Everything posted by ccrinc
SVX People
ccrinc replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe EZ30 was especially designed to fit in the same engine bay as a 2.5L, so they could offer it as an "option". Using a timing chain instead of serpentine belt made it over 2" shorter (front to back) than other 6 cyls. That engine is due to be a major leaker. Something like 49 bolts hold the front chain cover on: and they have to come off in a very specific order. If (and when) the chain goes, it's gonna take out a whole bunch of metal! It may yet prove to be quite reliable, but I'd advise being very pro-active on maintenance, because when it goes, it's gonna go in a big way! Emily http://www.ccrengines.com
Blown EA-81 during hovercraft race, need advice!
Actually, if you have ZERO compression on one side, and ran it like that, you probably had at least one cylinder sleeve turn. In which case, the engine is toast. The valves on these engines don't burn: they're enormous for the size of the engine. Emily http://www.ccrengines.com ps: do you know the Zangs?
clicker torque wrench... any good?
ccrinc replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNaw, you probably have to pay extra for that too! Emily http://www.ccrengines.com
Ej-25
ccrinc replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen that rear plate backs off, you may not obviously lose oil pressure, but you lose oil circulation. The front seal can and will lose flexibility after time without the back plate being loose, and you can replace just that, but at 60K, it's worth it to have the oil pump rebuilt/resealed. A good Subaru shop can do that: no reason to spring for a new pump. They're practically bullet proof otherwise. Emily http://www.ccrengines.com
Engine problem- major bucks or what
ccrinc replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually, S-Wings Stuff's repair kit is a really solid, permanent fix IF you don't have damage to the crank otherwise, or the block. If you can move the crank backwards and forwards (not side to side) you have probably damaged the thrust. In that case, you're looking at major repairs/replacement. Otherwise, I've seen cars repaired with that kit that are running great. Emily http://www.ccrengines.com
ccrinc replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEd, It's a kit sold by S-Wings Stuff here in Denver. (303) 777-8658. Talk to Mike. Emily http://www.ccrengines.com
ccrinc replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX125 ft. lbs of torque Emily http://www.ccrengines.com
EA82 Rod Bearings
Clevite sells the true OEM NDC bearings repackaged under their name. They are the best choice. Emily http://www.ccrengines.com
Is it a 1.8 or a 2.2
ccrinc replied to rubysubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have the wrong manual for the EJ18. The one you have is for an EA82 engine, also a 1.8L. You may be able to use the EJ22 section for your car. Emily http://www.ccrengines.com
2002 Outback Brakes - not working when cold
ccrinc replied to srs_49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, of course I know that! Warming up is driving and applying the brakes (cautiously) until they react properly. It only takes a few applications of the brake pedal to get everything moving properly. Incidentally, when the brake booster failed in my old car, the symptoms were, IIRC, quite different. Emily http://www.ccrengines.com
ccrinc replied to srs_49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy '92 SVX does the same thing. Now I'm just careful about moving the car before all the fluids get circulating. I had the booster replaced under warranty on an '86 Olds Delta 88 Royale Brougham that I used to drive. (God, those were THE most comfortable seats!) The symptoms were completely different. At this point, I'm not convinced my problem is the brake booster: I think it's hydraulic fluids not wanting to work properly until they get warmed up a bit. Emily http://www.ccrengines.com
A Must See!!! ENGINEERING MARVEL.
