Everything posted by SubieTrav
Other cars/Vehicles we own
I still have my 96 Outback. For my delivery business I have a 99 Dodge Grand Caravan AWD. I'm looking to move up to a full size cargo van.
What's the difference between the Legacy Outback, the Legacy Wagon, and the Outback?
SubieTrav replied to billfred97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOutback has the raised roof, Legacy doesn't.
Hello from Colorado
Welcome, there are several of us here in CO, I'm in Denver.
97 2.2 Valve Job vs used engine replacement
SubieTrav replied to revtim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat about just changing the heads.
who does this?
SubieTrav replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI keep a spare tensioner so I don't have wait out the time to compress it again.
paint code
SubieTrav replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsually the front driver side strut tower. Factory paint code is 19X Silver Stone Metallic.
91 Loyale for $950 with 170k?
SubieTrav replied to rydney's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd only pay that price if it was 4wheel drive. I have no interest in 2 wheel dive so If that was the case, I'd walk away. It doesn't say which window has a chip (I like that description, tempered glass breaks when chipped) but the front passenger window is either rolled down or broken. The door windows are a bit of a pain to replace considering the attachments on the glass and trying to get them in the door with the narrow opening but once in they just bolt to the regulator and then align it to the proper position when closed.
SubieTrav replied to rydney's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://tinyurl.com/m4d59xv Is this the car. The clear coat is pretty badly eaten off. Can't tell if it is 4wheel drive or not.
window vent visors
SubieTrav replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe vent visors for the 3rd gen will work. I have them on my 96 OB. Mine were from Amazon.
96 OB 5mt
SubieTrav replied to SubieTrav's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not certain how good my transmission is. The shifter is tight, but I get grinding going into reverse. The bigger problem is recently I had a clutch put in and a couple days later I was smelling something burning. I checked the fluids and the nothing was touching the tranny dipstick. So I added some and still nothing, I ended up putting a quart of gl5 80-90 gear oil in to bring it up to full. I was hearing some scraping grinding noise when coming to a stop. Also at low speeds, when turning into a parking space, I would get little jerking on the steering wheel like when an auto trans would do with a bad duty c. I called the guy who put the clutch in and he said it must have already been bad. Do you think I should just change the center dif and change the gear oil it would be ok?
96 OB 5mt
I have a 96 OB 2.2 5mt (cable linkage) that has a bad center dif. I'm going to be replacing the transmission.I was just at a junk yard and there are 2 OB with hydralic linkage manual trans, a 97 OB and a 98 OB. Can I use a hydraulic type trans and swap parts to make it stay cable type.
Hello from South Dakota
Welcome to USMB. Born and grew up around Mitchell. My first Subaru was an 88 GL, I miss it.
96 OB CEL Code 1101
SubieTrav replied to SubieTrav's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, at least I'll know what to do if it goes into limp mode. So far it is running the same as always.
96 OB CEL Code 1101
My 96 OB 2.2 5mt through a code 1101, Neutral Position Switch Circuit Malfunction(MT). How imortant is it I get this fixed right away. Can it wait till the weekend.
New Subaru Outback owner wondering about rear sway bar
SubieTrav replied to Beesh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're right, they did decrease the size of the rear sway bar, I did a google search. Looks like the '09 Sti 19mm is a good replacement per this article http://tinyurl.com/knrg4ag
SubieTrav replied to Beesh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought Outbacks came factory with 18mm, at least my 96 did.
91 Loyale Fuel Reset Button
I didn't think it had one, when the weather warms up we'll try to get it running. My brother wants the motor for his other Loyale with 300K miles. This one has 112K.
It was hit on the front right corner and the car was spun around and hit again between the rear right tire and the gas door.
Today I totaled my brothers 91 Loyale. I doesn't start. the cops that did the accident report were asking if I new where the fuel reset button was. I told them I didn't think it had one. Does it have one and if so, where is it.
- HOWDY from Colorado!
What is the 4eat's Housing made from? Aluminum or Magnesium?
SubieTrav replied to Tony2toes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I took my 4eat to the scrappers, they took it as bulk and I only got $20 for it.
CEL 1997 Outback
SubieTrav replied to lichen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://jdmfsm.info/Auto/Japan/Subaru/--Articles--/--Endwrench--/ I couldn't figure out how to just send the one article so here are all of them, just scroll down to 4EAT.pdf.
CEL 1997 Outback
SubieTrav replied to lichen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour torque converter is not locking up. Check the tranny fluid, see if it is clean and is up to level with the car at operating temp and on level ground. Could also be an electrical issue, or a faulty torque converter clutch solenoid valve.
special tool
SubieTrav replied to lichen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 2.5 DOHC is an interferance engine.
