ccrinc
Everything posted by ccrinc
  1. It's supposed to do that. It's a downhill engine braking feature. Emily http://www.ccrengines.com
  2. There is a part in the '99-up 4EAT transmission that I believe is called a piston. I couldn't believe the first one I saw! The dang thing is made of aluminum, not steel! These have a lot of stress put on them, and definitely effect the shifting. We decided to stock new ones as a matter of course. Emily http://www.ccrengines.com
  3. Check out http://www.awdpirates.net. There's a thread there about ring landings breaking. That much blue smoke under those conditions says "Rings" to me. Emily http://www.ccrengines.com
  4. One good reason not to use Bosch is that the German metric thread pattern has a different pitch. Perhaps that's why they appear to "seize up". The amount of distance for the electricity to jump is therefore greater than it is supposed to be (or is it less? I'm soooo confused! :-\ ) NGK is the best for Subarus. NipponDenso is also good and usually a bit less expensive. Emily http://www.ccrengines.com
  5. Don't waste your time going back to the yard. The EA82 oil filler neck tube won't fit your car. It doesn't even bolt up the same. Emily http://www.ccrengines.com
  6. You won't find that timing belt guide on any EJ22 engine. It was put on, as an afterthought, around '98. And only on the EJ25s. The 2.2 doesn't need it, since it isn't interferential. If the alledged '95 EJ22 doesn't have an EGR port, is isn't a '95...simple as that. The head can be drilled and tapped for it by someone who knows what they're doing, but the head has to completely disassembled to do it. Otherwise you run the risk of metal shaving in bad places. Yes, it's in the exact same place on both engines. Emily http://www.ccrengines.com
  7. We haven't seen any evidence to support that at all. Due to their small size, EJ22 exhaust valves can be a weak point in any year if the engine is running too lean. This will cause them to "burn"...I've even seen chunks burnt out of the edge of exhaust valves because of this. The single port heads do seem to carbon up internally a bit worse, or maybe they're just harder to clean due to the design. Even a 55 gal. ultrasonic cleaner won't take out burned on carbon! Frankly, the single port EJ22s seem as durable as the dual ports. Emily http://www.ccrengines.com
  8. Looks too much like a Murano for my taste. On the other hand, I can see a LOT of people who will like the fact that they can get a Subaru that will actually seat more than 4 people comfortably. My daughter has a Legacy Turbo Touring Wagon and 3 kids. When the whole family goes anywhere, it gets darn crowded. But she wants a Subaru...so she's stuck with a wagon. I don't particularly like it, but I think it may be a huge seller! Emily http://www.ccrengines.com
  9. duh Need to watch what I'm typing. '96-99 are single port. '90-95 are dual port. '95 has an EGR on the left head. Emily
  10. '96 to '99...dual port exhaust. Emily http://www.ccrengines.com
  11. What about the exhaust? The '95 has a single port exhaust and '90-95 are dual port exhaust. Emily http://www.ccrengines.com
  12. Gee Tim, that's exactly like the one I got my grandson for his birthday last year! He's too big to get inside it too. Emily http://www.ccrengines.com
  13. Pat, I think we're all "certifiable" around here! Emily http://www.ccrengines.com
  14. The '99 EJ22 is a one-year-only model, sort of a hybrid between the EJ22 and the EJ25 SOHC. Frankly, I wouldn't own one personally. When (and if) that one fails, it's a total disaster! Plus, parts are going to be inconvenient: the timing belt for that is also for that year EJ22 only. It it was me, I'd keep looking. (Sadly, the '99 is a sweet looking car ) Emily http://www.ccrengines.com
  15. '97 Outback EJ25 DOHC = solid lifters. Emily http://www.ccrengines.com
  16. A dealer shortblock is block, crank, pistons, rods, bearings and rings. Period. All brand new. Emily http://www.ccrengines.com
  17. http://www.transgo.com Good kit. Have one in my '92 Legacy Turbo Touring Wagon LE. Emily http://www.ccrengines.com
  18. The 2.5 DOHC conversion to a 2.2 is quite simple. You must use a '95 EJ22 in order to get the exhaust to match up. You do not have to change the ECU. You need the '95 intake manifold. Emily http://www.ccrengines.com
  19. There are actually two sets of gears inside the dual range tranny: one for "normal" and one for "low". I've seen that job and I don't want it!! When you shift into 4x low, you actually engage the 2nd gear set, I do believe. On the other hand, I'm not the total tranny guru, and I'm going on memory... Emily http://www.ccrengines.com
  20. Oh man...wish I could go! I haven't been there in years!!! You have GOT to go to Farley's Prairie. It's just north of the turnoff to go to Alexander Springs. (some of the best snorkeling in the world) Also cool...Salt Springs and Juniper Springs. Especially if you like canoe runs. Get a good map of the forest from one of the rangers or you'll never find all the good back roads, and places that aren't on the state maps. Have fun and post some pix for me!!!! Emily http://www.ccrengines.com
  21. The water pump does not come with that idler. Check the threads: that may be what cut loose. The OEM manufacturer is NSK. You may find one under that name, but they aren't too expensive from the dealer either. Emily http://www.ccrengines.com
  22. Mismatched gear ratios can make the rear wheels lock up...completely. Emily http://www.ccrengines.com
  23. I suppose I should have said that my "normal" mpg is 18-21. So...:-p Emily http://www.ccrengines.com
  24. I had to put the FWD fuse in my '92 Legacy Turbo Touring Wagon LE last week on a trip from Denver to Rapid City, SD. (Why is another story). Not only does my car seem to have more pep, but my gas mileage just soared! I usually gas up in Lusk, WY then have to top off in Cheyenne to make it home to Denver (about 240 miles total), then have maybe half a tank left. I gassed in Lusk as usual, drove all the way to Denver, and around town for 2 more days! When I did stop for gas, I still had a quarter tank!! No actual count, but I'm figgering about 28-32mpg which is awesome for my car! I'm having Rick put a switch on the dash to be able to switch back and forth between FWD and AWD as needed. Emily http://www.ccrengines.com
  25. Yes, and yes. :cool: Emily http://www.ccrengines.com
