Everything posted by ccrinc
Bad shimy above 60mph '00obw
ccrinc replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour tires need to be balanced. And you probably could use an alignment too. What you're describing are typical symptoms. Emily http://www.ccrengines.com
NOW ON EBAY! CCR Engines
Its the slow season at CCR so we are cleaning up the shop and some of the parts and such that are lying around. In addition we are also offering 2 day shipments! That means if you order one of our engines it will ship out 2 business days later. Normally our special order engines are a 2 week wait! http://motors.search.ebay.com/_W0QQsassZccrengines If an engine you need isnt on our Ebay auctions please email or call us. ccrinc@aol.com or 303-293-9230. Thanks, Emily http://www.ccrengines.com
EJ22 cams
ccrinc replied to WAWalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's easier to eye-ball the cams to tell if they are roller rocker or not. Roller rocker cams: all lobes are equal width. Non-roller: middle lobe on each side is wider. Obviously wider. Emily http://www.ccrengines.com
Car sat for a while, won't start
ccrinc replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou said it was hard to start before when it was cold. Sounds like the coolant temperature sensor to me. Located on the coolant crossover pipe under the intake manifold. Of course, after sitting for a year, the other things are worth checking too. Emily http://www.ccrengines.com
Excessive oil consumption '97 EJ22
ccrinc replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA leak-down test will provide more accurate information on worn rings than a compression test. Worn valve stem seals could also be the culprit or both could be involved. What kind of mileage Ed? Emily http://www.ccrengines.com
NEWS FLASH! Shawn Hits Big 3-0!!!
I Know, it's in wrong forum. Sue me. Emily
NEWS FLASH! Shawn hits BIG 3-0!!
I know, I know...it's in the wrong place! Sue me. Emily http://www.ccrengines.com
Case splitting.... HELP!
Yep, that's why we call it the "Secret Bolt". Use Permatex Ultra Grey 599. Great stuff, available almost anywhere. Emily http://www.ccrengines.com
Did you find the "hidden" one way deep in what looks like a water jacket on the bottom right (I think) side? You can't see it without looking inside there. You need to shine a flashlight in those areas to find it unless you know it's there. We've played this trick on noobs in our shop a zillion times. Emily http://www.ccrengines.com
turbo motor carnage
ccrinc replied to zstalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs Ron White says, "You can't fix stupid!" Emily http://www.ccrengines.com
Can a 3-spd Loyale wagon really do 130mph?
What would probably go first is the transmission. I've gotten up to around 80mph in my daughter's old Loyale 3spd wagon and I felt I was pushing it pretty hard. Plenty of power left, but not worth the trouble if we broke down in the middle of Wyoming at midnight Emily http://www.ccrengines.com
turbo motor carnage
ccrinc replied to zstalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe've got a couple rods in our shop that are twisted worse than that one! Also a block that came from a local dealer out of a new car that went 70,000 miles with no oil changes! You name it, we've seen it. Emily http://www.ccrengines.com
replacing AT tranny, what else should I do while it's out?
ccrinc replied to biglittledog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$85-120 depending on where you live and from whom you get one. Emily http://www.ccrengines.com
ccrinc replied to biglittledog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRebuilt torque converter. Emily http://www.ccrengines.com
Great Deal Alert!
ccrinc replied to Jimmyowensfan20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe highly recommend AGAINST using any oil that has a high paraffin or sulphur content (Pennzoil, Quaker State, Havoline, etc.) They are fine for US engines or even a straight 4/6, but not horizontally opposed engines. The paraffin and sulphur have a tendency to pool in the cylinders, causing the oil rings to become unbelievably crudded up. So bad, you can't get them out of the pistons! Castrol GTX is the best on the open market. Subaru Genuine oil filters and NAPA Gold (made by Wix), Wix brand all have the heavier filter elements and check balls necessary for EA engines to have the extra oil protection on start up. Just my .02. Emily http://www.ccrengines.com
Finally joined the New Gen crowd
ccrinc replied to Turbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSweeeet! I love my SVX. '92 LSi, complete touring package. Yep, it had a bad tranny when we got it too. Imagine that. Put a Transgo shift kit in there. Helps the tranny last longer and gives much better response. Emily http://www.ccrengines.com
Replacement Battery Suggestions
ccrinc replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey, I know the engines better than battery brands. :-\ I do know that this one is great! Emily http://www.ccrengines.com
ccrinc replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a deep cycle gel battery in my Turbo Legacy. (AGM possibly, I forget). It's about 3 yrs old now, and even with the bad winter we had last year here in Denver, it's a great powerhouse! Planning on getting another one when the SVX battery starts to give out. Emily http://www.ccrengines.com
What changed between 96 and 97 2.5L
ccrinc replied to newsance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWent from hydraulic lifters to solid in '97. There may have been a piston change too, but not sure. If there was, it certainly wasn't anything radical. Otherwise, they're identical as far as the engines themselves are concerned. Emily http://www.ccrengines.com
Oil Pan
Nope. Different again. Sorry. Emily http://www.ccrengines.com
Things that suck: My SVX destroyed by a$$hat in box truck :(
ccrinc replied to Subafreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs an SVX owner, those pix just about made me sick! So sorry. Suzam is sooo right: I used to work for a back clinic. Whiplash and such can cause pain for a lifetime if not properly treated. My neice can attest to that. Emily http://www.ccrengines.com
'96 SVX For Sale-$4500 Sweet!!!
See listing under Subaru Stuff listed in Craigslist/Ebay. Emily http://www.ccrengines.com
any pictures from brooklyn bash(56k=bad ju-ju)
Yeah, I kinda wondered about a meet in Brooklyn, NY! Emily
Brooklyn?! Brooklyn what planet?! Emily http://www.ccrengines.com
EA 82's fat smokescreen???
I'm not sure this was a recall: it may have only been a TSB. Either way, the time period has lapsed on doing that fix for free. You used to be able to get the kit for about $7 but I think that price is history too. I do believe they are still available from dealers because the SPFI engine was sold through '94. Junk yard's your best bet. (Oh, and replace the PCV valve with a Genuine one at the same time.) Emily http://www.ccrengines.com
