12
Everything posted by Subie Gal
stand for? dunno and dont care the GREEN THING is actually known as the outer joint for the axle. the ring on the end of it... known as the DOJ BAFFLE PLATE the seal in the end of the joint? the DOJ seal how do i know? i work for Subaru and sell these parts for a living. also have replaced 3 of these seals in the last 2 months on my race car.... but hey! what do i know! i'm just a girl Jamie
2.5 trunk
Subie Gal replied to Erudite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
oh okay yep. the 1993-2001 trunk lids are all the same size/shape i had a 95, and currently have a 2001... parts are very very much compatible. cheers Jamie -
I run Dunlop Sport5000's on my Subaru's love em. kick rump roast in the rain good in light snow (i have had mine up to about 8") and nice grip on the dry Decent treadwear (last set did me about 40k miles) only concern is that they may not have the right tire size for the OBK? not sure on that one... see the review for the Dunlop sp5000's on www.tirerack.com in their price range? they are one of the best all season tires out there. hope this helps Jamie
i work at Carter and i was a carter customer with a bad head gasket issue loooong before i started working here... they treated me right and kept me posted on what was going on with my car that only made me more interested in eventually becoming a member of the Carter Family Good people here.. and you will find that many of them have been here for 5.... 10.... 14... years.. even longer. You dont stay with a company that long unless they are doing something right! swing by sometime and say hi... My office is located in the new Carter quick lube/tire building have fun Jamie
2.5 trunk
the 2.5 RS has been around for years 1998 - 2005 what model year 2.5RS are you talking about? -
RiMs?
www.nasioc.com private classifieds you will find wrx, legacy, non wrx impreza, sti wheels and more i've seen entire sets of new wrx wheels + tires go for $200ish good luck Jamie -
that's not your CV that's your DOJ seal both are parts of the axle 1/2 shaft cv is the outer part of the axle, near the hub doj is the inner part of the axle, connected to the tranny/front diff. Unless there is an obvoius tear in the doj boot? you probably just need a new doj seal. very very common issue. there is a seal which is supposed to sit just inside the end of that 'green thing' (green thing is the inner part of your axle 1/2 shaft) you need to pull that off of the tranny, replace the seal, regrease if needed and reinstall it. there is a pin that is holding that doj into place you should also replace the pin as once you tap it out, it may not seal correctly once replaced and you'll have more seepage and leakage hope this helps. good luck Jamie
thanks Eric and Austin and everyone! my friend Tom and his son have one they are working on i'm helping them gather info and such... you guys are an awesome help!! Jamie