ccrinc replied to Lawsonmh15's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUmmm, not really, but thanks for thinking of us. We do NOT do performance. Not interested, not our niche. There are like, 50(?) companies out there who do all kinds of crazy performance work, but they won't "lower" themselves to do a stock rebuild. Stock rebuilds are our specialty. And we like it that way. :cool: Emily http://www.ccrengines.com
Looking for mechanic Palm Springs/ Palm Desert Area
ccrinc replied to richierich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRichie, You have a PM. Emily http://www.ccrengines.com
Needed Mechanic in Palm Springs/Palm Desert
There's a guy in Aguanga I'd highly recommend. He's not really close either, but really good and honest. (Nothing is close to Palm Desert). :-\ Alan's Garage. (951) 763-5634. Alan Jacobs. And he has experience with the EJ25 engines. Emily http://www.ccrengines.com
ej22 into an ej25 Outback swap questions
ccrinc replied to hankosolder2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe engines themselves are the same from manual and automatic models, but the coil pack is NOT. Therefore, the wiring harness is not exactly the same, but will work if you swap the entire intake manifold including the coil pack. Emily http://www.ccrengines.com
can I swap 97 or 98 2.2 into a 99 2.2?
ccrinc replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are so many differences in the '99 EJ22 that I'd have to see everything side by side to tell you if it would work. The '99 2.2 is a hybrid between the EJ22 and the EJ25 SOHC. Very different internally. I'd even question whether the ECU will work with the earlier model. Emily http://www.ccrengines.com
EA81 Differences
Jerry, You looking to get rid of the block? Call me! (303) 293-9230 Emily http://www.ccrengines.com
Do 2.5L parts fit 2.2L ?
ccrinc replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Oil Filter ?
ccrinc replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnder our warranty, we require people to use Subaru Genuine oil filters. With this filter problem, I've been trying to figure out a decent way to let people know NOT to use those filters! The only other filter we consider as "warranteeable" is the NAPA Gold model. Good, solid oil filter. In fact, we have an engine in our shop that developed a slight rod knock after the owner put one of those defective filters on and took a road trip. The sealing ring is hard as a rock, has dents in it, and is way too small for the surface it's supposed to cover. One of our contacts at a local dealer is trying to get SOA to help us out with this, since the car was running perfectly before he put that POS on it! So, if anybody reads this who has one of our EJ22 or EJ25 engines, DO NOT use those filters!!!!! If you can't get the older style, use the NAPA Gold ones! Emily http://www.ccrengines.com- timing belt swap
Turbo water pump is quite different. Emily http://www.ccrengines.com- She's At It Again...
If one of your turbo cooling hoses has a leak, it will only leak when your turbo is "running". We ran into that a few years ago. A dealer couldn't figure out why it was happening, and since they bought the engine from us, it had to be our fault :-p . We got the car over to our place, and figured it out. I asked why they didn't replace the hoses as a matter of course while the engine was out? Emily http://www.ccrengines.com- Oil Pump Allen bolt size
ccrinc replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey should be 14mm. However, you don't need to take those off at all. Just the back plate and the angled bolt on the side. Emily http://www.ccrengines.com- Re-visit EJ25 replacement with EJ22
ccrinc replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is indeed one issue about swapping an EJ22 into a later model Outback. In mid-'98, the bell housings on both the transmission and engine went from a 4 bolt to an 8 bolt pattern. So, if you try to put a '95 EJ22 into a '99 Outback (for instance) you do not have enough bolt holes to bolt up the starter. Drilling an additional hole in the 4 bolt EJ22 is iffy at best, unless it's being done by one very precision drilling master. After 5/98, there may be issues with sensors, OBDs, ECU, etc. Not enough swaps in that time range to have documented everything. Emily http://www.ccrengines.com- Legacy 250T (EJ25) Broken Camshaft Pulley
Sounds like you very likely have a seized cam. Unfortunately this isn't all that uncommon, and we think it's due to lack of oiling to that cam. And yes, you have, at the very least, bent valves. Merry *#^#% Christmas Emily http://www.ccrengines.com- will 1996 2.2. fit into 90 legacy? issues??
ccrinc replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJosh, Sorry, but ALL EJ22 engines from '96 thru '98 had single port exhausts. (All we've seen anyway, and that's a lot!) There was the occasional oddball '95 with an EGR however. Emily http://www.ccrengines.com - Oil Filter ?
