12
Everything posted by Subie Gal
had the exact same symptoms on my Phase I and it was bad HG's... i did what you're doing... (thermo, radiator, hoses replaced...) and ended up needing a new block as well as i drove it too long with the issue and the block cracked from heat damage do yourself a favor face the music and fix it now before it gets much much worse (if it's not too late) Jamie
www.rockblocker.com or www.stongard.com i have stongard on all of my subaru's on the lights as well as the paint stuff... works.... great!!! after spending $100 per fog light lense... and after breaking 2 of them... installed the stongard for $24.95 and never looked back 3 years later, still working, still clear, no yellow, no fading. hope this helps Jamie
studdering
Subie Gal replied to davidv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
could also be bad tie rod ends... Jamie -
sounds like a bad slave and/or master cylinder worn slave cylinder - when warm can act up and make the clutch pedal go soft... aka go to the floor it's best to swap slave and master at the same time they usually crap out together. slave cylinders rarely go bad? i beg the differ we have a shelf full of them - reason? they are a wear item, and wear out hope this helps. Jamie
Foglights???
Subie Gal replied to kenfb1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
AGAIN, they are not available from subaru in anything other than the complete unit try www.google.com for "used subaru parts" i've used www.aaronsauto.com and Halspartsandservice.com with much success good luck! Jamie -
Foglights???
subaru sells fog light assemblies only as complete units thus, the price... you get the bulb, harness, lense assy... it's complete check with wholesale on line dealerships such as www.allsubaru.com and www.subaruwrxparts.com - even if you dont see the item on their sites, they can get it to you, and at wholesale pricing. Jamie
