other very obvious thing you are overlooking is that the radiator itself is clogged. Subaru radiators tend to corrode from the inside > out. At that kind of mileage, it's time for a new radiator anyway. (No recore: not very effective on Subarus.) No flow through the rad would account for different temps at the hoses. Sorry. Emily http://www.ccrengines.com
How To Use RTV Sealant?
ccrinc replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's one of the new style steel separator plates, you need to rough up the sealing edge. The new ones are awful! Use some steel wool, then clean it well. Otherwise, the sealant will literally not stick to it very well. Permatex UltraGray 599 IS anaerobic RTV and fume free. You can spend more for the newer stuff if you like, but honestly...IMHO it's no better than the 599.
What 2.5 Engines Fit 2000 Forester? (Cracked Cylinder)
ccrinc replied to dbfitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are several things that have to match up: Left cam sprocket Crank sprocket EGR PCV valve seating (either screws into block or has hose that goes over it) The cam and crank sprockets must match or the car will NOT start. Emily http://www.ccrengines.com
2.2 liter crank shaft. . .
ccrinc replied to Dazed Dreamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe guy who used to turn cranks for Ridge Reamer now works for Area Machine. They do very good work. As for someone who "doesn't recommend" us, I guess you can't please everyone, though we sure try. Most who don't are old competitors from 15 years ago or so as far as I know. Emily http://www.ccrengines.com
ATF For '06 Forester
ccrinc replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis info should be in your owners manual. Look under "Specifications". Emily http://www.ccrengines.com
Alot of smoke on passenger side of engine bay?
ccrinc replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat engine?
92 Legacy running rough after warmed up.
ccrinc replied to diggler1971's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm going to second coolant temperature sensor. It's located on the coolant crossover pipe on top of the block, under the intake manifold. Kind of a ***** to get at. Emily http://www.ccrengines.com
Where is the PCV Valve on my EJ18? 1994 impreza
ccrinc replied to sub_dont_touch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're losing oil without any other good explanation. No leaks, no blowby, no seeps from valve covers. Emily http://www.ccrengines.com
MT5 trans rebuild kit
ccrinc replied to hebrewhammer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTranstar. Emily http://www.ccrengines.com
to junk or fix?
ccrinc replied to winelegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou got it
to junk or fix?
ccrinc replied to winelegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat right rear o-ring is a common issue and an easy fix. Those are 12mm bolts. Take them out, clean off the cover, CAREFULLY replace the o-ring (it goes on the cover itself) and replace. About a 15 min. job if you've never done it before.
2006 Legacy Turbo Catastrophic Engine Failure
ccrinc replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemember, the turbo is lubricated by the engine oil. High oil consumption = low lubrication to the turbo. Most common cause of that kind of oil consumption, all else being ok: Bad PCV valve. A $12 part that causes so many engine failures because dealers tend to overdiagnose issues. If they can't find it on a scanner, it doesn't exist. A bad PCV valve won't show up on a scanner because it's mechanical. My bet is that if he had changed the PCV valve early he would have saved himself $10,000!! Emily http://www.ccrengines.com
At temp light flashing...
ccrinc replied to wallywiz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe tranny cooler lines would have to have been disconnected also to do the head gasket job. I wouldn't be surprised if they forgot to reconnect them, or didn't connect them properly. Emily http://www.ccrengines.com
